imageFORMULA CR-150
- Scanner Main Unit
- Power Cable
- USB Cable
- Setup Disc and Guide
- Operations and Maintenance Guide
- User Registration Card
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Wide Range of Uses
- Can help assist in moving paper checks and related documents
- Front-counter teller settings, merchant/remote deposit capture (RDC) applications, and remittance processing
- Back-office/branch capture, lockbox applications
- Ideal for banks, credit unions, and retail
Simple, Compact Design
- Small footprint
- Optimal for teller counters, merchant desks, and areas with limited workspace
- Multifunction compatibility
- Combines functions of many peripherals found at teller station into one device
Reliable Item Handling
- Scans up to 150 items per minute1
- 150-item Automatic Document Feeder (ADF)
- Two additional USB ports for CR-150 for added USB peripheral equipment
Robust, Scalable Features
- Built-in five line imprinter prints and captures endorsement information on checks
- Modular and scalable - functionality can be added as required
- Dedicated card-reading slot for plastic and embossed cards
- Magnetic swipe reader (MSR)2 to capture information from the magnetic stripe of a bank card (MSR model only)
- Supports the industry standard check-scanning software, Ranger Transport API
Precise Image Capture
- Deskew/straighten scanned images
- Sharp image capture with low distortion using Fine Text Filtering
- Magnetic/optical character recognition (MOCR) technology combines MICR reading with OCR processing
- Help ensure accurate MICR data capture without sacrificing speed
Environmentally Conscious
- Meets ENERGY STAR guidelines
- Eu RoHS compliant
- WEEE compliant
- ErP Lot 6 directive for energy consumption compliant
Development and Customization
| Model Name | ImageFORMULA CR-150 |
| Type | Compact Check Transport |
| Document Feeding | Automatic |
| Document Size Width | From 61 Mm To 108 Mm (From 2.4” To 4.3”)* |
| Document Size Length | From 89 Mm To 245 Mm (From 3.5” To 9.6”)* |
| Feeder Capacity | Up To 150 Sheets |
| Grayscale | 8-Bit |
| Color | 24-Bit |
| Scanning Element | Contact Image Sensor (CMOS) |
| Light Source | RGB LED |
| Operating Modes | Color, Grayscale, Black & White, Fine Text Filtering, Error Diffusion, 256 Level Grayscale, 16 Level Grayscale, 24-Bit Color (Card Scan Only) |
| Optical Resolution | Up To 600 Dpi |
| Output Resolution | 100/150/200/240/300/400/600 Dpi |
| Interface | Hi-Speed USB 2.0 |
| Scanner Drivers | Windows Vista 32-Bit And 64-Bit (SP2 Or Later); Windows 7 (SP1 Or Later); Widows 8.1 32-Bit And 64-Bit; Widows 10 32-Bit And 64-Bit; Windows Server 2008R2/2012R2 |
| Dimensions | 203.6 Mm X 170 Mm X 238.2 Mm (8.0” X 6.7” X 9.4”) |
| Weight | Aprox. 3,2 Kg (7.1 Lb) |
| Power Consumption | 25W Or Less (Sleep Mode: 2.7W Or Less) |
| Other Features | Auto Page Size Detection, Color Dropout/ Enhancement, Fine Text Filtering, Imprinter, Border Removal, Edge Emphasis, Add-On, IQA, Contrast Adjustment, MOCR/MICR, Deskew, Color Deviation Correction, OCR, Shading Compensation, Scan Area Setting, MultistreamBundled Software: Ranger&Trade; Transport API, Canon Scanning Utility |
| Options | Exchange Roller Kit, Imprinter Ink Absorber |
Scanning Speeds
| Black And White | (Simplex / Duplex):* Up To 150 Cpm / Up To 150 Cpm |
| Grayscale | (Simplex / Duplex):* Up To 150 Cpm / Up To 150 Cpm |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
