imageFORMULA DR-G1130
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Wide Variety of Applications:
- Mission-critical scanning
- Centralized production scanning
- Process large amounts of documents
High Performance:
- Scans up to 130 pages per minute
- Single-pass duplex scanning
- Scans both sides of a document at the same time
- 500 sheet Automatic Document Feeder
- Dedicated, onboard image processing chip
Reliable and Flexible:
- Can handle a variety of document types:
- Business card to ledger sized
- Long documents
- Thick or thin documents
- Double-Feed detection / prevention
- Ultrasonic detection
- By length detection
- Rapid recovery system
- Staple detection
- Durable, solid-body design
- Heavy-duty feed and eject trays
Efficient, Smooth Operation:
- Control Panel
- User-programmable job buttons
- Select scanner settings
- Motorized paper-feed tray
- Adjusts to the height of the batch
- Flexible paper feed and output guides
Environment In Mind:
- Meets ENERGY STAR guidelines
- EU RoHS Compliant
- EU WEEE Compliant
- EPEAT Compliant
- Canon Generation Green Program
| Model Name | ImageFORMULA DR-G1130 Production Document Scanner |
| Type | Production Scanner | ||
| Document Feeding | Automatic, Manual, Continuous Manual Long Document Mode: Up To 118.1" Document Weight: 5-56 Lb. Bond (Automatic Feeding), 5-64 Lb. Bond (Manual Feeding) |
| Document Size Width | 2" - 12" | ||
| Document Size Length | 2.8" - 17" | ||
| Feeder Capacity | Up To 500 Sheets | ||
| Grayscale | 8-Bit | ||
| Color | 24-Bit | ||
| Scanning Element | Three-Line Contact Image Sensor (CMOS) | ||
| Light Source | RGB LED | ||
| Operating Modes | Color, Grayscale, Black & White | ||
| Optical Resolution | 600 Dpi | ||
| Output Resolution | 150 / 200 / 240 / 300 / 400 / 600 Dpi | ||
| Interface | Hi-Speed USB 2.0 | ||
| Dimensions | 18.9" X 21.1" X 12.4" (Trays Closed) | ||
| Weight | 50 Lb. | ||
| Power Consumption | 120V - 95W Or Less (Energy Saving Mode: 1.6W) 230V - 94.3W Or Less ( Energy Saving Mode: 1.7W)
| Other Features | Auto Color Detection, Auto Page Size Detection, Background Smoothing, Batch Separation, Character Emphasis, Count Only Mode, Custom Color Dropout / Enhance Color, Deskew, Double-Feed Detection, Edge Emphasis, Folio Scan, Image Rotation, Moiré Reduction, MultiStream, Paper Feed Tray (Three Positions), Pre-Scan, Prevent Bleed-Through/Remove Background, Punch Hole Removal, Rapid Recovery System, Skip Blank Page, Staple Detection, Text Enhancement, Text Orientation Recognition, Three-Dimensional Color Correction, User Preferences, Verify ScanBundled Software: ISIS/TWAIN Drivers, Canon CapturePerfect, Kofax VRS Supported OS: Windows XP Service Pack 3 Or Later, Windows XP X64 Edition Service Pack 2 Or Later, Windows Vista Service Pack 2 Or Later (32bit/64bit), Windows 7 Service Pack 1 Or Later (32bit/64bit), Windows 8 (32bit/64bit)
Scanning Speeds
| Black And White | (Simplex/Duplex)*: Up To 130 Ppm / Up To 200 Ipm |
| Grayscale | (Simplex/Duplex)*: Up To 130 Ppm / Up To 200 Ipm |
| Color 24 Bit | (Simplex/Duplex)*: Up To 130 Ppm / Up To 200 Ipm |
Exchange Roller Kit
Easy-to-replace kit typically consists of pickup, separation, and feed rollers that help ensure reliable document feeding and promote easy maintenance and upkeep of the scanning device.
Flatbed Scanner Unit 201 (Manual)
Flatbed Scanner Unit 102
Barcode Module
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
