imageFORMULA DR-C125
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Space Saving:
- Unique Upright Design
- Top feeding
- Default top eject
- Dimensions (H x W x D): 8.5" x 11.8" x 6.1"
Easy Use:
- Front-side-forward, top-up item feeding
- Single-click image quality adjustments with Full Auto Mode
- Canon CaptureOnTouch for Windows and Mac
- Pre-defined Scan-To-Job buttons
- Scan directly to cloud applications such as Microsoft SharePoint and Evernote
- Windows ISIS/TWAIN and Mac TWAIN drivers
Flexibility:
- Scans up to 25 pages per minute (in black and white, grayscale, and color)
- Can handle a variety of document types
- Thick and thin documents
- Plastic ID Cards
- Embossed cards
- Driver licenses
- Long document mode (for documents up to 118" in length)
- Folio Scanning
- Ultrasonic Double-Feed Detection
High Image Quality:
- Background Smoothing
- Auto Resolution (for mixed batches of documents)
- Auto Color Detection
- Shadow Cropping
Environment In Mind:
- Meets ENERGY STAR guidelines
- RoHS and WEEE compliant
- Canon Generation Green program member
| Model Name | ImageFORMULA DR-C125 Document Scanner |
| Type | Office Scanner |
| Document Feeding | Automatic Or Manual |
| Document Size Width | U-Turn Path: Width: 2.0" - 8.5" Length: 2.8" - 14.0" Straight Path: Width: 2.0" - 8.5" Length: 2.1" - 14.0" Long Doc. Mode: Up To 118.1"Document Weight: U-Turn Path: 14 - 32 Lb. Bond Straight Path: 13 - 56 Lb. Bond |
| Feeder Capacity | 30 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | Three-Line Contact Image Sensor (CMOS) |
| Light Source | RGB LED |
| Operating Modes | Simplex, Duplex, Color, Grayscale, Black And White, Text Enhancement, Error Diffusion, Full Auto |
| Drop Out Color | Red, Green, Blue |
| Optical Resolution | 600 Dpi |
| Output Resolution | 150/200/300/400/600 Dpi |
| Interface | Hi-Speed USB 2.0 Supported OS: Windows® XP Professional (32-Bit/64-Bit)/Windows XP Home (32-Bit)/Windows Vista® (32-Bit/64-Bit)/Windows 7 (32-Bit/64-Bit), MacOS |
| Dimensions | 8.7" X 11.8" X 6.1" |
| Weight | 5.7 Lb. |
| Power Consumption | 12.7W Or Less (Energy Saving Mode: 1.8W Or Less)Suggested Daily Volumes: 1,500 Scans**Bundled Windows Software: ISIS/TWAIN Drivers, Canon CaptureOnTouch, Nuance ECopy PDF Pro Office, Nuance PaperPort, Nuance OmniPage, NewSoft Presto! BizCard, Evernote (Available Via DL)Bundled MAC Software: TWAIN Driver, Canon CaptureOnTouch, NewSoft! PageManager, NewSoft Presto! BizCard, Evernote (Available Via DL) |
| Other Features | Auto Color Detection, Auto Page Size Detection, Auto Resolution Setting, Background Smoothing, Color Dropout/Enhance Color, Deskew, Face Up Feeding, Folio Mode, Long Document Mode, Moiré Reduction, MultiStream, Pre-Scan, Prevent Bleed-Through/Remove Background, Shadow Cropping, Skip Blank Page, Text Orientation Recognition, Three-Dimensional Color Correction, Ultrasonic Double-Feed Detection, User Preferences |
| Options | Flatbed Scanner Unit 101, Exchange Roller Kit* Examples Based On Typical Settings, Rated In Pages/Images Per Minute With Letter-Sized Documents, Portrait-Feeding Direction, Up To 200 Dpi. ** Calculations Based On Scanning Speed And Typical Daily Time Of Usage. |
Scanning Speeds
| Black And White | (Simplex/Duplex):* Up To 25 Ppm / Up To 50 Ipm |
| Grayscale | (Simplex/Duplex):* Up To 25 Ppm / Up To 50 Ipm |
| Color 24 Bit | (Simplex/Duplex):* Up To 25 Ppm / Up To 50 Ipm |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
