imageFORMULA P-208II
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Wide Range of Uses:
- Stationary users and "road warriors":
- Can be used at home, in the office, or on the go
- Professional services, financial services, healthcare, and more
- Can scan various items:
- Bills and receipts
- Business cards
- Photographs
- Contracts
- Reports
- Letters
- Plastic ID cards or driver licenses
Convenient and Portable:
- Slim, lightweight, and flexible
- Fits easily into a briefcase or bag
- Powered via a single USB cable connection
- Helps reduce cable clutter
Easy to Use:
- "Plug-and-Scan" capability
- Immediate scanning without installing drivers or imaging applications
- CaptureOnTouch software
- One-touch access to repetitive tasks
- Scan to third-party cloud applications
- Evernote™, Microsoft® SharePoint®, Google Drive™, SugarSync, OneDrive, and Dropbox
- Windows ISIS / TWAIN drivers, Mac TWAIN driver
- Easy integration with capture and content management systems
Flexible Operation:
- Scans up to 8 pages per minute in B&W, grayscale, and color - both sides of an item in a single pass
- Can handle a variety of document types
- Thick or thin documents
- Plastic or embossed cards
- Can detect double-feed occurences
- Optional WU10 Wireless Adapter and Battery Pack*
- Works wirelessly in Windows and Mac environments
- Works with iPad®, iPhone®, and Android™ devices via downloadable Canon CaptureOnTouch Mobile app
Robust Features:
- Improve legibility of text characters
- Auto Resolution setting for scanning mixed batches of text documents and photographs
- Mode for the optimization of photographs
- Optical Character Recognition (OCR) to help create searchable and editable information
Environment In Mind:
- Meets ENERGY STAR guidelines
- Eu RoHS and EU WEEE compliant
- ErP Lot 6 directive for energy consumption compliant
| Model Name | ImageFORMULA P-208II Personal Document Scanner |
| Type | Personal Mobile Scanner |
| Document Feeding | Automatic Or Manual Document Weight: 14 - 34 Lb. Bond |
| Document Size Width | 2.0" - 8.5" |
| Document Size Length | 2.8" - 14" |
| Feeder Capacity | 10 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | Contact Image Sensor (CMOS) |
| Light Source | RGB LED |
| Operating Modes | Color, Grayscale, Black & White |
| Optical Resolution | 600 Dpi |
| Output Resolution | 150 / 200 / 300 / 400 / 600 Dpi |
| Interface | Hi-Speed USB 2.0 |
| Dimensions | 1.5" X 12.3" X 2.2" (With Trays Closed) |
| Weight | 1.3 Lb. |
| Power Consumption | 2.5W Max. (Energy Saving Mode: 1.5W) Suggested Daily Volume:*** 100 Scans |
| Other Features | Auto Color Detection, Auto Page Size Detection, Auto Resolution Setting, Background Smoothing, Deskew, Edge Emphasis, Moiré Reduction, Photograph Corrections, Pre-Scan, Prevent Bleed-Through/Remove Background, Shadow Cropping, Skip Blank Page, Text Enhancement, Text Orientation Recognition, Three-Dimensional Color Correction, Double-Feed Detection, User PreferencesBundled Windows Software: ISIS/TWAIN Drivers, Canon CaptureOnTouch And CaptureOnTouch Lite (Built-In), NewSoft Presto! BizCard Bundled Mac Software: TWAIN Driver, Canon CaptureOnTouch And CaptureOnTouch Lite (Built-In), NewSoft Presto! BizCard Supported OS: Windows XP Professional (32-Bit/64-Bit), Windows XP Home (32-Bit), Windows, Vista® (32-Bit/64-Bit), Windows 7 (32-Bit/64-Bit), Mac OS 10.5 - 10.7 * Examples Based On Typical Settings, Rated In Pages/Images Per Minute With Letter-Sized Documents, Portrait-Feeding Direction, Up To 200 Dpi, With One USB Cable And AC Adapter; One USB 3.0cable; Or, Two USB 2.0 Cables. Actual Processing Speeds May Vary Based On PC Performance And Application Software. *** Calculations Based On Scanning Speed And Assumed Daily Time Of Use. |
Scanning Speeds
| Black And White | (Simplex / Duplex):* 8 Ppm / 16 Ipm |
| Grayscale | (Simplex / Duplex):* 8 Ppm / 16 Ipm |
| Color 24 Bit | (Simplex / Duplex):* 8 Ppm / 16 Ipm |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
