imagePRESS C65
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Graphic Design Quality
CV Toner
The CV Toner helps deliver graphic design quality by providing vibrant and highly consistent quality with a wide color gamut on a broad range of media.
R-VCSEL
State-of-the-art, 32-beam Red VCSEL laser achieves 2400 x 2400 dpi and outputs crisp, clear color images with remarkable clarity and definition at high speeds. It also features several halftone screen patterns for increased flexibility and optimised quality on various types of images.
Compact Registration Technology
With a compact design, the module helps achieves precise front-to-back registration for first time right output and maintain across the job.
Advanced ITB
Advance ITB helps achieve quality output on various types of media including media with rough surface such as textured media or envelopes.
Meet Deadlines with Ease
Fast Output
With a start-up time of six minutes or less and a first-copy-out speed of under 7.7 seconds, the imagePRESS C65 is ready when you need it. Production speeds of up to 65 ipm on a wide range of media help keep you on track.
Calibration Tools
The imagePRESS C65 color digital presses offer automatic, real-time calibration and provide tools to help reduce calibration time to reliably deliver high-quality, repeatable, predictable output with minimal operator intervention.
Developer Unit
The developer uses internal air flow to maintain cool temperatures and vertical flow to efficiently use the developers which helps ensure stable color across the run.
Media Versatility
Long Sheet Duplex Printing
Auto-duplex long sheet printing of up to 13” x 30” paper formats for proofs and design studies, for example 6-panel brochures, fold outs, dust jackets for books or larger packaging
In-line Finishing
Achieve “white-paper-in, finished-productout” workflows with Canon’s extensive in-line finishing options. Maintain high quality, even on half-folded spines with the in-line creasing feature of the optional Multi Function Professional Puncher*
| Model Name | ImagePRESS C65 |
| Imaging System | Electrophotography |
| Printing Resolution | Up To 2400 X 2400 Dpi |
| Halftone | 256-Level Grayscale |
| Letter | (Simplex / Duplex): Up To 65 Ipm |
| Legal | (Simplex / Duplex): Up To 34 Ipm |
| Ledger | (Simplex / Duplex): Up To 32 Ipm |
| Statement | (Simplex / Duplex): Up To 30 Ipm |
| Duplexing | Automatic Duplex Any Supported Stock |
| Paper Size | 3.94" X 5.83" To 13" X 19.2" |
| Capacity | Standard: Up To 1,650 Sheets (20 Lb. Bond) Maximum: Up To 7,650 Sheets (20 Lb. Bond) |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover* (52 Gsm To 300 Gsm)* |
| Different Size Originals | Envelopes:** #10 Business, Monarch, 6" X 9", 9" X 12", 10" X 13" |
| Power Source | Single-Phase 208 V/20 A |
| Dimensions | 56.1" X 60.2" X 36.8"(Includes Operator Panel) |
| Description | Multi-Drawer Paper Deck-C1 (Optional) |
| Paper Capacity | Up To 6,000 Sheets (20 Lb. Bond) |
| Paper Size | 5.5" X 7.2" To 13" X 19.2" |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover (52 Gsm To 300 Gsm) |
| Power Source | 120 V/15 A |
| Dimensions | 40.9" X 37.4" X 31.4" |
| Description | POD Deck Lite-C1 (Optional) |
| Paper Capacity | Up To 3,500 Sheets (20 Lb. Bond) |
| Paper Size | 5.5" X 5.83" To 13" X 19.2" |
