imageCLASS X MF1238
- imageCLASS X MF1238 Main Unit
- Toner T08L: 3,000 Yield
- Power Cord
- Telephone Cable
- Starter Guide
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Workflow Efficiency
- 5" intuitive color touchscreen with smartphone-like usability.
- A unique, customized device experience with Application Library.
- Supports certain compatible mobile solutions for printing and scanning. 1
- Scan and convert documents to searchable digital files through a single-pass, duplex document feeder.
- Designed for small print jobs with first-print-out time as fast as 5.3 seconds.
Security Features
- Helps reduce the risk of confidential information loss, since documents are only stored in short-term memory.
- With imageWARE Enterprise Management Console Device Configuration Manager Plug-in, security settings can be captured and exported to other devices on the same network.2
- Remotely control device access and set rules via optional uniFLOW or uniFLOW Online.
- Limit document distribution by implementing Send-to-Myself-only.
- Verify System at Startup is a process to help verify the validity of the device firmware and Application Library from unauthorized modifications.
Cost Management
- Leverage optional uniFLOW or uniFLOW Online for full accounting and reporting for Canon and third-party devices, pull printing, and job routing.
- Service parts are designed for machine's life cycle to help minimize the need for proactive maintenance and potentially reduce service calls.
- High-capacity, all-in-one cartridge helps reduce overall supply costs.
- Out-of-the-box, standard, two-sided printing plus the ability to print multiple pages onto one sheet help to reduce paper consumption.
Device and Fleet Management
- Designed for quick, easy deployment.
- Remote diagnostics for rapid service response.
- Easily monitor device status and consumable levels, observe meter readings, manage settings, and implement security settings.
Quality and Reliability
- Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
- Designed to achieve maximum uptime with status notifications to help keep supplies replenished.
- Intuitive maintenance videos for common tasks like consumables replacement.
Sustainability
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve lower energy consumption.
- Encourages environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
- ENERGY STAR® certified and currently rated EPEAT® Silver.3
Manage Output with uniFLOW Software
The optional uniFLOW portfolio offers an on-premise or cloud solution that imageCLASS devices can utilize with flexible authentication. With either card-based or PIN-code-based authentication, imageCLASS devices can help secure output management, track costs with reporting, and operate mobile printing—one platform for your print, scan, and device management.
Fleet Management Tools
imageWARE Enterprise Management Console can be used by a device administrator to centrally manage the Canon printer fleet, including consumables, status notifications, meters, and configuration settings. imageWARE Remote software allows for the service provider to manage devices proactively, including remote diagnosis and reporting. Local Content Delivery System facilitates remote firmware download at the device level.
Fast, Single-Pass Duplex Scanning
The Color imageCLASS X 1238i model leverages a single-pass document feeder for two-sided scanning at up to 70 images per minute (ipm) in black-and-white or up to 26 ipm in color. Easily scan directly to PC, USB, email, or the network. Scanned files can be converted into multiple file formats, including Hi-Compression PDF and Searchable PDF (OCR).
Easy To Use with Application Library
Unique to the Canon product line, the Application Library platform allows for one-touch button creation of key functions: Print Template, Standby Slide (screen saver), Scan-to-Preset Destination, ID Card Copy, Consumables Information, Copy (Eco), Copy (Bleed Reduce), Passport Copy, Fax and Store, Name and Scan, Copy (Enhanced Text), and Language.
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.cla.canon.com/cla/en/office/MobileApps. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
- Please reference user manuals for details on settings available to export.
- For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
- Includes consumables.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
- Attachment kit required.
- Ask Dealer for reader compatibility information.
| Printer Type | Black And White Laser |
| Print Speed | Up To 40 Ppm (Letter); Up To 32 Ppm (Legal) 5 |
| First Print Time | Approx. 5.3 Seconds |
| Printer Language | UFR II, PCL®6, PCL®5, Adobe PostScript 3® |
| Print Resolution | 600 X 600 Dpi |
| Maximum Print Size | Up To Legal |
| Duplex Print | Yes |
| Print Modes | Secure Print, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations |
| Print Memory | 1 GB |
| Direct Print From Usb | Available From USB Memory (JPEG, TIFF, PDF) |
| Standard Paper Source | 250-Sheet Paper Cassette, 100-Sheet Multipurpose Tray |
| Optional Paper Source | 550-Sheet Paper Cassette (Cassette Unit-AH1) |
| Paper Output | 65 Sheets |
| Paper Weight | Cassettes: 16 Lb. Bond To 32 Lb. Bond (60 To 120 G/M2) Multipurpose Tray: 16 Lb. Bond To 43 Lb. Bond (60 To 163 G/M2) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" X 5.8" To Max. 8.5" X 14") Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Thick, Bond Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes) |
| Standard Interface | USB 2.0 X2 (Host), USB 2.0 X1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection |
| Wifi Access Mode | WEP 64/128 Bit, WPA-PSK (TKIP/ AES), WPA2-PSK (AES) |
| Wifi Authentication Methods | WPA2-PSK (AES) |
| Mobile Functions | Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service, Google Cloud Print,™,6 UniFLOW Secure Mobile Printing |
| Os Compatibility | UFR II/PCL/PS: Windows® 7/Windows 8.1/ Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X V10.9.5 (Or Later) |
| Power Consumption | Maximum: Approx. 1300 W, Standby: Approx. 8.5 W, Sleep Mode: Approx. 0.9 W |
| Typical Energy Consumption | 0.33 KWh Power Requirements: AC 120-127 V:6.5 A, 60 Hz |
| Dimensions | Standard (Desktop): 17.3" X 14.7" X 12.3" (438 Mm X 373 Mm X 312 Mm) |
| Unit Weight Without With Cartridge | Approx. 20.3 Lb. (9.2 Kg) |
| Package Weight | Approx. 28.7 Lb. (13.0 Kg) |
| Cartridge Type | Cartridge T08 Black - Yields Up To 11,000 Pages |
| Lcd Display | 5" Color Touch Panel |
| Security | Authentication: Standard: Embedded Universal Login Manager, Department ID Authentication, Optional: UniFLOW, UniFLOW Online Data: Verify System At Startup Network: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6 Document: Secure Print |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
