imageCLASS MF5980dw
The imageCLASS MF5980dw combines professional-quality multifunction capabilities with features that help businesses save time and money, making it the perfect device for today's small business owners.
- Main Unit
- Starter Cartridge 119
- Power cord
- Modular Cable (RJ11)
- User Software CD-ROM
- e-manual CD-ROM
- Starter Guide
- Destination Labels
- Operation panel Label
- CRG Spacer
- Cartridge Instruction Sheet
- Setup Instructions
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
2. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
3. Based on ITU-T #1 Chart (standard mode).
4. PNG supports MAC OS only.
5. Based on 75g/m2 paper.
6. USB 2.0 Hi-Speed requires Windows® 7, Windows Vista®, Windows XP/2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v. 10.2 to 10.2.6 operating systems, the printer/scanner will operate at USB 1.1 specifications.
7. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
8. SNMPv3 supports Print and Send (Scan to Email/SMB) functions only.
09. Based on 20 lb. bond paper.
10. Print speed is based on internal testing. Print speed may vary depending on the number of copies selected, as well as on the settings for size, type and orientation of paper.
| Printing Method | Monochrome Laser |
| Print Speed Text | Default Print Mode: 2-Sided Black: Up To 17 Ppm (2-Sided, Plain Paper Letter)11 Black: Up To 35 Ppm (1-Sided, Plain Paper Letter)11 First Print Time 6 Seconds Or Less (Letter) |
| Resolution Text | Up To 600 X 600 Dpi 1200 X 600 Dpi Quality |
| Toner Compatibility | Canon Cartridge 119 (Yield: 2,100 Pages*) Single Cartridge System Canon Cartridge 119 II Hi-Capacity (Yield: 6,400 Pages*) *Yield Is Based On ISO/IEC Standard |
| Paper Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
| Print Features | Printer Language UFR II LT (Host-Based) Print Modes Poster, Booklet, Watermark, Toner Save, Page Composer Print Memory 256MB (Shared) |
| Paper Weights | 16 To 31 Lb. Bond (Cassette) 16 To 51 Lb. Bond (Multipurpose Tray) |
| Output Tray Capacity | 150 Sheets (Face Down) |
| Mono Copy Resolution | Up To 600 X 600 Dpi |
| Mono Copy Speed Up To | Black: Up To 35 Cpm (Letter) Duplex Black: Up To 17 Cpm (Letter) |
| Type | Monochrome Laser |
| Zoom | 25 - 400% In 1% Increments |
| Halftones | 256 Levels |
| First Copy Time | Less Than 8 Seconds1 Warmup Time: Less Than 17 Seconds Recovery Time: 5 Seconds Or Less |
| Reductions Enlargement | 25%, 50%, 64%, 78% / 129%, 200%, 400% |
| Document Feeder | 50-Sheet Duplex5 |
| Copy Size | Platen: Up To Letter ADF: 5.5" X 5" To Legal |
| Copy Feature | Memory Sort, 2 On 1, 4 On 1, ID Card Copy |
| Scanner Type | Color Contact Image Sensor (CIS) Scanner Compatibility: TWAIN, WIA |
| Max Resolution Text | Up To 600 X 600 Dpi (Optical) Up To 9600 X 9600 Dpi (Interpolated) |
| Scanner Features | Scan To USB Host 1.1 (Hi-Compression PDF, PDF, JPEG, TIFF), Rotate Image, Pull Scan, Push Scan, Scan To Email, Scan To SMB |
| Color Depth | 24-Bit |
| Max Document Size | Platen: Up To Letter ADF: 5.5" X 5" To Legal |
| File Format | Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP, PNG4 |
| Modem Speed | Up To 33.6 Kbps (Super G3)2 |
| Transmission Speed Approx | JBIG (Approx. 3 Seconds) |
| Transmission Reception Memory | Up To 512 Sheets3 |
| Fax Resolution | Up To 400 X 400 Dpi (Ultra Fine) |
| Speed Dialing | 19 One-Touch Speed Dials; 181 Coded Dials |
| Group Dialing | Group Dialing: 199 Destinations Sequential Broadcasting: 210 Destinations |
| Receive Options | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Collate, Auto Fax Reduction, PC Fax, Fax Forwarding, Memory Backup (1 Hour) |
| Other Features | USB Device 2.0 Hi-Speed6, 10/100 Base-T Ethernet (Network), IEEE802.11b/G/N (Wireless)7 WiFi Access Infrastructure Mode WiFi Authentication Method Open System, Shared Key, WPA-PSK, WPA2-PSK WiFi Encryption Mode WEP (64/128 Bit), TKIP, AES WPS Easy Setup Support Methods Push-Button Mode, PIN Code Mode Embedded Web Server (Remote UI) W/ IE 6.0 Or Later, Safari 1.3.2 Or Later Department Counter (Print, Copy, Scan) 5-Row Backlit LCD W/ Animation (Fax Installation, Toner Installation, Paper Jam) Print Protocols: LPD, RAW, WSD Supported Network Protocols: TCP/IP V4, TCP/IP V6 (Print Only) TCP/IP Set Of Application Services: DHCP, BOOTP, RARP, ARP+PING, Auto IP, Bonjour, HTTP, SHTTP, NetBIOS Network Management Protocols: SNMPv1, SNMPv38 MIB: RFC1213 (MIB-II), RFC1514 (Host Resources MIB), RFC1759 (Printer MIB), Canon MIB Languages: English, French, Spanish, Portuguese Security: IP Filtering, MAC Address Filtering, Secure Print |
| Os Compatibility | Windows® 7, Windows Server® 2008, Windows Vista®, Windows Server 2003, Windows XP/2000, Mac® OS X 10.4.9 & Up |
| Software Included | Canon Drivers, MF Toolbox, Document Management & OCR Software |
| Power Source | 120V-127V, 60Hz 220V-240V, 50/60Hz |
| Power Consumption Approx | 1,000W (Max), 9W (Standby), 2.1W (Energy Saver Mode) Typical Energy Consumption (TEC): 1.4k Wh |
| Dimension W X D X H | 15.4" (W) X 18.6" (D) X 17.0" (H) |
| Weight | 40.4 Lbs. (Without Cartridge); 42.2 Lbs. (With Cartridge) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
