imageFORMULA DR-C225W II
- Scanner Main Unit
- Setup Guide
- USB Cable
- AC Adapter
- Power Cable for 120V
- License key for eCopy PDF Pro Office
- Setup Disc
- Insert for Cardiris
- Packaging Materials
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageFORMULA DR-C225W II is registered EPEAT Silver.
- Corporate or remote offices
- Individuals or small workgroups
- Integrate information into digital workflows
- Convert paper documents to digital files
- Create keyword searchable files
- Scans 25 pages per minute in B&W, grayscale, and color1
- Can hold up to 30 sheets in feeder
- Can handle a variety of document types and sizes
- Thick, thin, long and even oversized documents
- Plastic or embossed cards
- Optical Character Recognition (OCR) to help create searchable and editable information
- Auto resolution setting for scanning mixed batches of documents and photographs
- U-turn path to save desk space
- Top feed and default top eject
- Upright design with small footprint
- Cable management system
- Front-forward, face up feeding
- Automatically adjust multiple settings with a single click
- Windows ISIS/TWAIN drivers, Mac TWAIN drivers included
- Canon CaptureOnTouch Software included
- Pre-configure repetitive scan jobs
- One-touch scanning
- Scan directly to third-party cloud applications2 GoogleDrive, MicrosoftSharePoint, Dropbox and more
- EPEAT Silver Registered
- Meets ENERGY STAR guidelines
- Complies with EU RoHS and WEEE directives for the reduction of hazardous substances and waste products
- ErP Lot 6 directive for energy consumption compliant
- Supports 802/11b/g/n WiFi scanning on smart phone and mobile IOS devices such as iPads and Android devices3
- Free Canon CaptureOnTouch Mobile app4
- Examples based on typical settings, rated in pages/images per minute with letter-sized documents at 200 dpi portrait feeding directions. Actual processing speeds may vary based on PC performance, available network bandwidth and application.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers' terms and conditions.
- Wireless scanning requires a working network with wireless 802.11 b/g/n capability. Wireless performance may vary based on terrain and distance between the scanner and wireless network clients.
- CaptureOnTouch Mobile is available at the App Store or Google Play Store.
- Calculations based on scanning speed and assumed daily time of use.
| Model Name | ImageFORMULA DR-C225W II |
| Document Feeding | Automatic Or Manual |
| Document Size Width | U-Turn Path: 50.8 Mm To 216 Mm (2.0" To 8.5") Straight Path: 50.8 Mm To 216 Mm (2.0" To 8.5") |
| Document Size Length | U-Turn Path: 53.9 Mm To 356 Mm (2.12" To 14.0") Straight Path: 53.9 Mm To 356 Mm (2.12" To 14.0") Long Document: Up To 3,000 Mm (118.1") Folio: Up To 297 Mm X 420 Mm (11" X 17") Document Thickness : U-Turn Path: 14 To 34 Lb. Bond / Straight Path: 11 To 58 Lb. Bond |
| Feeder Capacity | Up To 30 Sheets |
| Scanning Element | Contact Image Sensor |
| Light Source | RGB LED |
| Operating Modes | Color, Grayscale, B&W |
| Output Resolution | 100/150/200/240/300/400/600 Dpi |
| Scanning Resolution | 600 Dpi |
| Interface | USB 2.0 Or Wi-Fi® |
| Scanner Drivers | Windows OS: Windows® 7/8/8.1/10 Service Pack 1 Or Later (32-Bit/64-Bit) Or Later, Windows® Server 2008 R2 2012/R2 2016 Service Pack 1 Or Later Mac OS: 10.11 |
| Dimensions | 220mm X 300mm X 156mm (8.7" X 11.8" X 6.1") With Trays Closed |
| Weight | Approx. 2,8 Kg (6.17 Lb.) |
| Power Consumption | 15.6W Or Less (Energy Saving Mode: 4.3W Or Less) Suggested Daily Volume: Approx. 1,500 Scans5 |
| Other Features | Auto Color Detection, Auto Page Size Detection, Auto Resolution Setting, Background Smoothing, Character Emphasis, Color Dropout/Red Enhance Color, Deskew, Duplex, Edge Emphasis, Face-Up Feeding, Folio Mode, Image Rotation, Long Document Mode, Moiré Reduction, MultiStream, Pre-Scan, Prevent Bleed-Through/Remove Background, Shadow Cropping/Removal, Simplex, Skip Blank Page, Text Enhancement, Text Orientation Recognition, Three-Dimensional Color Correction, Ultrasonic Double-Feed Detection, User Preferences Bundled Software: Windows: ISIS/TWAIN Driver; Canon CaptureOnTouch Mac: TWAIN Driver; Canon CaptureOnTouch Downloadable Software: Windows: Nuance ECopy PDF Pro Office, Cardiris, ImageWARE Enterprise Management Console Mac: Cardiris, ImageWARE Enterprise Management Console |
| Options | Flatbed Scanner Unit 102/201, Exchange Roller Kit (Feed Roller And Retard Roller) |
Scanning Speeds
| Black And White | (Simplex / Duplex)1: Up To 25 Ppm/ Up To 50 Ipm |
| Grayscale | (Simplex / Duplex)1: Up To 25 Ppm/ Up To 50 Ipm |
| Color 24 Bit | (Simplex / Duplex)1: Up To 25 Ppm/ Up To 50 Ipm |
Exchange Roller Kit
Easy-to-replace kit typically consists of pickup, separation, and feed rollers that help ensure reliable document feeding and promote easy maintenance and upkeep of the scanning device.
Flatbed Scanner Unit 201 (Manual)
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
