imagePRESS C6010
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
True 1,200 x 1,200 dpi with 256 levels of gray enable the highest near-offset quality for the most color critical environments.
The imagePRESS C6010 can handle a vast variety of medias ranging from 16 lb. bond to 120 lb. cover.
Gloss Optimization technology enables the adjustment of the imaged area appearance to minimize deviations in gloss reflectance relative to media finish.
Closed-loop, real-time color controls coupled with new internal environmental controls help to keep high quality consistent - even throughout longer runs.
Air Suction, Air Seperation, and Air Assist technologies provide reliable, accurate paper feeding, just like offset.
The imagePRESS C7010VP series features 2,000 sheet input standard, with the ability to scale up to 10,000 sheets. All trays accommodate all supported media.
Canon's oil free V Toner enable one of the widest color gamuts and a lay-flat finish, just like offset inks, even on pages with high toner coverage.
On-the-fly replacements of paper, toner, and waste toner keeps jobs flowing through the press to maximize uptime.
Productivity enhancements enable increased performance for complex jobs, including jobs containing mixed-media and mixplex sheets.
The new imagePRESS C7010VP Series features increased part life of several key parts and components, increasing uptime and reliability to help your press meet the demands of deadline-oriented environments.
Modules for saddle-stitching, stapling, perfect binding, hole-punching, and in-line trimming can be quickly integrated with any imagePRESS model.
More durable parts, recyclable consumables, and energy-saving mode leverage on-demand printing sustainibly; print on recycled stocks and produce output that can be easily de-inked and recycled.
The Media Library lets you create, edit, manage, and select medias from one central location. Once the details of the media are entered it's stored and the press is set for optimal performance and quality.
| Model Name | ImagePRESS C6010VP |
| Type | Laser Electrostatic Transfer System |
| Scanning Resolution | Up To 1200 X 1200 Dpi |
| Halftone | 256-Level Grayscale Paper Size: 7.2" X 7.2" - 13" X 19.2" |
| Letter | 60 |
| Legal | 32 12" X 18": 30 13" X 19": 28 |
| Standard Paper Capacity | 2,000 Sheets (20 Lb. Bond) |
| Maximum Paper Capacity | 10,000 Sheets (20 Lb. Bond) |
| Cassette | 16 Lb. Bond To 120 Lb. Cover |
| Duplexing | Automatic Duplex/Perfect Any Supported Stock |
| Power Requirements | Single Phase 208V/30A |
| Dim | 52.4" X 101.8" X 45.4" |
| Estimated Toner Yield | CMYK: 35,500 Impressions At 10% Coverage (LTR Pgs) |
| Description | DADF (Duplex Automatic Document Feeder)-R1 |
| Acceptable Originals | Statement To 11" X 17" |
| Scanning Speed | Up To 80 Ipm (300 Dpi) Up To 50 Ipm (600 Dpi) |
| Capacity | 100 Sheets (20 Lb. Bond) |
| Paper Weights | 13 Lb. Bond To 80 Lb. Cover |
| Description | POD Deck-A1 |
| Paper Capacity | 4,000 Sheets (20 Lb. Bond) |
| Paper Sizes | 7.2" X 7.2" To 13" X 19.2" |
| Paper Weights | 16 Lb. Bond To 120 Lb. Cover |
| Power Source | 208V/15A |
| Dimensions | 43.1" X 38.7" X 31.2" |
| Description | Secondary POD Deck-A1 |
| Dimensions | 43.1" X 31.9" X 31.2" |
| Description | Paper Deck-AC1 |
| Paper Capacity | 3,500 Sheets (20 Lb. Bond) |
| Paper Sizes | Letter, Letter-R, Legal, 11" X 17", 12" X 18", 13 X 19" |
| Paper Weights | 17 Lb. Bond To 110 Lb. Cover |
| Dimensions | 22.4" X 23.7" X 24.4" |
| Description | Stack Bypass-A1 |
| Paper Capacity | 100 Sheets (20 Lb. Bond) |
| Paper Sizes | 5.5" X 7.2" To 13" X 19.2" |
| Paper Weights | 17 Lb. Bond To 140 Lb. Index Color Image Reader-H1 |
| Description | Professional Puncher-B1/Integration Unit-A1 |
| Paper Weights | 20 Lb. Bond To 80 Lb. Cover |
| Paper Size | LTR, LTR-Tab Paper Die Set Patterns: Loose Leaf 3-Hole/5-Hole, Velo Bind 11-Hole, Plastic Comb 19-Hole, Twin Loop 21-Hole/32-Hole, ProClick 32-Hole, Color Coil 44-Hole |
| Power Source | 120V/15A |
| Dimensions | 40.9 X 22" X 31.2"* |
| Description | Finisher-AJ1/Saddle Finisher-AJ2 |
| Paper Weights | 16 Lb. Bond To 120 Lb. Cover** |
| Paper Size | Stapling: Executive, Letter-R, Letter, Legal, 11" X 17" Saddle Finisher: Letter-R, Legal, 11" X 17", 12" X 18", 13" X 19", Custom Size |
| Top Tray | 3,000 Sheets (20 Lb. Bond) |
| Lower Tray | 2,000 Sheets (20 Lb. Bond) |
| Saddle Stitch Tray | 30 Booklets Or Limitless |
| Staple Capacity | Up To 100 Sheets Booklet Stapling Capacity Uncoated: Up To 25 Sheets Coated: Up To 15 Sheets |
| Staple Positions | Corner Stapling, Double Stapling |
| Folding Capacity | V-Folding: Up To 5 Sheets Without Stitch (20 Lb. Bond) |
| Dimensions | 46.5" X 31.5" X 31.2" High-Capacity Stacker-C1 Perfect Binder-B1 Paper Weight: 16 Lb. Bond To 110 Lb. Index Paper Sizes 2-Hole: Legal, Letter-R 3-Hole: 11" X 17", Letter, Executive |
| Description | Booklet Trimmer-D1 Margin Trimming: Open-End Only Trim Amount: 0.08" To 0.78" Trim Thickness: 50 Sheets Paper Weight: 16 Lb. Bond To 110 Lb. Cover Output Tray Capacity: 30 Booklets Dimensions (H X W X D): 40.9" X 62" X 30.3" |
| Description | Two-Knife Booklet Trimmer-A1Margin Trimming: Top And Bottom Trim Amount: 0.08" To 0.59" Trim Thickness: 50 Sheets Paper Weight: 16 Lb. Bond To 110 Lb. Cover Dimensions (H X W X D): 40.9" X 21.1" X 30.3" Power Supply: 120V/15A |
| Description | Document Insertion Unit-C1 (Option For Finisher/Saddle Finisher) |
| Paper Weight | 16 Lb. Bond To 110 Lb. Cover |
| Paper Sizes | Upper Tray: 7.2" X 7.2" To 11.7" X 13" Lower Tray: 7.2" X 7.2" To 13" X 19.2" |
| Feeder Capacity | 200 Sheets X 2 (20 Lb. Bond)* Size Includes Professional Puncher Integration Unit-A1. ** Saddle-Stitching Cannot Handle Over 110 Lb. Cover. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
