imageFORMULA DR-C225 II
- Scanner Main Unit
- Setup Guide
- USB Cable
- AC Adapter
- Power Cable for 120V
- License key for eCopy PDF Pro Office
- Setup Disc
- Insert for Cardiris
- Packaging Materials
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Upright design with small footprint
- Top feeding & default top eject
- "U-turn" path feeding
- Cable management system
- Intuitive front-side-forward, top-up item feeding
- Eliminates the need to rotate or flip documents
- Full Auto Mode
- Automatically adjusts multiple settings with a single click
- Canon CaptureOnTouch
- Pre-configure repetitive scan jobs
- One-touch scanning
- Scan directly to cloud applications1
- Google Drive
- Microsoft SharePoint
- DropBox
- PDF, PDF/A, JPEG, TIFF, PPTX, BMP and PNG output formats
- ISIS & TWAIN drivers for Windows, TWAIN for Mac
- Easy integration with third-party software
- Meets ENERGY STAR guidelines
- Registered EPEAT Silver
- Eu RoHS compliant
- WEEE compliant
- ErP Lot 6 directive for energy consumption compliant
- Scans up to 25 pages per minute in B&W, grayscale, and color2 - both sides of an item in a single pass
- Reliably handles a wide variety of document types
- Thick or thin documents
- Plastic or embossed cards
- Photographs
- Long documents up to 118.1"
- Oversized documents larger than letter sized
- Detects double-feeds
- Features to improve character legibility, crop shadows, straighten scanned images
- Auto Resolution setting for scanning mixed batches of text documents and photographs
- Auto Color Detection
- Optical Character Recognition (OCR) to help create searchable and editable information
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers' terms and conditions.
- Examples based on typical settings, rated in pages/images per minute with letter-sized documents at 200 dpi portrait feeding directions. Actual processing speeds may vary based on PC performance, available network bandwidth and application.
| Model Name | ImageFORMULA DR-C225II |
| Document Feeding | Automatic Or Manual |
| Document Size Width | U-Turn Path: 50.8 Mm To 216 Mm (2.0" To 8.5") Straight Path: 50.8 Mm To 216 Mm (2.0" To 8.5") |
| Document Size Length | U-Turn Path: 53.9 Mm To 356 Mm (2.12" To 14.0") Straight Path: 53.9 Mm To 356 Mm (2.12" To 14.0") Long Document: Up To 3,000 Mm (118.1") Folio: Up To 297 Mm X 420 Mm (11" X 17") Document Thickness : U-Turn Path: 14 To 34 Lb. Bond / Straight Path: 11 To 58 Lb. Bond |
| Feeder Capacity | Up To 30 Sheets |
| Scanning Element | Contact Image Sensor |
| Light Source | RGB LED |
| Operating Modes | Color, Grayscale, B&W |
| Output Resolution | 100/150/200/240/300/400/600 Dpi |
| Scanning Resolution | 600 Dpi |
| Power Consumption | 12.7W (Energy Saving Mode:1.7W) |
| Other Features | Auto Color Detection, Auto Page Size Detection, Auto Resolution Setting, Background Smoothing, Character Emphasis, Color Dropout/Red Enhance Color, Deskew, Duplex, Edge Emphasis, Face-Up Feeding, Folio Mode, Image Rotation, Long Document Mode, Moiré Reduction, MultiStream, Pre-Scan, Prevent Bleed-Through/Remove Background, Shadow Cropping/Removal, Simplex, Skip Blank Page, Text Enhancement, Text Orientation Recognition, Three-Dimensional Color Correction, Ultrasonic Double-Feed Detection, User Preferences |
| Options | Flatbed Scanner Unit 102/201, Exchange Roller Kit (Feed Roller And Retard Roller) |
Exchange Roller Kit
Easy-to-replace kit typically consists of pickup, separation, and feed rollers that help ensure reliable document feeding and promote easy maintenance and upkeep of the scanning device.
Flatbed Scanner Unit 201 (Manual)
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
