imageFORMULA DR-G2090
- Main DR-G2090 Unit
- USB Cable
- Power Cable
- Setup DVD
- Cleaning Cloth
- Reference Guide
- Packing Materials
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageFORMULA DR-G2090 is registered EPEAT Gold.
Wide Variety of Applications
- Mission-critical scanning
- Centralized production scanning
- Process high volume of documents
- Ideal for back-file conversion
High Performance
- Scans up to 90 pages per minute
- Single-pass duplex scanning
- Scans both sides of a document at the same time
- 300 sheet Automatic Document Feeder
- Dedicated, onboard image processing chip
- Helps to maintain rated speeds
- USB 3.1
Reliable and Flexible
- Can handle a variety of document types
- Business card to ledger sized
- Long documents
- Thick or thin documents
- Double-Feed detection / prevention
- Ultrasonic detection
- By length detection
- Rapid recovery system
- Staple detection
- Durable, solid-body design
- Heavy-duty feed and eject trays
Efficient, Smooth Operation
- Control panel
- User-programmable job buttons
- Select scanner settings
- Motorized paper-feed tray
- Adjusts to the height of the batch
- Flexible paper feed and output guides
Environment In Mind
- Meets ENERGY STAR guidelines
- EU RoHS Compliant
- EU WEEE Compliant
- EPEAT Gold rated
** Calculations based on scanning speed and assumed daily time of use.
| Model Name | ImageFORMULA DR-G2090 |
| Type | Production Document Scanner |
| Document Feeding | Automatic Or Manual |
| Document Size Width | 50.8 - 304.8 Mm (2" - 12") |
| Document Size Length | 71.12 - 431.8 Mm (2.8" - 17") Long Document Mode: Up To 3000 Mm (118.1") |
| Thickness Automatic Feeding | 14 - 56 Lb. Bond |
| Thickness Manual Feeding | 14 - 56 Lb. Bond |
| Feeder Capacity | 300 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | Three-Line Contact Image Sensor (CIS) |
| Light Source | RGB LED |
| Operating Modes | Color, Grayscale, Black And White Color Dropout: RGB And Custom |
| Optical Resolution | 600 Dpi |
| Output Resolution | 100/150/200/300/400/600/Custom Dpi |
| Interface | Hi-Speed USB 3.1 |
| Scanner Drivers | ISIS/TWAIN Supported Operating System: Windows 7 SP1 Or Later (32 Bit/64bit), Windows 8.1 (32bit/64bit), Windows 10 (34bit/64 Bit), Windows Server 2008 R2, Windows Server 2012 R2, Windows Server 2016 Bundled Software: Canon CaptureOnTouch, Kofax VRS Professional |
| Dimensions | 12.4” X 18.9” X 22.4” (Trays Closed) |
| Weight | 55.1 Lb. |
| Power Consumption | 66.5W Or Less (Energy Saving Mode: 3.5W) Daily Volume: 30,000** |
| Other Features | Auto Color Detection, Auto Page Size Detection, Active Thresholding, Batch Separation, Character Emphasis, Count Only Mode, Custom Color Dropout/ Enhance Color, Deskew, Double-Feed Detection, Edge Emphasis, Folio Scan, Image Rotation, Moiré Reduction, MultiStream, Paper Feed Tray (Adjustable), Pre-Scan, Prevent Bleed-Through/Remove Background, Punch Hole Removal, Rapid Recovery System, Skip Blank Page, Staple Detection, Text Enhancement, Text Orientation Recognition, Three-Dimensional Color Correction, User Preferences, Verify Scan |
| Options | Flatbed Scanner Unit 102 And 201 |
Scanning Speeds
| Black And White High Speed | (Simplex / Duplex):* Up To 90 Ppm / Up To 180 Ipm |
| Color High Speed | (Simplex / Duplex):* Up To 90 Ppm / Up To 180 Ipm |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
