imagePRESS C850/C750 Series
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
imagePRESS C850/C750 digital color production presses offer end-users outstanding quality, productivity, and versatility in a compact, scalable footprint. Designed for small-to-medium commercial, franchise, in-plant, transactional and quick printers, imagePRESS C850 Series is equipped to handle a variety of media options up to 110 lb Cover, including heavy, coated, textured stock and envelopes at an outstanding level of reliability and performance.
Built upon the successful imagePRESS C800 Series platform, the imagePRESS C850/C750 offer users even more capabilities, ease of use and productivity.
New Capabilities:
- Fast turnaround with print speeds of up to 85/75 letter images per minute (Color and B&W)
- Duplex long sheet printing of up to 30 inches for new applications*
- New in-line finishing options:
- Multi Function Professional Puncher** for die punching and creasing
- Booklet Trimmer with continuous run capability
- Faster, Simple Registration Adjustment
- New PRISMAsync Color Print Server V5 for more flexibility in achieving amazing print quality:
- Realistic previews on the user interface
- Flexible color corrections
- Digital Moiré Reduction
Proven imagePRESS technologies:
- Unique imagePRESS Gloss Optimization to help match the gloss level of the toner image to that of the paper used for offset-like quality
- Advanced Twin Belt Fusing enables efficient belt heating and quick cooling for Gloss Optimization and fast print speeds
- CV Toner for high-speed output of smooth, vivid, and consistent image quality
- Compact Registration Module helps provide accurate registration in a small footprint, for first time right output
- High definition 2400x2400 dpi print resolution with R-VCSEL Laser Scanner Unit
- Advanced Image Transfer Belt for outstanding quality even on textured surfaces
*Requires feeding and output options.
**Not available at initial launch.
Vibrant and Consistent Image Quality
State-of-the-art, 32-beam Red VCSEL laser achieves 2400 x 2400 dpi and outputs crisp, clear color images with remarkable clarity and definition at high speeds. It also features various halftone screen patterns for increased flexibility and optimised quality closer to offset to deliver the required quality the most demanding environments.
Consistently Vivid (CV) Toner
The CV Toner improves transfer efficiency and provides consistent, quality output on a wide variety of media.
Advanced Image Transfer Belt (ITB)
Advance ITB helps achieve quality output on various types of media including media with rough surface such as textured media or envelopes.
Outstanding Stability
Calibration Tools
The imagePRESS C850/C750 color digital presses offer automatic, real-time calibration and provide tools to help reduce calibration time to reliably deliver high-quality, repeatable, predictable output with minimal operator intervention.
Developer Unit
The developer uses internal air flow to maintain cool temperatures and vertical flow to efficiently use the developers which helps ensure stable color across the run.
Compact Registration Technology
With a compact design, the module helps achieves precise front-to-back registration for first time right output and maintain across the job.
Media Versatility
Long Sheet Duplex Printing
Auto-duplex long sheet printing of up to 13” x 30” paper formats to offer applications such as 6 panel brochures and dust jackets.
In-line Finishing
Achieve “white-paper-in, finished-productout” workflows with Canon’s extensive in-line finishing options. Maintain high quality, even on half-folded spines with the in-line creasing feature of the optional Multi Function Professional Puncher*
* Not available at initial launch.
Maximized Uptime
Induction heating and cooling technologies use two belts that allow the press to fuse at a lower temperature which helps the press to be kept productive on regular and mixed media jobs while controlling gloss and image quality.
Large Media Capacity
Maximum of up to 7,650-sheet input capacity with the Multi Drawer Paper Deck allows for unattended production runs. And with up to six different sources, operators can load many different media types for mixed-media jobs.
