imageFORCE C3026
- Color A3 Multifunction Printer
- Prints up to 26 ppm (BW/Color, Letter)
- Scans up to 80 ipm (300 dpi BW/Color Duplex)
- Up to 4800 x 2400 dpi Print Resolution
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Overview
THE ULTIMATE ENTRY LEVEL A3 COLOR MULTIFUNCTION PRINTER FOR CORE OFFICE NEEDS.
A3 multifunction color printer, ideal for small workgroups needing reliable high-quality printing and scanning.
Features
Boost Productivity
Work faster with rapid start‑up, and rock‑solid reliability to help teams keep business moving. Compatibility with uniFLOW Online and Cloud Connector ensures seamless connectivity to workflows.
Smooth User Experience
Simple, intuitive and quiet. Helping everyone get more done with clear on-screen steps, easy controls and a smart preview that shows your print exactly as it will appear – no surprises.
Security-Focused
Defend your data and your device with robust security features designed with the modern workplace in mind.
Meet Sustainability Targets
Reduced power consumption, long-life components and recycled materials make every print a smarter choice for your business – and a lighter one for the planet.
| Machine Type | A3 Color Multifunctional |
| Core Functions | Print, Copy, Scan, Send, Store, and Optional Fax |
| Processor | 1.6GHz Dual Core Processor |
| Control Panel | 7 inch TFT LCD WVGA Color Touch Panel |
| Memory | RAM 3.0GB |
| Storage |
| Interface Connection |
| Paper Supply Capacity (A4, 80gsm) |
| Paper Output Capacity (A4, 80gsm) |
| Finishing Capabilities | Collate, Group, Offset, Staple, Saddle Stitch, Hole Punch, Eco Staple, Staple On Demand Finishing capabilities vary depending on the options connected. |
| Supported Media Types |
| Supported Media Sizes | Lower Cassette
Upper Cassette
Multi-purpose tray
| Supported Media Weights |
| Warm-up Time |
| Dimensions (W x D x H) | 565 x 712 x 862 mm |
| Installation Space (W x D) |
| Weight | Approx. 78 kg * Including regular toner |
| Print Speed (BW and CL) |
| Print Resolution (dpi) | 4800 x 2400 |
| Page Description Languages |
| Printing From Mobile And Cloud | AirPrint, Mopria, IPP Everywhere, Canon PRINT, uniFLOW Online, Universal Print and Cloud Connector A range of software and MEAP-based solutions are available to provide printing from mobile devices or internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information. |
| OS Standard Printing | Android, Windows® 11, Chrome OS, macOS (11.2.2 or later), iOS (15.2 or later), iPadOS |
| Fonts |
*1 Optional PCL International Font Set-A1 is required. |
| Print Features | Secure Print, Secure Watermark, Header/Footer, Page Layout, Two-sided Printing, Mixed Paper Sizes/Orientations, Toner Reduction, Poster Printing, Forced Hold printing, Print Date, Scheduled Printing, Printing Using a Virtual Printer, Compatible with Quick Editor |
| Operating System |
* As of October 2025 |
| Copy Speed (BW and CL) |
| First-Copy-Out Time (A4, BW/CL) | Approx. 7.0/8.7 seconds or less |
| Copy Resolution (dpi) | 600 x 600 |
| Multiple Copies | Up to 999 copies |
| Magnification | Variable zoom: 25% to 400% (1% Increments) |
| Copy Features | Preset R/E Ratios by Area, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Book to Two Pages, Two-sided Original, Sort, Job Build, N on 1, Different Size Originals, Sharpness, Erase Frame, Gutter, Copy ID Card, Skip Blank Pages, Free Size Original, Reserved copy, Copy Sample, Dropout Color |
| Type |
| Document Feeder Paper Capacity (80 gsm) | Up to 100 Sheets |
| Document Feeder Acceptable Paper Weight |
| Scan Speed (ipm, BW/CL, A4) |
| Scan Resolution (dpi) | 600 X 600 |
| Pull Scan Specifications | Color Network ScanGear2 for both TWAIN and WIA Supported OS: Windows® 11/Server 2016/Server 2019/Server 2022/Server 2025* * As of Oct. 2025 |
| Scan Method | Push Scan, Pull Scan, Scan to Network, Scan to memory media (USB Memory Key), Scan to Mobile Devices, Scan to cloud-based services (uniFLOW Online) |
| Destination |
| Address Book | LDAP (2,000)/Local (1,600)/Speed dial (200) |
| Communication Protocol |
| File Format |
| Universal Send Features | Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Erase Frame, Job Build, Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Dropout Color |
| Maximum Number Of Connection Lines | 1 |
| Modem Speed |
| Compression Method | MH, MR, MMR, JBIG |
| Resolution (dpi) | 400 x 400 (Ultra Fine), 200 x 400 (Super Fine), 200 x 200 (Fine), 200 x 100 (Normal) |
| Sending/Receiving Size | *1 Sent as A4 *2 Sent as B4 short |
| FAX Memory | Up to 30,000 pages (2,000 jobs) |
| Speed Dials | Max. 200 |
| Group Dials/Destinations | Max. 199 dials |
| Sequential Broadcast | Max. 256 addresses |
| Memory Backup | Yes |
| Fax Features | Sender's Name (TTI), Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Interrupt Transmission, Sequential Broadcasting, Password/Subaddress Sending, Confidential Mailbox |
