imageFORMULA DR-C240
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Wide Range of Uses
- Ideal for government, financial/banking, insurance, accommodation services, transportation, rental and leasing services, legal services, and more
- Integrate information into digital workflows
- Process automation
- Information distribution
Dynamic, Reliable, Flexible Feeding
- Scans up to 45 ppm in B&W, grayscale, and up to 30 ppm in color - both sides of an item in a single pass
- Can hold up to 60 sheets
- Can handle a variety of document types
- Thick, thin or long documents
- Plastic or embossed cards
- Passports
- Can detect double-feed occurrences
- Equipped with double feed release functions and one touch release button
User-Friendly
- Designed with the user in mind
- Easy to use operation panel for one touch job operations
- Start and stop scanning
- Pre-configure job tasks
- CaptureOnTouch software
- One-touch access to repetitive tasks
- Scan to third-party cloud applications
- Evernote™
- Microsoft® SharePoint®
- Google Drive™
- SugarSync, OneDrive, and Dropbox
- Windows ISIS / TWAIN drivers
- Easy integration with capture and content management systems
High-Quality Imaging
- Auto Resolution setting for scanning mixed batches of text documents and photographs
- Improve legibility of text characters
- Optical Character Recognition (OCR) to help create searchable and editable information
Environment In Mind
- Meets ENERGY STAR guidelines
- Eu RoHS and EU WEEE compliant
- ErP Lot 6 directive for energy consumption compliant
| Model Name | ImageFORMULA DR-C240 Document Scanner |
| Type | Office Document Scanner |
| Document Feeding | Automatic Or Manual Document Weight: 7 - 56 Lb. Bond Plain Paper |
| Document Size Width | 2.0" - 8.5" |
| Document Size Length | 2.8" - 14.0" |
| Feeder Capacity | 60 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | Contact Image Sensor (CMOS) |
| Light Source | RGB LED |
| Operating Modes | Color, Grayscale, Black And White |
| Optical Resolution | 600 Dpi |
| Output Resolution | 100/150/200/240/300/400/600 Dpi |
| Interface | Hi-Speed USB 2.0 |
| Dimensions | 9.0" X 11.4" X 9.9" (With Trays Closed) |
| Weight | Approx. 6.17 Lb. |
| Power Consumption | 19W Or Less (Sleep Mode: 1.4W Or Less) Suggested Daily Volume: 4,000 Scans4 |
| Other Features | Auto Color Detection, Auto Page Size Detection, Auto Resolution, Background Smoothing, Deskew, Edge Emphasis, Moiré Reduction, Photograph Corrections, Prevent Bleed-Through/Remove Background, Shadow Cropping, Skip Blank Page, Text Enhancement, Text Orientation Recognition, Three-Dimensional Color Correction, Double-Feed Detection, User Preferences Bundled Software: ISIS/TWAIN Driver, CaptureOnTouch, CapturePerfect, ECopyPDF Pro Office, Kofax VirtualReScan Basic Supported OS: Windows, Vista 32bit SP2 & 64bit SP2 (WOW), Windows 7 32bit & 64bit (WOW), Windows 8 32bit & 64bit (WOW), Windows 8.1 32bit & 64bit (WOW). |
| Options | Flatbed Scanner Unit 101/201, Barcode Module, 2D Code Module, Exchange Roller Kit (Feed Roller And Retard Roller), Carrier Sheet (Passport), Carrier Sheet (A4) 1Subscription To A Third-Party Cloud Service Required. Subject To Third-Party Cloud Service Providers’ Terms And Conditions. 2Examples Based On Typical Settings, Rated In Pages/Images Per Minute With Letter-Sized Documents At 200 Dpi Portrait Feeding Directions. Actual Processing Speeds May Vary Based On PC Performance And Application. 3The Facts And Product Statistics About EU RoHS And WEEE Were Obtained From Canon Electronics Inc. As Of 2015. 4Calculations Based On Scanning Speed And Assumed Daily Time Of Use. |
Scanning Speeds
| Black And White | (Simplex / Duplex:)2 Up To 45 Ppm / Up To 90 Ipm |
| Grayscale | (Simplex / Duplex:)2 Up To 45 Ppm / Up To 90 Ipm |
| Color 24 Bit | (Simplex / Duplex:)2 Up To 30 Ppm / Up To 60 Ipm |
Exchange Roller Kit
Easy-to-replace kit typically consists of pickup, separation, and feed rollers that help ensure reliable document feeding and promote easy maintenance and upkeep of the scanning device.
Flatbed Scanner Unit 201 (Manual)
WA10 Network Adapter
Create ethernet and Wi-Fi network connectivity with the WA10 and a compatible imageFORMULA document scanner.
For more information, click here.
Flatbed Scanner Unit 102
NA10 Network Adapter
Create ethernet network connectivity with the NA10 and a compatible imageFORMULA document scanner.
2D Barcode Module
Barcode Module
Passport Carrier Sheet
Reusable protective sheet to scan passports.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
