imagePRESS C800/C700
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- CV Toner produces exceptionally vibrant images on a wide variety of media.
- Compact Registration Module helps ensure that images are placed in the same location for each sheet for high-quality results.
- A 32 beam red Vertical Cavity Surface Emitting Laser (VCSEL) with multiple-exposure technology delivers 2400 x 2400 dpi resolution and allows customers to choose from a selection of versatile screen patterns.
- New Auto Correct Color Tone and Enhanced Auto Gradation Adjustment for multidimensional mixed color calibration. The imagePRESS C800 Series reliably delivers high-quality, stable output with minimal operator intervention. In addition to automatic real-time calibration, the system provides users with tools to cut down on calibration time and achieve repeatable, predictable output.
Advanced Twin Belt Fusing
32-Beam Red-VCSEL Laser
CV Toner
Compact Registration Technology
VF Developer Unit
| Model Name | ImagePRESS C800/C700 Series |
| Imaging System | 32-Beam R-VCSEL Laser Technology |
| Printing Resolution | 2400 X 2400 Dpi |
| Halftone | 256-Level Grayscale |
| Letter | (Simplex / Duplex): C800: Up To 80 Ipm C700: Up To 70 Ipm |
| Legal | (Simplex / Duplex): C800: Up To 46 Ipm C700: Up To 41 Ipm |
| Ledger | (Simplex / Duplex): C800: Up To 40 Ipm C700: Up To 35 Ipm |
| Cassettes | 11"×17", Legal, Letter, Letter-R, Executive, Statement-R, 12"×18", 13"×19", Envelope (Envelope Attachment Kit Required), Custom Size (3.94"X5.83" To 13" X 19.2") |
| Bypass | (Optional): 11"×17", Legal, Letter, Letter-R, Executive, Statement-R, 12"×18", 13"×19", Envelope, Custom Size (3.94"X5.83" To 13" X 19.2") |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220g/M2) |
| Bypass | (Optional): 14 Lb. Bond To 110 Lb. Cover (52 To 300g/M2) |
| Duplexing | Automatic Duplex/Perfect, Any Supported Stock |
| Paper Size | 11"×17", Legal, Letter, Letter-R, Executive, Statement-R, 12"×18", 13"×19", Custom Size (3.94"X5.83" To 13" X 19.2") |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover (52 Gsm To 300 Gsm) |
| Special Media Support | Cassette: Thin Paper, Plain Paper, Recycled Paper, Thick Paper, Color Paper, Transparency, Pre-Punched Paper, Bond Paper, Letterhead, Textured Paper, Tab Paper, Envelope (Envelope Attachment Kit Required) Bypass: Thin Paper, Plain Paper, Recycled Paper, Thick Paper, Color Paper, Transparency, Pre-Punched Paper, Coated Paper, Bond Paper, Letterhead, Textured Paper, Tab Paper, Envelope |
| Plug | Single-Phase 208 V/20 A # NEMA 6-20P 220-240 V AC, 50/60 Hz, 13 A+13 A (Two Power Cords) |
| Dim | (H X W X D): 56.1" X 54.63" X 36.7" (Includes Operator Panel) |
| Scan Resolution | 600 X 600 Dpi, 256 GradationsImage Sensor: CCD |
| Acceptable Originals | Statement To 11" X 17"Scan Speed: C800: 300dpi / C700: 600dpi BW (Duplex): C800: 200 / C700: 120 Color (Duplex): C800: 140 / C700: 70 |
| Description | Multi-Drawer Paper Deck-B1 |
| Paper Capacity | 6,000 Sheets (20 Lb. Bond) |
| Paper Size | 5.5" X 7.2" To 13" X 19.2" |
| Power Source | 120-127 V AC, 60 Hz, 3.1 A 220-240 V AC, 50/60 Hz, 1.7 A |
| Dimensions | (H X W X D): 22.5" X 28.2" X 27" |
| Description | POD Deck Lite-B1 |
| Paper Capacity | 3,500 Sheets (20 Lb. Bond) |
| Paper Size | 3.94" X 5.83" To 13" X 19.2" |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover (52 Gsm To 300 Gsm)Envelopes: #10 Business, Monarch, 6" X 9", 9" X 12", 10" X 13", Custom |
| Power Source | 120-127 V AC, 60 Hz, 2.2 A 220-240 V AC, 50/60 Hz, 1.2 A |
| Dimensions | (H X W X D): 22.4" X 23.7" X 24.4" |
| Description | Stack Bypass-B1 |
| Paper Capacity | 100 Sheets (20 Lb. Bond) |
| Paper Size | 5.5" X 7.2" To 13" X 19" |
| Description | Finisher-AM1/Saddle Finisher-AM2 |
