imageFORMULA P-215II
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Wide Variety of Applications:
- Designed to improve personal productivity and efficiency virtually anywhere
- Home offices, classrooms, anywhere in between
- Classrooms
- Perfect for stationary users or "road warriors"
- Healthcare, Legal, Financial, and other areas
- Portable and mobile
Compact and Convenient:
- 1.6" x 11.0" x 3.7" (with trays closed)
- Fits easily into briefcase
- Approx. 2.2 lbs.
- Built-in card reader and Automatic Document Feeder (ADF)
Simple Use:
- "Plug-and-Scan" capability
- Updated CaptureOnTouch and CaptureOnTouch Lite Software
- Immediate scanning without installing drivers or imaging applications
- Configure routine scan jobs for one-touch access
Maximum Image Quality:
- Includes features to help improve legibility of hard-to-scan documents
- Trims, straightens, and removes shadows from scanned images
- Scans mixed batches of documents and photographs
- Automatically adjusts resolution to improve image quality
Productive and Flexible:
- One-pass duplex scanning
- Up to 20 sheet ADF
- Up to 15 pages per minute
- Maximum scanning speed via single USB cable connection
- Integrated card reader
- Plastic ID cards Embossed cards
Compatible and Comprehensive:
- Windows ISIS / TWAIN drivers, MAC TWAIN driver
- Easy integration with capture and content management systems
- Device sharing between Windows and Mac users
- CaptureOnTouch
- Scan directly to cloud for improved collaboration and compatibility*
- Microsoft SharePoint
- Evernote
- Google Docs
- Multiple file output formats
- Including PDF/A, PPTX
* Subscription to a third-party cloud service required. Subject to third-party cloud service providers terms and conditions.
Environment In Mind:
- Meets ENERGY STAR guidelines
- Eu RoHS and EU WEEE compliant
| Model Name | ImageFORMULA P-215II Personal Document Scanner |
| Type | Personal Mobile Scanner |
| Document Feeding | Automatic Or Manual Document Size: Width: 2.0" - 8.5" Length: 2.8" - 14" Long Document Mode: Up To 39.4" Document Weight: 14-34 Lb. Bond |
| Feeder Capacity | Up To 20 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | Contact Image Sensor (CMOS) |
| Light Source | RGB LED |
| Operating Modes | Color, Grayscale, Black And White |
| Drop Out Color | Red, Green, Blue |
| Optical Resolution | 600 Dpi |
| Output Resolution | 150 / 200 / 300 / 400 / 600 Dpi |
| Interface | Hi-Speed USB 2.0, USB 3.0 |
| Scanner Drivers | Windows XP Service Pack 3 Or Later, Windows XP X64 Edition Service Pack 2 Or Later, Windows Vista Service Pack 2 Or Later (32-Bit/64-Bit), Windows 7 Service Pack 1 Or Later (32-Bit/64-Bit), Windows 8/8.1 (32-Bit/64-Bit), Mac OS 10.7.5, Mac OS 10.8.5, Mac OS 10.9.1 |
| Dimensions | 1.6" X 11.2" X 3.7" (With Trays Closed) |
| Weight | 2.2 Lb. |
| Power Consumption | 2.5W - 7W Suggested Daily Volume: 500 Scans** |
| Other Features | Auto Color Detection, Auto Page Size Detection, Auto Resolution Setting, Background Smoothing, Character Emphasis, Color Dropout/Red Color Enhance, Deskew, Double-Feed Detection, Duplex, Image Rotation, Long Document Mode, Moiré Reduction, MultiStream, Photograph Corrections, Pre-Scan, Prevent Bleed-Through/Remove Background, Shadow Cropping/Removal, Simplex, Skip Blank Page, Text Enhancement, Text Orientation Recognition, Three-Dimensional Color Correction, Trimming, User Preferences Bundled Windows Software: ISIS/TWAIN Drivers, Canon CaptureOnTouch And CaptureOnTouch Lite (Built-In), Evernote, NewSoft Presto! Bizcard, Nuance PaperPort Bundled Mac Software: TWAIN Driver, Canon CaptureOnTouch And CaptureOnTouch Lite (Built-In), Evernote, NewSoft Presto! Bizcard, NewSoft Presto! PageManager |
| Options | Separation Pad, Feed Roller, USB Cable, Carrying Case, AC Adapter*Examples Based On Typical Settings, Rated In Pages/Images Per Minute With Letter-Sized Documents At 200 Dpi Portrait Feeding Directions. Actual Processing Speeds May Vary Based On PC Performance And Application. **Calculations Based On Scanning Speed And Typical Daily Time Of Use. |
Scanning Speeds
| Black And White | (Simplex / Duplex):* 15 Ppm / 30 Ipm |
| Grayscale | (Simplex / Duplex):* 15 Ppm / 30 Ipm |
| Color 24 Bit | (Simplex / Duplex):* 10 Ppm / 20 Ipm |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
