imageFORMULA CR-80
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Clear-Cut Images:
- Reduces risks such as incorrect postings and item returns
- Fine Text Filtering removes patterned backgrounds and enhances edges around text, for sharper images and improved OCR accuracy
- 600 dpi optical resolution
- Up to 300 dpi output resolution
- IQA Software to meet Check 21 standards
Precise MICR Read:
- Patented magnetic head reads E13B/CMC7 fonts
- MICR read complemented with OCR processing (MOCR) for increased accuracy
Dependable Item Handling:
- Scans up to 80 checks per minute
- Infrared double-feed detection
- Corrugated rollers
- Adjustable roller gap with notched increments
Easy to Install, Use, and Maintain:
- Small footprint convenient for teller counters, merchant desks, and other space constrained areas
- 7.4" x 5.5" x 8.8" (H x W x D)
- USB connectivity
- 50-item ADF
- Easy-open body cover for maintenance & error recovery
Useful Features:
- Built-in imprinter for physical endorsement
- Four-Line Add-On for dynamic "virtual" endorsement
- Low ink level alarm
- Logging tool for diagnostic purposes
- Scans, jams, double-feeds, imprints, LED hours of use
- Canon Scanning Utility assists with image capture / output
- Silver Bullet Ranger Driver
- Easier application integration & improved compatibility
- Software Development Kit (SDK)
Environment in Mind:
- Meets ENERGY STAR guidelines
- RoHS and WEEE compliant
- Canon Generation Green program member
Customer Care:
- KICTeam cleaning cards available (optional)
| Model Name | ImageFORMULA CR-80 Check Transport |
| Type | Compact Check Transport |
| Document Feeding | Built-In Automatic Feeder (ADF) |
| Document Size Width | 2.0" - 4.3" |
| Document Size Length | 3.1" To 9.0" |
| Thickness Automatic Feeding | .003" To .008" (17 To 40 Lb. Bond) |
| Feeder Capacity | Approx. 50 Sheets |
| Scanning Element | CMOS CIS Sensor |
| Light Source | RGB LED |
| Operating Modes | Simplex, Duplex, Color (24-Bit), Grayscale (4-Bit/8-Bit), Black And White, Fine Text Filtering, Error Diffusion |
| Optical Resolution | 600 Dpi |
| Output Resolution | Binary And Grayscale: 100/120/200/300 Color: 100/120/200 |
| Black And White | 80 Cpm* |
| Grayscale | 80 Cpm* |
| Color 24 Bit | 30 Cpm* MICR/OCR: |
| Interface | Hi-Speed USB 2.0 Supported OS: Windows XP/Windows Vista/7 |
| Dimensions | (H X W X D): 7.4" X 5.5" X 8.8" |
| Weight | 4.4 Lb. |
| Power Consumption | 20.4W (Energy Saving Mode: 4.7W)Suggested Daily Volume: 5,000 Scans |
| Other Features | Deskew, Four Line Virtual Endorsement, Infrared Double-Feed Detection, MOCR, Single Line Pre-Scan Imprinter Bundled Software: Silver Bullet Ranger Driver With IQA, Canon Scanning Utility Software |
| Options | Cleaning Cards, Ink Cartridge * Examples Based On Typical Settings, Rated In Checks Per Minute With U.S. Personal Checks At 200 Dpi In Black And White, Grayscale Or Color. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
