imageFORMULA CR-190i II
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Wide Range of Uses
- Can assist in handling large volumes of checks to help improve efficiency of payment processes and treasury management
- Helpful in areas such as financial institutions, utilities, and other organizations
- Ideal for high-volume remittance processing, lockbox, and back-office / branch capture
- Bundled with Silver Bullet Ranger API
Dynamic and Reliable Performance
- Scans up to 190 items per minute - both sides of an item in a single pass
- Can hold up to 250 items
- Can handle a variety of document types
- Business and personal checks
- Rebate check cards
- Deposit and withdrawal slips
- Coupons
- Tickets
- Envelopes
- Includes two 200-item eject pockets - used individually or virtually combined to form one large pocket for increased output capacity, and an additional 50-item pocket
- Built-in jogger helps eliminate mis-feeds
- Detects double feed via ultrasonic double-feed
- Detector
Precise Image Quality
- Auto page size detection
- Sharp image capture with low distortion using Fine Text Filtering
- Deskew / straighten scanned images
- Magnetic / optical character recognition (MOCR) technology combines MICR reading with OCR processing
- Help ensure accurate MICR data capture without sacrificing speed
Efficient Design
- Countertop-sized and easy-access design
- Easy maintenance
- Enclosed mechanics
- Easy-access paper path
- Ability to change imprinter's ink cartridge, clear jams, and clean scanning glass
Environment In Mind
- Meets ENERGY STAR guidelines
- Eu RoHS and EU WEEE compliant
- ErP Lot 6 directive for energy consumption compliant
| Type | High-Volume Check Transport |
| Document Feeding | Automatic |
| Document Size Width | 2.7" - 4.3" |
| Document Size Length | 4.7" - 9.6" |
| Thickness Automatic Feeding | 0.003" - 0.008" (17 - 40 Lb. Bond) |
| Thickness Manual Feeding | 0.003" - 0.02" (17 - 112 Lb. Bond) |
| Feeder Capacity | 250 Sheets |
| Grayscale | 256-Level, 16-Level |
| Scanning Element | Contact Image Sensor (CMOS) |
| Optical Resolution | 1200 Dpi |
| Output Resolution | 100/120/150/200/240/300 Dpi |
| Interface | Hi-Speed USB 2.0 |
| Scanner Drivers | Windows Vista/7/8/8.1/10 |
| Dimensions | 8.4" X 18.7" X 10.7" |
| Weight | Approx. 18.5 Lb. |
| Power Consumption | 49 W Or Less (Sleep Mode: 2.7 W Or Less) |
| Other Features | Auto Page Size Detection, Built-In Jogger, Color Dropout,Continuous Feeding, Deskew, Duplex, Error Diffusion, Fine Text Filtering, MICR-Based Imprinting, MICR-Based Sorting, Paper Eject Button, Programmable Function Button, Three Output Pockets (200/200/50), Ultrasonic Double-Feed Detection, Waterfall Output Mode Bundled Software Silver Bullet Ranger Driver With IQA, Canon Scanning Utility Software Suggested Daily Volume 24,000 Scans*** * Examples Based On Typical Settings, Rated In Checks Per Minute With 6" Long U.S. Personal Checks At 200 Dpi In Black And White Or Grayscale. ** The Facts And Product Statistics About EU RoHS And WEE Were Obtained From Canon Electronics Inc. As Of 2015. *** Calculations Based On Scanning Speed And Assumed Daily Time Of Use. |
| Options | Exchange Roller Kit, Imprinter Ink Absorber |
Scanning Speeds
| Black And White | Simplex: Up To 190 Cpm Duplex: Up To 190 Cpm |
| Grayscale | Simplex: Up To 190 Cpm Duplex: Up To 190 Cpm MICR/OCR MICR: E13B/CMC-7 OCR: E13B/OCR-A/OCR-B /Universal Character |
Ink Disposal Tank
A consumable receptacles that collect and contain residual ink sprayed from ink cartridge.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
