imagePRESS 1110+
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
| Model Name | ImagePRESS 1110+ |
| Imaging System | Laser Electrostatic Transfer System |
| Printing Resolution | Up To 1200 X 1200 Dpi |
| Halftone | 256-Level Grayscale |
| Letter | Simplex: 110 Duplex/Perfect: 55 |
| Ledger | Simplex: 68 Duplex/Perfect: 34 |
| Maximum Original Size | 13" X 19.2" |
| Standard Paper Capacity | 2,000 Sheets (20 Lb. Bond) |
| Cassette | Uncoated: 14 Lb. Bond To 110 Lb. Bond Cover Coated: 24 Lb. Bond To 90 Lb. Cover |
| Duplexing | Automatic Duplex/Perfect Any Supported Stock |
| Power Requirements | 208V/30A+208V/15A |
| Dim | (H X W X D): 54.12" X 54.62" X 31.87" |
| Weight | 1,103 Lb. |
| Estimated Toner Yield | 69,000 Impressions At 6% Coverage (LTR Pgs) |
| Description | Color Image Reader-L1 (Opt.) (Includes DADF (Duplex Automatic Document Feeder) |
| Acceptable Originals | Statement To 11" X 17" Resolution: Up To 600 X 600 Dpi, 256 Gradations |
| Scanning Speed | B/W: Up To 200 Ipm (300 Dpi) Up To 120 Ipm (600 Dpi) Color: Up To 80 Ipm (300 Dpi) Up To 40 Ipm (600 Dpi)* |
| Capacity | 300 Sheets (20 Lb. Bond) |
| Paper Weights | 14 Lb. Bond To 120 Lb. Index |
| Power Source | From Main Unit |
| Dimensions | (H X W X D): 7.12" X 23.25" X 25" |
| Weight | 81.6 Lb. |
| Description | POD Deck-C1 (Std.) |
| Paper Capacity | 4,000 Sheets (1,000 X 2 + 2,000) (20 Lb. Bond) |
| Paper Sizes | 13" X 19.2" |
| Paper Weights | Uncoated: 14 Lb. Bond To 110 Lb. Bond Cover (All Trays) Coated: 24 Lb. Bond To 90 Lb. Cover (All Trays) |
| Paper Source | 120-127VAC, 60Hz, 15A |
| Dimensions | 43.12" X 29.37" X 31.25" |
| Weights | 499 Lb. |
| Description | POD Deck-C1 And Secondary POD Deck-C1 (Opt.)*** |
| Paper Source | 120-127VAC, 60Hz, 15A X (2) |
| Dimensions | 43.12" X 61.5" X 31.25" |
| Weights | 997 Lb. |
| Description | POD Deck-C1 & Sec. POD Deck-C1 (2) (Opt) *** |
| Dimensions | 43.12" X 93.62" X 31.25" |
| Weights | 1,495 Lb.〉 |
| Description | Finisher-AF1/Saddle Finisher-AF2 (Opt.) |
| Paper Weights | Finisher: 14 Lb. Bond To 110 Lb. Cover Saddle Finisher: 14 Lb. Bond To 110 Lb. Cover |
| Paper Size | Stapling: Executive, Letter-R, Letter, Legal, 11" X 17" Sheet Stacking: Up To 13" X 19.2" Saddle Finisher: Letter-R, Legal, 11" X 17", 12" X 18", 13" X 19" |
| Number Of Trays | 2/3 |
| Top Tray | Up To 3,000 Sheets (20 Lb. Bond) |
| Lower Tray | 2,000 (20 Lb. Bond) |
| Saddle Stitch Tray | 30 Booklets Or Limitless |
| Staple Positions | Corner-Stapling, Double-Stapling |
| Stapling Capacity | Up To 100 Sheets (LTR) Max. Booklet Stapling Capacity: Up To 25 Sheets Saddle-Stitched (20 Lb. Only) |
| Power Source | 120V/15A |
| Dimensions | 46.5" X 31.25" X 35.37" |
