imageFORMULA DR-M160
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Exceptional Performance:
- Scans up to 60 pages per minute
- Single-pass duplex scanning
- 60 sheet ADF
Usable Design:
- Simple hardware and features designed with the user in mind
- Dimensions (H x W x D) 9.09" x 11.02" x 9.76" (with trays closed)
- Weight 7.05 lb.
- LED Control Panel
Very Reliable Feeding:
- Double-Feed & Non-feed prevention
- Large roller: Increases feeding traction
- Support roller: Stabilizes documents at the feeder
- Document Stopper: Aligns document edges
- Floating Retard Roller: Maintains constant power for documents being fed
- Plastic card scanning capable
- Thin Paper Mode
High Quality Scanning:
- Increased input gradation level
- More accurate image capture
- Shadow Cropping
- Background Smoothing
- Auto Resolution setting
Bundled Software Solutions:
- Canon CaptureOnTouch
- Scan to Microsoft SharePoint
- Full Auto Mode
- PDF/A format output
- Canon CapturePerfect 3.1
- Auto Color Detection
- PPTX format output
- Kofax VRS
- Nuance eCopy PDF Office Pro
Environment In Mind:
- Meets ENERGY STAR guidelines
- RoHS Compliant
- WEEE Compliant
| Model Name | ImageFORMULA DR-M160 |
| Type | Office Scanner |
| Document Feeding | Automatic Or Manual |
| Document Size Width | 2.0" - 8.5" |
| Document Size Length | 2.12" - 14.0" Long Doc. Mode: Up To 118.11" Document Weight: 7-68 Lb. Bond |
| Feeder Capacity | 60 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | One-Line Contact Image Sensor (CMOS) |
| Light Source | RGB LED |
| Operating Modes | Grayscale, B&W, Color, Error Diffusion, ATE (Multiple Modes) |
| Drop Out Color | Red, Green, Blue |
| Optical Resolution | 600 Dpi |
| Output Resolution | 150 / 200 / 300 / 400 / 600 Dpi |
| Interface | Hi-Speed USB 2.0 |
| Scanner Drivers | ISIS/TWAIN |
| Dimensions | 9.09" X 11.02" X 9.76" (With Trays Closed) |
| Weight | 7.05 Lb. |
| Power Consumption | 27W Max. (Energy Saving Mode: 1.8W) Suggested Daily Volume**: 7,000 Scans |
| Other Features | Auto Page Size Detection, Auto Resolution Setting, Background Smoothing, Barcode Module, Deskew, Double-Feed Release, Feeding Retry, Folio Mode, Long Document Mode, MultiStream, Pre-Scan, Prevent Bleed-Through/Remove Background, Separation Retry, Shadow Cropping, Skip Blank Page, Text Orientation Recognition, Ultrasonic Double-Feed Detection Bundled Software: ISIS/TWAIN Drivers, Canon CaptureOnTouch, Canon CapturePerfect, Nuance ECopy PDF Pro Office, Kofax VRS Supported OS: Windows XP Professional (32-Bit/64-Bit), Windows XP Home (32-Bit), Windows Vista® (32-Bit/64-Bit), Windows 7 (32-Bit/64-Bit) |
| Options | Flatbed Scanner Unit 101, Exchange Roller Kit* Examples Based On Typical Settings, Rated In Pages/Images Per Minute With Letter-Sized Documents, Portrait-Feeding Direction, Up To 200 Dpi. ** Calculations Based On Scanning Speed And Typical Daily Time Of Usage. |
Scanning Speeds
| Black And White | (Simplex/Duplex):* Up To 60 Ppm / Up To 120 Ipm |
| Grayscale | (Simplex/Duplex):* Up To 60 Ppm / Up To 120 Ipm |
| Color 24 Bit | (Simplex/Duplex):* Up To 60 Ppm / Up To 120 Ipm |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
