/content/cla/en/cla-test/cla-testing/haibd4-testing
/content/cla/en/cla-test/cla-testing/support/p/Software-Applications/1259B003
imagePRESS C10000VP/C8000VP
The imagePRESS C10000VP Series features robust print speeds of up to 100 letter images per minute (imagePRESS C10000VP) and 80 letter images per minute (imagePRESS C8000VP), on all supported media weights up to 350 gsm. Delivering vibrant, stable output, high productivity and reliability, the Series is designed for demanding production environments at commercial printers, in-plants, transaction and direct mail service providers alike.
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Combining proven imagePRESS features and new technologies, the imagePRESS C10000VP/C8000VP Color Digital Production Press has been engineered to deliver production excellence for the business advantage of its users. It can help commercial printers, in-plants, production hubs, direct mail and transaction print service providers to produce a broader range of applications in shorter turnaround times.
imagePRESS C10000VP/C8000VP deliver offset-like, vibrant & stable output quality with high resolution of 2400 x 2400 dpi at print speeds of up to 100/80 letter-size images per minute in color and B&W on all supported media weights for average monthly print volume of up to 450,000/360,000 LTR images per month and maximum monthly duty cycles of up to 1.5M/1.2M LTR images.
Offset-like, vibrant & stable output quality
with high resolution of 2400 x 2400 dpi, real-time color control and adjustments, more accurate and automated calibration using new inline spectrophotometric sensors and unique Gloss optimization technology to match gloss levels of the printed image to the substrate it is printed on.
Outstanding productivity and machine uptime
with print speeds up to 100 ipm, serviceability improvements and extended key operator maintenance
Wide range of media support
from 60 gsm (uncoated) and 70 gsm (coated) up to 350 gsm, delivering high quality output even on textured media and supported specialty media including vellum, film and synthetics
Versatile in-line finishing portfolio
for white-paper-in, finished-product-out workflow. Inline finishing modules will comprise Canon and third party finishers including a new professional creasing module for high quality appearance of half folded leaflets and saddle-stitched booklets.
Streamlined workflow support and integration
powered by a choice of the latest PRISMAsync Color Print Server and Fiery-based imagePRESS Servers with new Fiery FS200 Pro System.
| Model Name | ImagePRESS C10000VP/C8000VP |
| Type | Electrophotography |
| Printing Resolution | Up To 2400 X 2400 Dpi |
| Maximum Original Size | 13" X 19.2" Minimum Paper Size 7.2" X 7.2" |
| Standard Paper Capacity | Up To 2,000 Sheets |
| Maximum Paper Capacity | Up To 10,000 Sheets |
| Paper Weight | 16 Lb Bond To 130 Lb Cover (60-350 Gsm) Auto Duplex Max Paper Weight Up To 130lb Cover (350 Gsm) Print Speed (Color & B&W) | ImagePRESS C10000VP/C8000VP LTR Up To 100ipm / Up To 80ipm 11"X17" Up To 56.2ipm / Up To 43.1ipm 12"X18" Up To 53.5ipm / Up To 40.9ipm 13"X19" Up To 51ipm / Up To 38.9ipm |
| Power Requirements | 3-Phase 208V/30A + Single Phase 208V/20A |
| Dim | 57.3" X 101.8" X 45.4" |
| Description | Single-Pass Duplex Document Feeder And Black & White/Color Scanner (DADF) |
| Scan Method | Automatic Paper Size Detection: Statement, Letter, Legal , 11" X 17" Resolution: Up To 600 X 600 Dpi |
| Scanning Speed | Simplex: 600dpi BW: 120ipm CL: 70ipm 300dpi BW: 120ipm CL: 120ipm Duplex: 600dpi BW: 120ipm CL: 70ipm 300dpi BW: 200ipm CL: 140ipm |
| Capacity | 300 Sheets (20 Lb Bond) |
| Paper Weight | 16lb Bond To 80lb Cover (60-216gsm) |
| Power Source | From Main Unit |
| Description | POD Deck-D1 (Optional) Air Assist, Air Suction |
| Paper Capacity | Up To 4,000 Sheets |
| Paper Size | 7.2" X 7.2" - 13" X 19.2" |
| Paper Weight | 16 Lb Bond To 130 Lb Cover (60-350 Gsm) |
| Power Source | 120V/15A |
| Dimensions | 43.1"X38.7"X31.2" |
