imageFORMULA P-215
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Compact and Convenient:
1.6" H x 11.2" W x 3.7" D |
- Fits easily into a briefcase or laptop bag |
2.2 lb. |
- Portable and mobile |
Built-in card reader and Automatic Document Feeder (ADF) |
Simple Use:
"Plug-and-Scan" capability |
- CaptureOnTouch Lite launches upon connection |
CaptureOnTouch |
- For easy scanner use |
- Pre-configure repetitive scan jobs |
Maximum scanning speed via single USB cable connection |
Maximum Image Quality:
Character Emphasis |
- Improves the legibility of hard-to-capture documents |
Auto Resolution Setting |
Shadow Cropping |
Background Smoothing |
Productive and Flexible:
One-pass duplex scanning |
- 20 sheet ADF |
- Up to 15 pages per minute / 30 images per minute |
Integrated card reader |
Compatible and Comprehensive:
Windows ISIS / TWAIN drivers, Mac TWAIN driver |
- Industry standard interfaces for connecting software applications and scanners |
- Easy integration with capture and content management systems |
- Device sharing between Windows and Mac users |
Canon CaptureOnTouch (Windows and Mac) |
- Scan directly to the cloud for improved collaboration and compatibility |
Full Auto Mode |
Environment In Mind:
| Model Name | ImageFORMULA P-215 Scan-Tini Personal Document Scanner |
| Type | Personal Mobile Scanner |
| Document Feeding | Document Size: Width: 2.0" - 8.5" Length: 2.8" - 14" Long Document Mode: 39.4" Document Weight: 14-34 Lb. Bond |
| Feeder Capacity | 20 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | Contact Image Sensor (CMOS) |
| Light Source | RGB LED |
| Operating Modes | Simplex, Duplex, Color, Grayscale, Black And White, Error Difusion, Advanced Text Enhancement II |
| Drop Out Color | Red, Green, Blue |
| Optical Resolution | 600 Dpi |
| Output Resolution | 150 / 200 / 300 / 400 / 600 Dpi |
| Interface | Hi-Speed USB 2.0, USB 3.0 |
| Scanner Drivers | Windows ISIS / TWAIN, Mac TWAIN |
| Dimensions | 1.6" X 11.2" X 3.7" (With Trays Closed) |
| Weight | 2.2 Lb. |
| Power Consumption | 2.5W - 7W Suggested Daily Volume:*** 500 Scans |
| Other Features | Auto Color Detection, Auto Page Size Detection, Auto Resolution Setting, Background Smoothing, Character Emphasis, Color Dropout/Red Color Enhance, Deskew, Pre-Scan, Prevent Bleed Through/Remove Background, Shadow Cropping, Skip Blank Page, Text Orientation Recognition, User PreferencesBundled Software: ISIS/TWAIN Drivers, Canon CaptureOnTOuch And CaptureOnTOuch Lite (Built-In), Nuance PaperPort, NewSoft Presto! BizCard, EvernoteBundled Mac Software: TWAIN Driver, Canon CaptureOnTOuch And CaptureOnTouch Lite (Built-In), NewSoft Presto! PageManager, NewSoft Presto! BizCard, EvernoteSupported OS: Windows XP Professional (32-Bit/64-Bit), Windows XP Home (32-Bit), Windows Vista® (32-Bit/64-Bit), Windows 7 (32-Bit/64-Bit), Mac OS 10.5-10.7 |
| Options | Separation Pad, Feed Roller, USB Cable, Carrying Case, AC Adapter* Examples Based On Typical Settings, Rated In Pages/Images Per Minute With Letter-Sized Documents, Prtrait Feeding Direction, Up To 200 Dpi, With One USB Cable And AC Adapter, One USB 3.0 Cable, Or Two USB 2.0 Cables. Actual Processing Speeds May Vary Based On PC Performance And Application Software. ** Power Consumption Varies Depending On The USB / AC Adapter Configurations Used. *** Calculations Based On Scanning Speed And Typical Daily Time Of Usage. |
Scanning Speeds
| Black And White | (Simplex / Duplex):* 15 Ppm / 30 Ipm |
| Grayscale | (Simplex / Duplex):* 15 Ppm / 30 Ipm |
| Color 24 Bit | (Simplex / Duplex):* 10 Ppm / 20 Ipm |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
2.2 lb.
CaptureOnTouch
Character Emphasis
Shadow Cropping
Full Auto Mode
PDF/A, PPTX, other file formats output
Meets ENERGY STAR guidelines
EU RoHS Compliant
EU WEEE Compliant
Canon Generation Green Program
