imagePRESS C60
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Scalable Configuration
Advanced Twin Belt Fusing
32-Beam Red-VCSEL Laser
CV Toner
Compact Registration Technology
VF Developer Unit
| Model Name | Imagepress C60 |
| Imaging System | 32-Beam R-Vcsel Laser Technology |
| Printing Resolution | 2400 X 2400 Dpi |
| Halftone | 256-Level Grayscale |
| Letter | (Simplex / Duplex): Up To 60 Ipm |
| Legal | (Simplex / Duplex): Up To 36 Ipm |
| Ledger | (Simplex / Duplex): Up To 32 Ipm |
| Cassettes | 11"×17", Legal, Letter, Letter-R, Executive, Statement-R, 12"×18", 13"×19", Envelope (Envelope Attachment Kit Required), Custom Size (3.94"X5.83" To 13" X 19.2") |
| Bypass | (Optional): 11"×17", Legal, Letter, Letter-R, Executive, Statement-R, 12"×18", 13"×19", Envelope, Custom Size (3.94"X5.83" To 13" X 19.2") |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220g/M2) |
| Bypass | (Optional): 14 Lb. Bond To 110 Lb. Cover (52 To 300g/M2) |
| Duplexing | Automatic Duplex/Perfect, Any Supported Stock |
| Paper Size | 11"×17", Legal, Letter, Letter-R, Executive, Statement-R, 12"×18", 13"×19", Custom Size (3.94"X5.83" To 13" X 19.2") Paper Feeding: Standard: 1,650 Sheets (20 Lb. Bond) Maximum: 7,650 Sheets (20 Lb. Bond) |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover (52 To 300g/M2) |
| Special Media Support | Cassette: Thin Paper, Plain Paper, Recycled Paper, Thick Paper, Color Paper, Transparency, Pre-Punched Paper, Bond Paper, Letterhead, Textured Paper, Tab Paper, Envelope (Envelope Attachment Kit Required) Bypass: Thin Paper, Plain Paper, Recycled Paper, Thick Paper, Color Paper, Transparency, Pre-Punched Paper, Coated Paper, Bond Paper, Letterhead, Textured Paper, Tab Paper, Envelope |
| Plug | Single-Phase 208 V/20 A # Nema 6-20p |
| Dim | (H X W X D): 56.1" X 60.2" X 36.8" (Includes Operator Panel) |
| Scan Resolution | Up To 600 X 600 Dpi |
| Acceptable Originals | Statement To 11" X 17"Scan Speed: 300dpi / 600dpi Bw (Duplex): 200 / 120 Ipm Color (Duplex): 140 / 70 Ipm |
| Description | Multi-Drawer Paper Deck-B1 |
| Paper Capacity | 6,000 Sheets (20 Lb. Bond) |
| Paper Size | 5.5" X 7.2" To 13" X 19.2" |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover (52 Gsm To 300 Gsm) |
| Power Source | 120 V/15 A |
| Dimensions | (H X W X D): 40.9" X 37.4" X 31.4" |
| Description | Pod Deck Lite-B1 |
| Paper Capacity | 3,500 Sheets (20 Lb. Bond) |
| Paper Size | 5.5" X 5.82" To 13" X 19.2" |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover (52 Gsm To 300 Gsm)Envelopes: #10 Business, Monarch, 6" X 9", 9" X 12", 10" X 13" |
| Dimensions | (H X W X D): 22.5" X 28.2" X 27" |
| Description | Stack Bypass-B1 |
| Paper Capacity | 100 Sheets (20 Lb. Bond) |
| Paper Size | 3.94" X 5.83" To 13" X 19.2" |
| Description | Output Tray-A1 |
| Paper Size | 11"×17", Legal, Letter, Letter-R, Executive, Statement-R, 12"×18", 13"×19", Envelope (Envelope Attachment Kit Required), Custom Size (3.94"X5.83" To 13" X 19.2") |
| Total Output Capacity | Up To 250 Sheets [20 Lb. Bond (80g/M2)] |
| Dimensions | 6.9" X 16.6" X 15" |
| Weight | 2.9 Lb. |
| Description | Finisher-Am1/Saddle Finisher-Am2 |
| Paper Size | Stapling: Executive, Letter-R, Letter, Legal, 11" X 17" Saddle Finisher: Letter-R, Legal, 11" X 17", 12" X 18", 13" X 19", Custom Size |