On-the-fly replacement
Keep the press running and maintain a steady workflow with the ability to replace paper, toner, and trim waste with the new Booklet Trimmer-F1 during a print run.
| Model Name | ImagePRESS C850 / C750 |
| Imaging System | Electrophotography |
| Printing Resolution | Up To 2400 X 2400 Dpi |
| Halftone | 256-Level Grayscale |
| Letter | (Simplex / Duplex): C850: Up To 85 Ipm / C750: Up To 75 Ipm |
| Legal | (Simplex / Duplex): C850: Up To 43 Ipm / C750: Up To 37 Ipm |
| Ledger | (Simplex / Duplex): C850: Up To 40 Ipm / C750: Up To 35 Ipm |
| Statement | (Simplex / Duplex): C850: Up To 38 Ipm / C750: Up To 33 Ipm |
| Duplexing | Automatic Duplex Any Supported Stock |
| Paper Size | 3.94" X 5.83" To 13" X 19.2" |
| Capacity | Standard: Up To 1,650 Sheets (20 Lb. Bond) Maximum: Up To 7,650 Sheets (20 Lb. Bond) |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover* (52 Gsm To 300 Gsm)* |
| Different Size Originals | Envelopes:** #10 Business, Monarch, 6" X 9", 9" X 12", 10" X 13" |
| Power Source | Single-Phase 208 V/20 A |
| Dimensions | 56.1" X 60.2" X 36.8"(Includes Operator Panel) |
| Description | Multi-Drawer Paper Deck-C1 |
| Paper Capacity | Up To 6,000 Sheets (20 Lb. Bond) |
| Paper Size | 5.5" X 7.2" To 13" X 19.2" |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover (52 Gsm To 300 Gsm) |
| Power Source | 120 V/15 A |
| Dimensions | 40.9" X 37.4" X 31.4" |
| Description | POD Deck Lite-C1 |
| Paper Capacity | Up To 3,500 Sheets (20 Lb. Bond) |
| Paper Size | 5.5" X 5.83" To 13" X 19.2" |
| Paper Type | Envelopes:** #10 Business, Monarch, 6" X 9",9" X 12", 10" X 13" |
| Dimensions | 22.5" X 28.2" X 27.0" |
| Description | Stack Bypass-B1 |
| Paper Capacity | Up To 100 Sheets (20 Lb. Bond) |
| Paper Size | 3.94" X 5.83" To 13" X 19.2" (Long Sheet Up To 30"†) |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover(52 Gsm To 300 Gsm) |
| Paper Type | Envelopes: #10 Business, Monarch, 6" X 9",9" X 12", 10" X 13" |
| Description | Duplex Color Image Reader-K1 |
| Paper Size | Statement To 11" X 17"Sensor: CCDResolution: Up To 600 X 600 Dpi, 256 GradationsTray Capacity: Up 300 Sheets (20 Lb. Bond)Scan Speed: (Simplex/Duplex): Up To 300 Dpi / Up To 600 Dpi BW (Duplex/Simplex): Up To 200/120 Ipm / Up To 120/120 Ipm Color (Duplex/Simplex): Up To 140/120 Ipm / Up To 70/70 Ipm |
| Description | Staple Finisher-W1/Booklet Finisher-W1 |
| Paper Size | Stapling: 11" X 17", LGL, LTR-R, EXEC, LTR,12" X 18", 13" X 19.2", Custom Size(8.3" X 11" To 13" X 19.2") Saddle Finisher: 11" X 17", LGL, LTR-R, 12" X 18",13" X 19", Custom Size (8.3" X 11" To 13" X 19.2") |
| Paper Weight | 14 Lb. Cover To 110 Lb. Cover(52 Gsm To 300 Gsm) |
| Top Tray | Up To 1,000 Sheets (20 Lb. Bond) |
| Lower Tray | Up To 4,000 Sheets (20 Lb. Bond) |
| Saddle Stitch Tray | Up To 30 Booklets Or Limitless |
| Staple Capacity | Up To 100 Sheets |
| Staple Positions | Corner Stapling, Double Stapling |
| Booklet Stapling Capacity | (20 Lb. Bond): Uncoated: Up To 25 Sheets Coated: Up To 10 Sheets V Folding: Up To 5 Sheets Without Stitch |
