imageFORMULA DR-M1060
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Reliable and Versatile:
- "U-turn" path feeding
- Typical document scanning
- Straight path feeding
- Thick, thin, and/or long documents
- Plastic and embossed cards
- Reliable pickup feeding for ledger sized documents
- 11" by 17" documents
- Long Document Mode
- Documents up to 118"
- Paper feed error detection sensors
- For consistent paper feeding
- ISIS & TWAIN drivers
- Easy integration with third‐party software
Compact and User-Friendly:
- Dimensions (H x W x D): 4.7" x 16.7" x 9.7" (with trays closed)
- Minimalistic design helps maximize desk space
- No lengthy feed tray needed
- No eject tray needed
- User-friendly control panel
- Selectable scan tasks
- Batch scanning ability
Productive and Efficient:
- Scans up to 60 pages/120 images per minute in color, B&W, and grayscale*
- Suggested daily volume
- Approximately 7,500 scans
- MultiStream™
- For saving and sending files in different formats
Precise Image Capture:
- Auto Color Detection
- Text Enhancement capability improves legibility
- Folio mode for scanning oversized documents
- Shadow Cropping
- Deskew / straighten scanned images
- Auto Resolution setting for scanning mixed batches of text documents and photographs
Bundled Software:
- Canon CaptureOnTouch
- Scan to Microsoft SharePoint
- Full Auto Mode
- PDF/A format output
- PPTX format output
- Canon CapturePerfect
- Kofax VRS
- Nuance eCopy PDF Pro Office
Environment In Mind:
- Meets ENERGY STAR guidelines
- Eu RoHS and EU WEEE compliant
- ErP Lot 6 directive for energy consumption compliant
| Model Name | ImageFORMULA DR-M1060 |
| Type | Office Document Scanner |
| Document Feeding | Automatic Or ManualU-Turn Path Document Size: Width: 2.0" - 11.8" Length: 2.75" - 17.0"Straight Path Document Size: Width: 2.0" - 11.8" Length: 2.75" - 17.0"Long Document Mode: Up To 118.1"Folio Mode: Up To 11" X 17"Document Weight:U-Turn Path: 7 - 32 Lb. Bond Straight Path: 7 - 68 Lb. Bond |
| Feeder Capacity | A4/LTR And Smaller: Up To 60 Sheets Larger Than A4/LTR: Up To 25 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | One-Line Contact Image Sensor (CMOS) |
| Light Source | RGB LED |
| Operating Modes | Color, Grayscale, Black And White |
| Drop Out Color | RGB |
| Optical Resolution | 600 Dpi |
| Output Resolution | 100/150/200/240/300/400/600 Dpi |
| Interface | Hi-Speed USB 2.0 |
| Scanner Drivers | ISIS®/TWAINSupported OS: Windows® XP Service Pack 3 Or Later, Windows XP X64 Edition Service Pack 2 Or Later, Windows Vista® Service Pack 2 Or Later (32-Bit/64-Bit), Windows 7 Service Pack 1 Or Later (32-Bit/64-Bit), Windows 8/8.1 (32-Bit/64-Bit), Windows Server 2008/2012 R2 |
| Dimensions | 4.7" X 16.7" X 9.7" (With Trays Closed) |
| Weight | 11.0 Lb. |
| Power Consumption | 32.5 W Max. (Energy Saving Mode: 2.5 W) |
| Other Features | Auto Color Detection, Auto Page Size Detection, Auto Resolution Setting, Background Smoothing, Character Emphasis, Color Dropout/Enhance Color, Deskew, Double-Feed Release, Duplex, Edge Emphasis, Folio Mode, Image Rotation, Long Document Mode, MultiStream, Pre-Scan, Prevent Bleed-Through/Remove Background, Shadow Cropping, Skip Blank Page, Text Enhancement, Text Orientation Recognition, Ultrasonic Double-Feed Detection, User PreferencesBundled Software: ISIS®/TWAIN Drivers; Canon CaptureOnTouch; CapturePerfect; Nuance ECopy PDF Pro Office; Kofax VRS With AIPE |
| Options | Flatbed Scanner Unit 101, Flatbed Scanner Unit 201, Barcode Module, 2D Code Module, Exchange Roller Kit* Examples Based On Typical Settings, Rated In Pages/Images Per Minute With Letter-Sized Documents At 200 Dpi Portrait-Feeding Directions. Actual Processing Speeds May Vary Based On PC Performance And Application. Δ The Facts And Product Statistics About EU RoHS And WEEE Were Obtained From Canon Electronics Inc. As Of 2014. ΔΔ Calculations Based On Scanning Speed And Assumed Daily Time Of Use. |
Scanning Speeds
| Black And White | (Simplex/Duplex): Up To 60 Ppm / Up To 120 Ipm |
| Grayscale | (Simplex/Duplex): Up To 60 Ppm / Up To 120 Ipm |
| Color 24 Bit | (Simplex/Duplex): Up To 60 Ppm / Up To 120 Ipm |
Exchange Roller Kit
Easy-to-replace kit typically consists of pickup, separation, and feed rollers that help ensure reliable document feeding and promote easy maintenance and upkeep of the scanning device.
Flatbed Scanner Unit 201 (Manual)
WA10 Network Adapter
Create ethernet and Wi-Fi network connectivity with the WA10 and a compatible imageFORMULA document scanner.
For more information, click here.
Flatbed Scanner Unit 102
NA10 Network Adapter
Create ethernet network connectivity with the NA10 and a compatible imageFORMULA document scanner.
2D Barcode Module
Barcode Module
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
