imageFORMULA CR-L1UV
The Canon imageFORMULA CR-L1UV compact check transport is an easy-to-use solution for high volume batch Remote Deposit Capture (RDC) and remote lockbox check processing. The CR-L1UV is equipped with UV sensors, which can scan anti-fraud patterns printed on checks with UV ink.
- Scanner Main Unit
- Power Cable
- USB Cable
- Setup Disc and Guide
- Operations and Maintenance Guide
- User Registration Card