| Dimensions | Staple Finisher: 48.8" X 35.0" X 31.2" Booklet Finisher: 48.8" X 41.7" X 31.2" |
| Description | Multi Function Professional Puncher-A1■ |
| Paper Size | 12" X 18", 11" X 17", LTR, LGL, LTR-R, STMT |
| Paper Weight | Plain: 20 Lb. Bond To 110 Lb. Cover(75 Gsm To 300 Gsm) Coated: 20 Lb. Bond To 110 Lb. Cover(80 Gsm To 300 Gsm)Die Set Patterns: Loose Leaf 3-Hole/5-Hole, Velo Bind, 11-Hole, Plastic Comb 19-Hole, Twin Loop, 21-Hole/32-Hole, Color Coil 44-Hole, Crease■ |
| Power Requirements | 120 V/15 A |
| Dimensions | 40.9" X 17.5." X 31.2" |
| Description | Puncher Unit-BS1(Option For Staple Finisher-W1/Booklet Finisher-W1) |
| Paper Size | 2-Hole: Legal, Letter-R, Custom Size(7.2" X 7.2" To 11.7" X 17") 3 Hole: 11" X 17", Letter, Executive-R, CustomSize (9.4" X 7.2" To 11.7" X 17") |
| Description | Booklet Trimmer-F1▲ |
| Margin Trimming | Front-Edge Trim |
| Trim Amount | 0.08" To 1.1" |
| Trim Thickness | 50 Sheets |
| Output Tray Capacity | 30 Booklets |
| Dimensions | 40.9" X 62.1" X 30.3" |
| Description | Two-Knife Booklet Trimmer-A1▲▲ |
| Margin Trimming | Top And Bottom |
| Trim Amount | 0.08" To 0.59" |
| Dimensions | 40.9" X 21.1" X 30.3" |
| Description | Document Insertion Unit-N1 |
| Paper Size | 11" X 17", 12" X 18", 13" X 19", LGL, LTR, LTR-R, EXEC, Custom Size (7.2" X 7.2" To 13" X 19.2") |
| Tray Capacity | Upper Tray: Up To 200 Sheets (20 Lb. Bond) Lower Tray: Up To 200 Sheets (20 Lb. Bond) |
| Description | Paper Folding Unit-J1 |
| Paper Weight | 14 Lb. Bond To 28 Lb. Bond(50 Gsm To 105 Gsm) |
| Fold Type | Double Parallel Fold: Legal, Letter-R C/Accordion Fold: Letter-R Z-Fold: 11" X 17" |
| Power Requirements | From Finisher |
| Dimensions | 46.87" X 13.25" X 31.25" |
| Weight | 157 Lb. (71 Kg) |
| Description | High-Capacity Stacker-H1 |
| Offset Stack Capacity | Up To 6,000 Sheets (20 Lb. Bond) |
| Top Tray Capacity | Up To 200 Sheets (20 Lb. Bond) |
| Paper Size | 7.2" X 7.2" To 13" X 19.2" |
| Maximum Connectivity | 1 Unit |
| Dimensions | 40.9" X 35.4" X 29.3" |
| Description | Perfect Binder-E1 |
| Cutting Method | 3-Side Cut/1-Side Cut/No CutFinished Book Size: 5.4" X 7.99" To 8.5" X 11.69" |
| Cover Weight | 28 Lb. Bond To 110 Lb. Cover(90 Gsm To 300 Gsm)Body Paper Weight: 14 Lb. Bond To 43 Lb. Bond(52 Gsm To 163 Gsm) |
| Book Thickness | 10 To 200 Sheets (20 Lb. Bond), (Up To 0.98") |
| Trim Range | Top/Bottom: 0.26" To 1.56" Side: 0.26" To 1.95" |
| Power Requirements | 208 V/15 A |
| Dimensions | 53.5" X 36.3" X 31.1"* Engine Cassette Supports 52 Gsm To 220 Gsm. ** Requires Envelope Attachment Kit. *** With Optional Stack Bypass-C2 And Long Sheet Tray. Paper Sizes Longer Than 19.2" Can Be Fed One Sheet At A Time. ▲ Must Connect To Booklet Finisher-W1. ▲ ▲ Must Connect To Booklet Trimmer-F1. ■ Not Available At Launch. |
T01 Toner Black
Estimated Toner Yield: 56,000 Copies/Bottle (Estimated 8.5% Coverage)
T01 Toner Magenta
Estimated Toner Yield: 39,500 Copies/Bottle (Estimated 8.5% Coverage)
T01 Toner Cyan
T01 Toner Yellow
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