| Paper Weight | 14 To 110 Lb. Cover (52 Gsm To 300 Gsm) |
| Top Tray | 1,000 Sheets (20 Lb. Bond) |
| Lower Tray | 4,000 Sheets (20 Lb. Bond) |
| Saddle Stitch Tray | 30 Booklets Or Limitless |
| Staple Capacity | Up To 100 Sheets |
| Staple Positions | Corner Stapling, Double Stapling |
| Booklet Stapling Capacity | Uncoated: Up To 25 Sheets Coated: Up To 15 Sheets V-Folding: Up To 5 Sheets Without Stitch (20 Lb. Bond) |
| Dimensions | (H X W X D): Am1: 48.8" X 35.0" X 31.2" Am2: 48.8" X 41.7" X 31.2" |
| Description | Staple Finisher-T1/Booklet Finisher-T1 |
| Paper Size | Staple: Executive, Letter-R, Letter, Legal, 11"X17" Saddle: Letter-R, Legal, 11"X17, 12"X18" |
| Paper Weight | Top/Lower Trays: 14 Lb. Bond To 110 Lb. Cover (52 To 300g/M2) Escape Tray: 14 Lb. Bond To 140 Lb. Index (52 To 256g/M2) |
| Number Of Trays | 3 |
| Top Tray | 1,300 Sheets (Letter, Statement-R, Executive) 650 Sheets (13"X19", 12"X18", 11"X17", Legal, Letter-R) |
| Lower Tray | 2,450 Sheets (Letter) 1,700 Sheets (Statement-R, Executive) 650 Sheets (13"X19", 12"X18", 11"X17", Legal, Letter-R) Escape Tray: 250 Sheets (Letter, Statement-R, Executive) 125 Sheets (13"X19", 12"X18", 11"X17", Legal, Letter-R) |
| Saddle Stitch Tray | Up To 25 Booklets |
| Staple Capacity | Up To 50 Sheets |
| Booklet Stapling Capacity | 16 Sheets [20 Lb. Bond (80g/M2)] [Including 1 Cover Sheet, Up To 140 Lb. Index (256g/M2)] |
| Dimensions | (Hxwxd): 44.1"X30.0"X25.8" (When The Auxiliary Tray Is Extended) |
| Description | Professional Puncher-B1/Integration Unit-C1 |
| Paper Size | Ltr, Ltr-Tab Paper |
| Paper Weight | 20 Lb. Bond To 80 Lb. Cover (75 Gsm To 216 Gsm)Die Set Patterns: Loose Leaf 3-Hole/5-Hole, Velo Bind 11-Hole, Plastic Comb 19-Hole, Twin Loop 21-Hole/32-Hole, Proclick 32-Hole, Color Coil 44-Hole |
| Plug | 120 V/15 A |
| Dimensions | (H X W X D): 40.9" X 22.0" X 31.2"* |
| Description | Puncher Unit-Bs1/Puncher Unit-Bt1 (Option For Finisher-Am1/Saddle Finisher-Am2) |
| Paper Size | 2-Hole: Letter-R, Custom Size (182 X 182 Mm To 297 X 432 Mm) 3-Hole (Bs1 Only): 11" X 17", Letter, Executive-R, Custom Size (240 X 182 Mm To 297 X 432 Mm) 4-Hole (Bt1 Only): 11" X 17", Letter, Executive-R, Custom Size (257 X 182 Mm To 297 X 432 Mm) |
| Paper Weight | 14 Lb. Bond To 110 Lb. Index (52 Gsm To 200 Gsm) |
| Description | External 2/3-Hole Puncher-C1 (Option For Staple Finisher-T1/Booklet Finisher-T1) |
| Paper Size | 11" X 17", Legal, Letter, Letter-R |
| Paper Weight | 14 Lb. Bond To 140 Lb. Index (52 To 256g/M2) |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Bond, Letterhead, Tab, Textured, Coated |
| Punch Type | 2 Holes: (Legal, Letter-R) 3 Holes: (11" X 17", Letter) |
| Distance Between Punch Holes | 2 Holes: 2-3/4" (70mm) 3 Holes: 4-1/4" (108mm) Punch Waste Tray Capacity: Approx. 10,000 Sheets [20 Lb. Bond (80g/M2)] |
| Power Requirements | From The Main Unit |
| Dimensions | 32.5" X 4.2" X 24.2" (825mm X 107mm X 615mm) |
| Weight | 17 Lb |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Locating and Installing Your Download Cómo Localizar e Instalar su Descarga Localizando e Instalando seu Download
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