| Weight | Finisher: 287 Lb. Saddle Finisher: 396 Lb. Puncher Unit-BB1 (Option For Finisher-AF1/Saddle Finisher-AF2) High-Capacity Stacker-E1 (Opt.)♦♦ Two-Knife Trimmer-A1 (Opt.) |
| Description | Booklet Trimmer-D1 (Opt.) |
| Sheet Capacity | Waste Tray Capacity: 1,500 Sheets (With 0.78" Trim, 20 Lb. Bond) Margin Trimming: Fore-Edge Trim Trim Amount: 0.08" To 0.78" Trim Thickness: 100 Sheets Acceptable Paper Weight: 14 Lb. Bond To 110 Lb. Cover Output Tray Capacity: 30 Booklets Dimensions (H X W X D): 41" X 62" X 30.37" Weight: 335 Lb. Power Source: From Saddle FinisherPerfect Binder-C1 (Opt.) Cutting Method: Stack Rotation 3-Direction Or 1-Direction Cut Finished Book Size Width: 8" To 11.62" Length: 5.37" To 8.5" Body Paper Weight: 14 Lb. Bond To 90 Lb. Index Cover Weight: 24 Lb. Bond To 110 Lb. Cover Book Thickness: 10 To 200 Sheets Glue Warm-Up Time: 440 Seconds Trim Range: Adjustable In .0197" (0.5mm) Increments Side: 0.26" To 1.94" Top And Bottom: 0.52" To 3.11" Dimensions (H X W X D): 51.25" X 36.97" X 31.12" Weight: 674.6 Lb. Power Source: 208V/15A |
| Description | Multi-Drawer Document Insertion Unit-A1 (Opt.) |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover |
| Feeder Capacity | 4,000 Sheets (1,000 X 2 + 2,000) (20 Lb. Bond) Dimensions (H X W X D): 43.12" X 42.5" X 31.25" Weight: 554 Lb. Power Source: 120V/15AProfessional Puncher And Integration Unit-B1 (Opt.) Paper Size: Letter, Tab Supported Media Weights: 20 Lb. Bond To 80 Lb. Cover Productivity: Up To 135 Ppm (Depends On Speed Of Marking Engine) Chip Tray Capacity: 25,000 Sheets Punch Patterns: 3H, 5H, Velo Bind 11H, Plastic Comb, 19H, Twin Loop 21H/32H, ProClick 32H, Color Coil 44H Power Source: 120V/15A Dimensions (H X W X D): 41" X 22.5" X 31.25" Weight: 258.5 Lb. |
| Description | Paper Folding Unit-F1 (Opt.)♦♦♦ |
| Fold Type | Z-Fold: 11" X 17", Legal, Letter-R C/V/Accordian Fold: Letter-R Parallel Double Fold: Letter-R, Legal Supported Media Weights: 14 Lb. Bond To 28 Lb. Bond Power Source: From Finisher Dimensions (H X W X D): 46.87" X 13.25" X 31.25" Weight: 157 Lb.* System Upgrade RAM-B1 Required For 600 Dpi Color Scanning ** Combined Weight Of The POD Deck-C1 And Secondary POD Deck-C1 *** Requires Either The ImagePRESS 1135+ Or The ImagePRESS 1125+ To Connect Three (3) POD Decks. Combined Weight Of The POD Deck-C1 And Secondary POD. 〉 Deck-C1 (2) ♦ 890mm When The Extension Tray Is Pulled Out For Saddle Finisher-AF1. 1060mm When The Extension Tray Is Pulled Out For Saddle Finisher-AF2. ♦♦ Only One Additional High Capacity Stacker-E1 Attaches To The ImagePRESS 1110+. ♦♦♦ Requires Either The Finisher-AF1 Or The Saddle Finisher-AF2. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