| Paper Type | Envelopes:** #10 Business, Monarch, 6" X 9",9" X 12", 10" X 13" |
| Dimensions | 22.5" X 28.2" X 27.0" |
| Description | Stack Bypass-B1 (Optional) |
| Paper Capacity | Up To 100 Sheets (20 Lb. Bond) |
| Paper Size | 3.94" X 5.83" To 13" X 19.2" (Long Sheet Up To 30"†) |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover(52 Gsm To 300 Gsm) |
| Paper Type | Envelopes: #10 Business, Monarch, 6" X 9",9" X 12", 10" X 13" |
| Description | Duplex Color Image Reader-K1 (Optional) |
| Paper Size | Statement To 11" X 17"Sensor: CCDResolution: Up To 600 X 600 Dpi, 256 GradationsTray Capacity: Up 300 Sheets (20 Lb. Bond)Scan Speed: (Simplex/Duplex): Up To 300 Dpi / Up To 600 Dpi BW (Duplex/Simplex): Up To 200/120 Ipm / Up To 120/120 Ipm Color (Duplex/Simplex): Up To 140/120 Ipm / Up To 70/70 Ipm |
| Description | Staple Finisher-W1/Booklet Finisher-W1 (Optional) |
| Paper Size | Stapling: 11" X 17", LGL, LTR-R, EXEC, LTR,12" X 18", 13" X 19.2", Custom Size(8.3" X 11" To 13" X 19.2") Saddle Finisher: 11" X 17", LGL, LTR-R, 12" X 18",13" X 19", Custom Size (8.3" X 11" To 13" X 19.2") |
| Paper Weight | 14 Lb. Cover To 110 Lb. Cover(52 Gsm To 300 Gsm) |
| Top Tray | Up To 1,000 Sheets (20 Lb. Bond) |
| Lower Tray | Up To 4,000 Sheets (20 Lb. Bond) |
| Saddle Stitch Tray | Up To 30 Booklets Or Limitless |
| Staple Capacity | Up To 100 Sheets |
| Staple Positions | Corner Stapling, Double Stapling |
| Booklet Stapling Capacity | (20 Lb. Bond): Uncoated: Up To 25 Sheets Coated: Up To 10 Sheets V Folding: Up To 5 Sheets Without Stitch |
| Dimensions | Staple Finisher: 48.8" X 35.0" X 31.2" Booklet Finisher: 48.8" X 41.7" X 31.2" |
| Description | Staple Finisher-T1/Booklet Finisher-T1 (Optional) |
| Paper Size | Stapling: Executive, Letter-R, Letter, Legal, 11" X 17" Saddle-Stitching: Letter-R, Legal, 11" X 17", 12" X 18" |
| Paper Weight | Top/Lower Tray: 14 Lb. Bond To 110 Lb. Cover (52 To 300 Gsm) Escape Tray: 14 Lb. Bond To 140 Lb. Index (52 To 256 Gsm) |
| Top Tray | Up To 1,300 Sheets (20 Lb. Bond) |
| Lower Tray | Up To 2,450 Sheets (20 Lb. Bond) Escape Tray: Up To 250 Sheets (20 Lb. Bond) |
| Saddle Stitch Tray | Up To 25 Booklets |
| Staple Capacity | Up To 50 Sheets |
| Booklet Stapling Capacity | Up To 16 Sheets |
| Dimensions | 44.1" X 30.0" X 25.8" |
| Description | Multi Function Professional Puncher-A1††† |
| Paper Size | 12" X 18", 11" X 17", LTR, LGL, LTR-R, STMT |
| Paper Weight | Plain: 20 Lb. Bond To 110 Lb. Cover(75 Gsm To 300 Gsm) Coated: 20 Lb. Bond To 110 Lb. Cover(80 Gsm To 300 Gsm)Die Set Patterns: Loose Leaf 3-Hole/5-Hole, Velo Bind, 11-Hole, Plastic Comb 19-Hole, Twin Loop, 21-Hole/32-Hole, Color Coil 44-Hole, Crease††† |
| Power Requirements | 120 V/15 A |
| Dimensions | 40.9" X 17.5." X 31.2" * Engine Cassette Supports 52 Gsm To 220 Gsm. ** Requires Envelope Attachment Kit. † With Optional Stack Bypass-C2 And Long Sheet Tray. Paper Sizes Longer Than 19.2" Can Be Fed One Sheet At A Time. †† Must Connect To Staple Finisher-W1 Or Booklet Finisher-W1 ††† Not Available At Launch. |
T01 Toner Black
Estimated Toner Yield: 56,000 Copies/Bottle (Estimated 8.5% Coverage)
T01 Toner Magenta
Estimated Toner Yield: 39,500 Copies/Bottle (Estimated 8.5% Coverage)
T01 Toner Cyan
T01 Toner Yellow
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