| Description | Secondary POD Deck-D1 (Optional) Air Assist, Air Suction |
| Power Source | From POD Deck D1 |
| Dimensions | 43.1"X31.9"X31.2" |
| Description | POD Deck Lite-C1 Air Assist |
| Paper Capacity | Up To 3,500 Sheets |
| Dimensions | 22.4"X25.8"X27.0" |
| Description | Finisher-AN1/Saddle Finisher-AN2 (Optional) |
| Paper Size | Stapling: 11"X17", LGL, LTR-R, EXEC, LTR, Custom Size (8.3"X11" - 13" X19.2") Saddle Stitch: 11"X17", LGL, LTR-R, 12"X18", 13"X19", Custom Size (8.3" X 11" - 13 X 19.2") |
| Paper Weight | Staple Mode 16 Lb. Bond To 120 Lb. Cover (60gsm To 325gsm)Saddle Stitch Mode 16 Lb. Bond To 110 Lb. Cover (60gsm To 300gsm) |
| Top Tray | Up To 1,000 Sheets (20 Lb. Bond) |
| Lower Tray | Up To 4,000 (20 Lb. Bond) |
| Saddle Stitch Tray | 30 Booklets Or Limitless |
| Staple Positions | Corner-Stapling, Double-Stapling |
| Stapling Capacity | Up To 100 Sheets (Letter) |
| Booklet Stapling Capacity | Up To 25 Sheets Saddle-Stitched |
| Dimensions | 46.5" X 35" X 31.2" |
| Description | Puncher Unit-BS1 (Option For Finisher-AN1/Saddle Finisher-AN2) |
| Paper Size | 2-Hole: LTR-R, LGL, Custom (7.2" X 7.2" To 13" X 19.2") 3-Hole: 11"X17", LTR, Custom Size (7.2" X 7.2" To 13" X 19.2") |
| Paper Weight | 16 Lb. Bond To 110 Lb. Cover (60gsm To 300gsm) |
| Power Requirements | From Finisher |
| Description | Multifunction Professional Puncher-A1 |
| Paper Size | Punch: 11"X17", 12"X18", LTR, LGL, LTRR, STMT Crease: 11"X17", 12"X18", 13"X19.2", LGL, LTRR |
| Paper Weight | Punch/Crease Plain Paper: 75-300gsm (20lb. Bond - 110lb. Cover) Coated Paper: 120-300gsm (32lb. Bond - 110lb. Cover) |
| Punch Patterns | Die Set Patterns: Punch Die: Loose Leaf 3-Hole/5-Hole, Velo Bind 11-Hole, Plastic Comb 19-Hole, Twin Loop 21-Hole/32-Hole, Color Coil 44-Hole Crease Die |
| Power Requirements | 120V/15A |
| Dimensions | 41" X 17.5" X 31.5" |
| Description | Booklet Trimmer-D1 (Optional) |
| Margin Trimming | Fore-Edge Trim |
| Trim Amount | 0.08" To 0.78" (2mm To 20mm) |
| Trim Thickness | Up To 25 Sheets (50 Sheets Folded) |
| Waste Tray Capacity | 1,500 Sheets With 0.78" Trim(20 Lb. Bond) |
| Output Tray Capacity | 30 Booklets |
| Power Consumption | From Saddle Finisher |
| Dimensions | 40.9" X 62.1" X 30.3" |
| Description | Two-Knife Trimmer-A1 (Optional) |
| Margin Trimming | Top And Bottom Trim |
| Trim Amount | 0.08" To 0.59" (2mm To 15mm) |
| Waste Tray Capacity | 750 Sheets (Two-Sided Trimmed) |
| Dimensions | 40.9" X 21.1" X 30.3" |
| Description | Document Insertion Unit-N1 (Optional) |
| Paper Size | 11"X17", 12"X18", 13x19, LGL, LTR, LTR-R, EXE, Custom Size (7.2 X 7.2" - 13" X 19.2") |
| Paper Weight | 16lb. Bond - 110lb. Cover (60gsm - 300gsm) |
| Number Of Trays | 2 |
| Tray Capacity | Top Tray Capacity: Up To 200 Sheets X 2 Trays |
| Power Requirements | 208V/15A |
| Dimensions | 55.4" X 13.2 X 31.2" |
| Description | Paper Folding Unit-J1 (Optional) |
| Paper Weight | 16 Lb. Bond To 28 Lb. Bond (60gsm To 105gsm) |
| Fold Type | Z Fold: Letter-R, Legal, 11"×17" C/Accordion Fold: Letter-R |
| Dimensions | 46.87" X 13.25" X 31.25" |
| Description | High-Capacity Stacker-H1 (Optional) |
| Top Tray Capacity | 200 Sheets (20 Lb. Bond) |
| Paper Size | 7.2"X7.2" - 13" X 19.2" |
| Paper Weight | 16 Lb. Bond To 130 Lb. Cover (60gsm To 350gsm) Offset Stack Capacity: 6,000 Sheets (Letter) (20 Lb. Bond) Up To 2 Stackers Can Be Configured Inline, Offering 12,000 Sheets Output Capacity |
| Dimensions | 40.9" X 35.4" X 29.3" |
| Description | Perfect Binder-E1 (Optional) |
| Cutting Method | 3-Side Cut/1-Side Cut/No Cut |
| Finished Book Width | 5.4" X 7.99" To 8.5" X 11.69" |
| Cover Weight | 28 Lb. Bond To 110 Lb. Cover (90gsm To 300gsm) Body Paper Weight 16 Lb. Bond To 43 Lb. Bond (60 Gsm To 163 Gsm) |
| Book Thickness | 10 To 200 Sheets (20 Lb. Bond) (Up To 0.98") |
| Trim Range | Adjustable In .0197" (0.5mm) Increments Side: 0.26" To 1.95" Top And Bottom: 0.52" To 1.56" |
| Dimensions | 53.5" X 36.3" X 31.1" Specifications Subject To Change Without Notice. |
ABOUT CANON
PRODUCT RESOURCES
ABOUT CANON
PRODUCT RESOURCES
Ⓒ 2026
