imageFORMULA CR-L1
- Scanner Main Unit
- Power Cable
- USB Cable
- Setup Disc and Guide
- Operations and Maintenance Guide
- User Registration Card
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Precise Image Capture
- High quality data capture helps reduce incorrect postings and item returns
- Fine Text Filtering-Removes patterned backgrounds and enhances edges around text for
- Sharper images with less distortion
- Improved OCR accuracy
- Up to 300 dpi output resolution-valuable check information is reproduced with precision
- Magnetic/optical character recognition (MOCR) technology combines MICR reading with OCR processing
- Help ensure accurate MICR data capture without sacrificing speed
Easy to use and maintain
- Small footprint
- Optimal for areas with limited workspace
- Easy open cover
- Easy access for maintenance and error recovery
- 50 item Auto Feeder
- USB Connectivity
Useful Features
- Built-in single line imprinter for physical endorsement
- Virtual endorsement for front and rear of items
- Equipped with UV sensors, which can scan anti-fraud patterns printed on checks with UV ink
- Supports the industry standard check-scanning software, Ranger Transport API
Reliable Performance
- Scans up to 45 checks per minute 1
- Infrared Double-Feed Detection Sensors
- 50 item Auto Feeder and Eject pocket
Environmentally Conscious
- Meets ENERGY STAR guidelines
- Eu RoHS compliant
- WEEE compliant
- ErP Lot 6 directive for energy consumption compliant
Development and Customization
- CR Software Development Kit (CR-SDK) is available for additional added functionality
- Examples based on typical settings, rated in checks per minute with 6" long U.S. personal checks at 200 dpi in black and white or grayscale.
- The facts and product statistics about EU RoHS and WEE were obtained from Canon Electronics Inc. as of 2018.
- In order to be eligible for the CR SDK, Canon U.S.A., Inc. must approve.
| Model Name | ImageFORMULA CR-L1 |
| Type | Compact Check Transport |
| Document Feeding | Automatic |
| Document Size Width | 53.34 – 109.22 Mm (2.1" – 4.3") |
| Document Size Length | 93.98 - 228.6 Mm (3.7" – 9.0") |
| Feeder Capacity | Up To 50 Sheets |
| Scanning Element | Contact Image Sensor |
| Light Source | RGB LED |
| Operating Modes | Grayscale, Black And White, Fine Text Filtering, Error Diffusion, 256 Level Grayscale, 16 Level Grayscale |
| Optical Resolution | 300 Dpi |
| Output Resolution | 100/120/200/300 Dpi |
| Interface | High Speed USB 2.0 |
| Scanner Drivers | Microsoft Windows 7 SP1 Or Later (32/64-Bit), Windows 8.1 (32/64-Bit), Windows 10 (32/64-Bit), Windows Server 2008R2, Windows Server 2012R2, Windows Server 2016 |
| Dimensions | 139.7 X 223.52 X 187.96 Mm (5.5" X 8.8" X 7.4") |
| Weight | 2.08 Kg. (4.6 Lb.) |
| Power Consumption | 15.8W Max. (Sleep Mode: 2.3W Or Less) |
| Other Features | Auto Page Size Detection, Fine Text Filtering, MOCR/ MICR, Deskew, Virtual Endorsement, Infrared Double Feed Detection, OCR, Device Logs For Troubleshooting And Maintenance Bundled Software: Ranger™ Driver With IQA, Canon Scanning Utility *Examples Based On Typical Settings, Rated In Checks Per Minute With 6" Long U.S. Personal Checks At 200 Dpi In Black And White Or Grayscale. **Calculations Based On Scanning Speed And Typical Daily Time Of Usage. ***Actual Prices Set By Dealer/Reseller May Vary. |
Scanning Speeds
| Black And White | (Simplex / Duplex):* Up To 150 Cpm / Up To 150 Cpm |
| Grayscale | (And BW): Up To 45 Cpm* |
| Color 24 Bit | Up To 20 Cpm* |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
