imageFORMULA DR-M160II
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Exceptional Performance:
- Scans up to 60 pages per minute
- Single-pass duplex scanning
- Both sides of a sheet in one pass
- Up to 60 sheet ADF
Usable Design:
- Dimensions (H x W x D): 9.09" x 11.02" x 9.76" (with trays closed)
- Weight: 7.05 lb.
- LED control panel
- One-touch access to pre-configured customizable scan tasks
- Easy interior access for cleaning and maintenance
Reliable Feeding:
- Double-feed & non-feed prevention
- Weight 7.05 lb.
- LED control panel
- Can handle embossed plastic cards
- Can handle thick or thin sheets
- Can handle long or oversized documents
High Quality Scanning:
- Character Emphasis improves legibility
- Shadow Cropping
- Background Smoothing
- Auto Resolution setting for scanning mixed batches of text documents and photographs
- Optical Character Recognition (OCR) to help create searchable and editable information
Bundled Software Solutions:
- Windows ISIS / TWAIN and Mac TWAIN drivers
- Industry standard interfaces for connecting software applications and scanners
- Eases integration with third-party capture or content management systems
- Device sharing between Windows and Mac users
- Canon CaptureOnTouch (Windows or Mac)
- Pre-configure repetitive scan jobs
- One-touch scanning
- Intuitive user interface
- Full Auto mode
- Automatically adjusts multiple settings with a single click
- Scan to cloud applications
- Microsoft SharePoint
- Evernote
- Google Docs
- PDF/A format output
- Canon CapturePerfect 3.1 (Windows)
- Kofax Virtual ReScan (VRS) Elite (Windows)
- Nuance eCopy PDF Office Pro (Windows)
- PDF encryption and password protection
Environment In Mind:
- Meets ENERGY STAR guidelines
- Eu RoHS compliant
- WEEE compliant
| Model Name | ImageFORMULA DR-M160II |
| Type | Office Document Scanner |
| Document Feeding | Automatic Or Manual |
| Document Size Width | 2.0" - 8.5" |
| Document Size Length | 2.1" - 14.0" Long Document Mode: Up To 118.1" Folio Mode: Up To 11" X 17" Document Weight: 7 - 68 Lb. Bond |
| Feeder Capacity | Up To 60 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | One-Line Contact Image Sensor (CMOS) |
| Light Source | RGB LED |
| Operating Modes | Color, Grayscale, Black And White |
| Drop Out Color | RGB |
| Optical Resolution | 600 Dpi |
| Output Resolution | 150/200/240/300/400/600 Dpi |
| Interface | Hi-Speed USB 2.0 Supported OS: Windows XP Professional (32-Bit/64-Bit) Windows XP Home (32-Bit), Windows Vista® (32-Bit/64-Bit), Windows 7 (32-Bit/64-Bit), Mac OS 10.7.5, Mac OS 10.8.5, Mac OS 10.9.1 |
| Dimensions | 9.09" X 11.02" X 9.76" (With Trays Closed) |
| Weight | 7.05 Lb. |
| Power Consumption | 27 W Max. (Energy Saving Mode: 1.8 W) |
| Other Features | Auto Color Detection, Auto Page Size Detection, Auto Resolution Setting, Background Smoothing, Character Emphasis, Color Dropout/Enhance Color, Deskew, Double-Feed Release, Feeding Retry, Folio Mode, Image Rotation, Long Document Mode, MultiStream, Pre-Scan, Prevent Bleed-Through/ Remove Background, Separation Retry, Shadow Cropping, Skip Blank Page, Text Enhancement, Text Orientation Recognition, Ultrasonic Double-Feed Detection, User PreferencesBundled Software: ISIS/TWAIN Drivers; Canon CaptureOnTouch; CapturePerfect; Nuance ECopyPDF Pro Office; Kofax VRS With AIPEBundled Mac Software: TWAIN Driver, Canon CaptureOnTouch |
| Options | 2D Code Module, Barcode Module, Exchange Roller Kit, Flatbed Scanner Unit 101, Flatbed Scanner Unit 201* Examples Based On Typical Settings, Rated In Pages/Images Per Minute With Letter-Sized Documents At 200 Dpi Portrait-Feeding Directions. Actual Processing Speeds May Vary Based On PC Performance And Application. |
Scanning Speeds
| Black And White | (Simplex / Duplex):* Up To 60 Ppm / Up To 120 Ipm |
| Grayscale | (Simplex / Duplex):* Up To 60 Ppm / Up To 120 Ipm |
| Color 24 Bit | (Simplex / Duplex):* Up To 60 Ppm / Up To 120 Ipm |
Flatbed Scanner Unit 201 (Manual)
WA10 Network Adapter
Create ethernet and Wi-Fi network connectivity with the WA10 and a compatible imageFORMULA document scanner.
For more information, click here.
Flatbed Scanner Unit 102
NA10 Network Adapter
Create ethernet network connectivity with the NA10 and a compatible imageFORMULA document scanner.
Barcode Module
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
