imageFORMULA ScanFront 400
- Scanner Main Unit
- AC Adapter
- Power Cord
- Setup DVD Rom
- Setup Guide
- Feed Roller
- User Registration Card
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Simple Scanning:
- 8.4" SVGA liquid crystal display
- Preview scanned documents
- Four USB ports
- Directly connect peripherals
- Saved and pre-configured information
- Address book
- One-touch job buttons
Distribute Business Information:
- Scan up to 30 pages per minute
- Single-pass duplex
- Directly route documents to
- PC shared folder
- FTP server
- USB memory
- Fax
- Printer
- Shared LDAP options
- Can handle plastic cards, and long or oversized documents
Protect and Manage:
- Device authorization
- Key-in & list-type login
- ScanFront Administration Tool
- Centrally manage devices connected to the network
- Upgrade software
- Restrict settings
- Troubleshoot
- LDAP over SSL (LDAPS)
Optional Software Development Kit (SDK):
- Customizations to enhance integration and branding
2. Calculations based on scanning speed and assumed daily time of use.
* The facts and product statistics about EU RoHS and WEEE were obtained from Canon Electronics Inc. as of October 2016.
** Software update for the ScanFront 400 scanner will be made available. Availability of software update is subject to change without notice.
An update to software 3.0 is required for the ScanFront 400 networked document scanner to work with Flatbed Scanner Unit 102.
| Model Name | ImageFORMULA ScanFront 400 |
| Type | Networked Document Scanner |
| Document Feeding | Automatic Or Manual |
| Document Size Width | 1.96” - 8.5” (50mm X 216mm) |
| Document Size Length | 2.12” - 14.0” (54mm X 356mm) Long Document Mode: Up To 120" (3048mm) Folio Mode: Up To 11" X 17" (280mm X 432mm) Document Weight: 14 Lb. To 57 Lb. Bond |
| Feeder Capacity | 60 Sheets (80 G/M²) |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | Contact Image Sensor |
| Light Source | LED |
| Operating Modes | Color, Grayscale, Black And White |
| Optical Resolution | Up To 600 Dpi |
| Output Resolution | 100/150/200/300/400/600 Dpi |
| Interface | USB 2.0 (X3), 10BaseT/100BaseT/1000BaseTSupported OS: Windows 64-Bit, 32-Bit |
| Dimensions | 9.06” X 12.0” X 11.1” (230mm X 305mm X 282mm) |
| Weight | 9.92 Lbs. (4.5Kg) |
| Power Consumption | 36W Or Less |
| Other Features | Automatic Page Size Detection, Background Smoothing, Background Removal, Bleed-Through Reduction, Color Dropout / Enhancement, Deskew, Double Feed Detection, Folio, Long Document Mode, Optical Character Recognition (OCR), Shadow Removal, Skip Blank Page, Text Enhancement, Text Orientation Recognition |
| Options | Exchange Roller Kit, Passport Carrier SheetBundled Software: ScanFront Administration ToolNetwork Functions: Scan-To-Email (SMTP Microsoft Exchange, Lotus Notes), Scan-To-Fax (SMTP-Via Internet Fax Service Or Via Direct Transmissions, Microsoft Exchange, Lotus Notes), Scan-To- Folder, Scan-To-Print, Scan-To-FTP, Scan-To-USB Drive |
Scanning Speeds
| Black And White | (Simplex / Duplex):1 45 Ppm / 90 Ipm |
| Grayscale | (Simplex / Duplex):1 45 Ppm / 90 Ipm |
| Color 24 Bit | (Simplex / Duplex):1 45 Ppm / 90 IpmOperation Panel: 10.1" WSVGA TFT Liquid Crystal Display With Touch-Panel |
Exchange Roller Kit
Easy-to-replace kit typically consists of pickup, separation, and feed rollers that help ensure reliable document feeding and promote easy maintenance and upkeep of the scanning device.
Reusable protective sheet to scan passports.
A4 Carrier Sheet
Reusable protective sheet for scanning documents with irregular shape.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
