imageCLASS MF515x
- imageCLASS MF515x product
- Standard Cartridge 324
- Power Cord
- Starter Guide / Manuals
- User Software CD-ROM
- Telephone Cable
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
2. May vary depending on the output environment.
3. Letter size, after being restored from energy saver mode.
4. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
4a. Based on ITU-T #1 Chart (standard mode).
5. Based on 20 lb. bond paper.
6. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
6a. Wi-Fi®; is a registered trademark of the Wi-Fi Alliance®;. The Wi-Fi CERTIFIED™ Logo is a certification mark of the Wi-Fi Alliance®;.
7. Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
8. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
9. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
10. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
| Printer Type | Monochrome Laser |
| Print Speed | Up To 42 Ppm (1-Sided Plain Paper Letter) / 20.5 Ppm (2-Sided Plain Paper Letter)1 |
| First Print Time | 7.5 Seconds Or Less (Letter)2 |
| Printer Language | UFR II (Host-Based), PCL6 (5c, XL) / PS |
| Print Resolution | Up To 600 X 600 Dpi, 1200 X 1200 Dpi Quality |
| Maximum Print Size | Up To Legal (8.5 X 14 Inches) |
| Duplex Print | Yes |
| Print Modes | Poster, Booklet, Watermark, Page Composer, Toner Saver |
| Print Memory | 1 GB (Shared) |
| Direct Print From Usb | PDF/JPEG/TIFF Formats |
| Copy Type | Monochrome Laser |
| Copy Speed | Up To 42 Ppm (1-Sided Plain Paper Letter) / 20.5 Ppm (2-Sided Plain Paper Letter)1 |
| Copy Resolution | Up To 600 X 600 Dpi |
| Original Type | Text/Photo, Text, Photo |
| Halftones | 256 Levels |
| Warm Up Time | 16 Seconds Or Less From Power On |
| First Copy Time | 9.6 Seconds Or Less (Letter)3 |
| Recovery Time | 8 Seconds Or Less |
| Maximum Number Of Copies | Up To 999 Copies |
| Reduction Enlargement | 25-400% In 1% Increments |
| Copy Size | Platen: Up To 8.5 X 14, Feeder: 5.1 X 5.5 To 8.5 X 14 (Legal Size) |
| Copy Features | Frame Erase, Memory Sort, 2 On 1, 4 On 1, ID Card Copy |
| Modem Speed | Up To 33.6 Kbps (Super G3)4 |
| Fax Resolution | Up To 406 X 391 Dpi (Ultra Fine) |
| Transmission Time | Approx. 3 Seconds Per Page (ECM-JBIG, Transmitting From The Memory At 33.6 Kbps) |
| Memory Capacity | Up To 512 Sheets4a |
| Speed Dials | 19 One-Touch Dials, Up To 262 Coded Dials |
| Group Dialing | 199 Destinations |
| Sequential Broadcasting | 310 Destinations |
| Duplex Fax | Yes (Sending) |
| Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Fax Forwarding, Dual Access, Remote Reception, PC Fax (TX Only), Fax Activity / Activity Result Reports, Fax Activity Management Reports, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial |
| Memory Backup | Yes |
| Activity Reports | Fax Activity / Result Reports, Fax Activity Management Reports |
| Pc Fax | Sending Only |
| Fax Forwarding | SMB, E-Mail, FTP, IFax Simple |
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-Bit |
| Scan Resolution | Up To 600 X 600 Dpi (Optical), 9600 X 9600 (Software Interpolated Resolution) |
| Scan Size | Platen / Feeder: Up To Legal |
| Duplex Scan | Yes |
| Compatibility | TWAIN, WIA 2.0 |
| Output File Formats | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
| Scan Features | Push Scan, Pull Scan, Scan To USB |
| Pull Scan | USB And Network |
| Push Scan Scan To Pc | USB And Network |
| Scan To Email | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
| Scan To Smb | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
| Standard Paper Source | 500-Sheet Cassette Plus 100-Sheet Multipurpose Tray5 |
| Optional Paper Source | 500-Sheet Cassette5 (Up To 2 Cassettes) (PF-45) Cabinet Type – M1: 24" (W) X 25.5" (D) X 13.5" (H) (Recommended For Use With 1 Or 2 Optional Cassettes) |
| Document Feeder | Duplex Auto Document Feeder 50-Sheets5 |
| Paper Output | 250 Sheets (Face Down) |
| Paper Weight | 16 To 32 Lb. Bond (Plain Paper, Cassette / Option), 16 To 53 Lb. Bond (Plain Paper, Multipurpose Tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, Executive, Statement, Postcard And Index Card Via Multipurpose Tray Only |
| Media Types | Plain, Heavy, Recycled, Color, Label, Envelope |
| Envelope Capacity | 10 (Multipurpose Tray) |
| Envelope Types | Com 10, Monarch, DL, C5 |
| Standard Interface | USB Device 2.0 High-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11b/G/N Wireless6, Wi-Fi Direct Connection6a |
| Wifi Access Mode | Infrastructure Mode, WPS Easy Set Up |
| Wifi Authentication Methods | WEP 64/128 Bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES), 802.1x (LEAP, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS) |
| Wifi Encryption Modes | WEP (64/128 Bit), TKIP, AES |
| Wps Easy Setup Support Methods | Push-Button Mode, PIN Code Mode |
| Mobile Functions | Canon PRINT Business7, Apple® AirPrint®8, Mopria™ Print Service9, Google Cloud Print™10 |
| Network Functions | Print, Scan (SMB, E-Mail, FTP), PC Fax |
| Embedded Web Server Remote Ui | Yes |
| Web Browser Support For Remote Ui | IE 7.0 Or Higher, Safari 3.2.1 Or Higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
| Tcp Ip Set Of Application Services | Bonjour(MDNS), HTTP, HTTPS, POP Before SMTP (IPv4, IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
| Network Management Protocols | SNMPv1, SNMPv3 (IPv4, IPv6) |
| Os Compatibility | Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012 R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac OS X® 10.6 & Up Drivers Available For Download From Www.Usa.Canon.Com |
| Cable Included | Power Cord, Phone Cable (USB Not Included) |
| Bundled Software | Printer Driver, Fax Driver, Scanner Driver, Network Scan Utility, MF Scan Utility, Presto! PageManager |
| Power Consumption | During Operation: 750W, Standby: 11.3W, Energy Saver: 1.4 W (Wireless), .7 W (USB), .8 W (Wired) In Sleep Mode |
| Typical Energy Consumption | 1.7 KWh (230V) |
| Dimensions | 17.9"(W) X 18.8"(D) X 19.9"(H) |
| Unit Weight Without With Cartridge | 50.8 Lbs W/O Cartridge, 53.6 W/ Cartridge |
| Package Weight | 66.2 Lbs. |
| Cartridge Type | Cartridge 324 (Yields Approximately 6,000 Pages), Cartridge 324II (Yields Approximately 12,500 Pages) Single Cartridge System *Yields Based On ISO/IEC Standard |
| Department Counter | Yes |
| Lcd Display | 3.5 Inch, Color Touch LCD |
| Duty Cycle | Up To 100,000 Pages Per Month |
| Department Id Management | Yes, Up To 300 ID's |
| Security | IP/MAC Address Filtering, SNMPv3, IPSEC, HTTPS, IEEE802.1x, Department ID (Up To 300), Secured Print |
| Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