| Paper Size | Stapling: Executive, Letter-R, Letter, Legal, 11" X 17" Saddle Finisher: Letter-R, Legal, 11" X 17", 12" X 18", 13" X 19", Custom Size |
| Paper Weight | 14 To 110 Lb. Cover (52 Gsm To 300 Gsm) |
| Top Tray | 1,000 Sheets (20 Lb. Bond) |
| Lower Tray | 4,000 Sheets (20 Lb. Bond) |
| Saddle Stitch Tray | 30 Booklets Or Limitless |
| Staple Capacity | Up To 100 Sheets |
| Staple Positions | Corner Stapling, Double Stapling |
| Booklet Stapling Capacity | Uncoated: Up To 25 Sheets Coated: Up To 15 Sheets V-Folding: Up To 5 Sheets Without Stitch (20 Lb. Bond) |
| Dimensions | (H X W X D): AM1: 48.8" X 35.0" X 31.2" AM2: 48.8" X 41.7" X 31.2" |
| Description | Professional Puncher-B1/Integration Unit-C1 |
| Paper Size | LTR, LTR-Tab Paper |
| Paper Weight | 20 Lb. Bond To 80 Lb. Cover (75 Gsm To 216 Gsm) Die Set Patterns: Loose Leaf 3-Hole/5-Hole, Velo Bind 11-Hole, Plastic Comb 19-Hole, Twin Loop 21-Hole/32-Hole, ProClick 32-Hole, Color Coil 44-Hole Die Set Patterns 230V: Plastic Comb 21-Hole Punch A4-A1 Twin Loop 23-Hole(Round) Punch A4-A1 Twin Loop 34-Hole(Round) Punch A4-A1 Color Coil 47-Hole Punch A4-A1 Velo Bind 12-Hole Punch A4-A1 Loose Leaf 4-Hole Punch A4-A1 Pro Click 34-Hole Punch A4-A1 Loose Leaf 2-Hole Punch A4-A1 |
| Plug | 120-127 V AC, 60 Hz, 5.5 A 220-240 V AC, 50/60 Hz, 3.1 A |
| Dimensions | (H X W X D): 40.9" X 22.0" X 31.2"* |
| Description | Puncher Unit-BS1/Puncher Unit-BT1 (Option For Finisher/Saddle Finisher) |
| Paper Size | 2-Hole: Letter-R, Custom Size (182 X 182 Mm To 297 X 432 Mm) 3-Hole (BS1 Only): 11" X 17", Letter, Executive-R, Custom Size (240 X 182 Mm To 297 X 432 Mm) 4-Hole (BT1 Only): 11" X 17", Letter, Executive-R, Custom Size (257 X 182 Mm To 297 X 432 Mm) |
| Paper Weight | 14 Lb. Bond To 110 Lb. Index (52 Gsm To 200 Gsm) |
| Description | Booklet Trimmer-D1** |
| Margin Trimming | Front-Edge Trim |
| Trim Amount | 0.08" To 0.78" |
| Trim Thickness | 50 Sheets |
| Output Tray Capacity | 30 Booklets |
| Dimensions | (H X W X D): 40.9" X 62.1" X 30.3" |
| Description | Two-Knife Booklet Trimmer-A1*** |
| Margin Trimming | Top And Bottom |
| Trim Amount | 0.08" To 0.59" |
| Power Requirements | 120-127 V AC, 50/60 Hz, 4 A 220-240 V AC, 50/60 Hz, 2.3 A |
| Dimensions | (H X W X D): 40.9" X 21.1" X 30.3" |
| Description | Document Insertion Unit-M1 |
| Paper Size | 7.2" X 7.2" To 13" X 19.2" |
| Tray Capacity | Upper Tray: 200 Sheets Lower Tray: 200 Sheets |
| Description | Paper Folding Unit-F1 |
| Paper Weight | 14 Lb. Bond To 28 Lb. Bond (52 Gsm To 105 Gsm) |
| Fold Type | Double Parallel Fold: Legal, Letter-R C/Accordion Fold: Letter-R Z-Fold: Legal, Letter-R, 11" X 17" |
| Dimensions | (H X W X D): 46.87" X 13.25" X 31.25" |
| Weight | 157 Lb. (71 Kg) |
| Description | High-Capacity Stacker-G1 |
| Offset Stack Capacity | 6,000 Sheets (20 Lb. Bond) |
| Top Tray Capacity | 200 Sheets (20 Lb. Bond) |
| Paper Size | Up To 13" X 19.2" |
| Maximum Connectivity | 1 Unit |
| Power Requirements | 120 V/15 A |
| Dimensions | (H X W X D): 40.9" X 35.4" X 29.3" |
| Description | Perfect Binder-D1 |
| Cutting Method | 3-Side Cut/1-Side Cut/No CutFinished Book Size: 5.4" X 7.99" To 8.5" X 11.69" |
| Cover Weight | 28 Lb. Bond To 110 Lb. Cover (105 Gsm To 300 Gsm)Body Paper Weight: 14 Lb. Bond To 43 Lb. Bond (52 Gsm To 163 Gsm)Finished Size: 5.5" X 8" To 8.5" X 11.6" |
| Book Thickness | 10 To 200 Sheets (20 Lb. Bond) (Up To 0.98") |
| Trim Range | Top/Bottom: 0.52" To 3.11" Side: 0.26" To 1.48" |
| Power Requirements | 208 V AC, 60 Hz, 3.0 A 220-240 V AC, 50/60 Hz, 3.0 A |
| Dimensions | (H X W X D): 53.5" X 36.3" X 31.1"* Size Includes Professional Puncher Integration Unit-A1. ** Must Connect To Saddle Finisher-AM2. *** Must Connect To Booklet Trimmer-D1. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
