The imageFORMULA DR-3010C compact workgroup scanner is Canon's fastest and most reliable desktop workgroup scanner. It combines many features from Canon's other high speed document scanners, along with some new features, to deliver the best to the workgroup segment.
For added value, the DR-3010C comes bundled with Canon's CapturePerfect, Canon CaptureOnTouch, Nuance eCopy PDF Pro Office, Presto! BizCard Reader SE, PaperPort Standard, OmniPage SE software, Kofax VRS and Nocson EasyConnect (available via download from the Nocson website) software and a full featured ISIS®/TWAIN driver.
2.1" - 14"*Document Weight Automatic Feeding: 14 - 54 Lb. Bond Manual Feeding: 11 - 54 Lb. Bond (Cards Up To .03" Thick)
Feeder Capacity
50 Sheets
Grayscale
8-Bit
Color
24-Bit
Scanning Element
Contact Image Sensor (CMOS)
Light Source
RGB LED
Operating Modes
Simplex, Duplex, Color, Grayscale, Black And White, Error Diffusion, Advanced Text Enhancement (Two Types)
Drop Out Color
Red, Green, Blue
Optical Resolution
600 Dpi
Output Resolution
100/150/200/240/300/400/600 Dpi
Interface
Hi-Speed USB 2.0
Scanner Drivers
ISIS®/TWAIN For Windows® 2000,XP, WindowsVista®
Dimensions
7.8" X 12.2" X 11.5"
Weight
6.4 Lb.
Power Consumption
18W Or Less (Energy Saving Mode: 4W Or Less)
Other Features
Ultrasonic Double-Feed Detection
Auto Color Detection
Moire Reduction
MultiStream
Prevent Bleed Through/Remove Background
User Registration
Skip Blank Page
Auto Paper Size Detection
Deskew
Batch Separation
Text Orientation Recognition
Edge Emphasis
Folio
BUNDLED SOFTWARE
Canon CapturePerfect
Nuance ECopy PDF Pro Office
Nuance PaperPort SE
Nuance OmniPage SE
Presto! BizCard
Kofax VRS
Nocson EasyConnect (Available Via Download From The Nocson Website)
Options
Flatbed Scanner Unit 101, Exchange Roller Kit, Barcode Module III, Soft Carrying Case* 118" In Long Document Mode ** Examples Based On Typical Settings, Rated In Pages/Images Per Minute With Letter-Sized Documents At 200 Dpi, Portrait-Feeding Direction. Actual Processing Speeds May Vary Based On PC Performance And Application.
