imageFORMULA DR-C225
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Exceptional Performance:
- Top feeding & default top eject
- Upright design
- Dimensions (H x W x D): 8.7” x 11.8” x 6.1”
- Cable routing from either side of the scanner
- Device can be placed flush against a wall
Easy Use:
- Front-side-forward, top-up item feeding
- Eliminates the need to rotate or flip documents
- Full Auto Mode
- Automatically adjusts multiple settings with a single click
- Canon CaptureOnTouch
- Pre-configure repetitive scan jobs
- One-touch scanning
- Intuitive Graphical User Interface (GUI)
- Scan directly to cloud applications
- Microsoft SharePoint
- Evernote
- DropBox
- PDF/A format output
- ISIS & TWAIN drivers for Windows, TWAIN for Mac
- Easier integration with third-party software
Flexibility:
- Scans up to 25 pages per minute in color, B&W, and grayscale
- "U-turn" path feeding
- Typical document scanning
- Straight path feeding
- Thick documents
- Long documents
- Plastic and embossed cards
- Folio Mode for scanning oversized documents
- Ultrasonic Doublefeed Detection
High Image Quality:
- Character Emphasis improves legibility
- Shadow Cropping
- Deskew / straighten scanned images
- Auto Resolution setting for scanning mixed batches of text documents and photographs
- Auto Color Detection
- Optical Character Recognition (OCR) to help create searchable and editable information
Environmentally Friendly:
- Meets ENERGY STAR guidelines
- Eu RoHS compliant
- WEEE compliant
- ErP Lot 6 directive for energy consumption compliant
| Model Name | ImageFORMULA DR-C225 |
| Type | Desktop Sheet-Fed Scanner |
| Document Feeding | Automatic Sheet Feeding |
| Document Size Width | U-Turn Path: 50.8 To 216 Mm (2" To 8.5") Straight Path: 50.8 To 216 Mm (2" To 8.5") |
| Document Size Length | U-Turn Path: 70 To 356 Mm (2.76" To 14") Straight Path: 53.9 To 356 Mm (2.12" To 14") (Use Long Document Mode To Scan Documents Up To 3,000 Mm (118.1") Long.)Business Card: 50 X 53.9 Mm (1.97" X 2.12") Or Larger (Vertical Feeding Only.)Plastic Card: 53.9 X 85.5 Mm (2.12" X 3.37") (ISO Standard) Embossed Cards Can Be Scanned.Plain Paper U-Turn Path: 52 To 128 G/M2 (0.06 To 0.15 Mm) Straight Path: 40 To 209 G/M2 (0.05 To 0.25 Mm) Business Card: 300 G/M2 (140 Lb Bond) 0.35 Mm (0.0138") Or Less Plastic Card: 0.76 Mm (0.03") Or Less |
| Feeder Capacity | Automatic Sheet Feeding 6 Mm Stack (Including Curls) Or 30 Sheets Of 80g/M2 (20 Ib Bond) |
| Scanning Element | CMOS CIS |
| Light Source | LED (Red, Green, And Blue) |
| Operating Modes | Black And White, Error Diffusion, Advanced Text Enhancement, Advanced Text Enhancement II (For Windows Only), 256-Level Grayscale, 24-Bit Color |
| Scanning Resolution | 150 X 150 Dpi, 200 X 200 Dpi, 300 X 300 Dpi, 400 X 400 Dpi, 600 X 600 Dpi |
Exchange Roller Kit
Easy-to-replace kit typically consists of pickup, separation, and feed rollers that help ensure reliable document feeding and promote easy maintenance and upkeep of the scanning device.
Flatbed Scanner Unit 201 (Manual)
Flatbed Scanner Unit 102
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
