imageCLASS MF449dw
- Print up to 40 ppm
- Print up to 8-1/2" x 14"
- 900-sheet maximum paper capacity
- Supports uniFLOW and uniFLOW Online
- MF449dw Product
- Canon Genuine Toner 057, Standard Yield (3,100 Pages)
- Power Cord
- Fax Cord
- User Software DVD
- Getting Started Guide
- Warranty Card
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageCLASS MF449dw is registered EPEAT Silver.
Workflow Efficiency
- 5" intuitive color touchscreen with smartphone-like usability.
- A unique, customized device experience with Application Library.
- Supports mobile solutions for printing and scanning.1
- Scan and convert documents to searchable digital files through a single-pass duplex document feeder.
- Designed for smaller print jobs with first-print time as fast as 5.3 seconds.
Security
- Low risk of confidential information loss as documents are only stored in short-term memory.
- With imageWARE Enterprise Management Console Device Configuration Manager Plug-in, security settings can be captured and exported to other devices on the same network.2
- Remotely control device access and set rules via optional uniFLOW or uniFLOW Online.
- Limit document distribution by implementing Send-to-Myself-only.
- Verify System at Startup is a process to help verify the validity of the device firmware, and Application Library from unauthorized modifications.
Cost Management
- Leverage optional uniFLOW or uniFLOW Online for full accounting and reporting for Canon and third-party devices, pull printing, and job routing.
- Service parts are designed for machine's life cycle to help minimize need for proactive maintenance and potentially reduce service calls.
- High-capacity, all-in-one cartridge helps reduce overall supply costs.
Device and Fleet Management
- Designed for quick, easy deployment.
- Remote diagnostics for rapid service response.
- Easily monitor device status and consumable levels, observe meter readings, manage settings, and implement security settings.
Quality and Reliability
- Canon's signature reliability and engine technologies keep productivity high and minimize the impact on support resources.
- Designed to achieve maximum uptime with status notifications to help keep supplies replenished.
- Intuitive maintenance videos for common tasks like consumables replacement.
Sustainability
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low-energy consumption.
- Encourage environmentally conscious work practices by providing settings that can help save paper and energy.
- ENERGY STAR® certified and currently rated EPEAT® Silver.3
Manage Output with uniFLOW
Fleet Management Tools
Fast, Single-Pass Duplex Scanning
Easy to Use with Application Library
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.cla.canon.com/cla/en/office/MobileApps. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
- Please reference user manuals for details on settings available to export.
- For latest EPEAT ratings (Gold/Silver/Bronze), please visit https://www.cla.canon.com/cla/en/epeat.
- Includes consumables.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
| Printer Type | Black And White Laser |
| Print Speed | Up To 40 Ppm (Letter); Up To 32 Ppm (Legal) 5 |
| First Print Time | Approx. 5.3 Seconds |
| Printer Language | UFR II, PCL®6, PCLL®5, Adobe PostScript 3L® |
| Print Resolution | 600 X 600 (Dpi) |
| Duplex Print | Automatic (Standard) |
| Print Memory | 1GB |
| Direct Print From Usb | Available From USB Memory (JPEG, TIFF, PDF) |
| Copy Speed | Up To 40 Ppm (Letter); Up To 32 Ppm (Legal) |
| Copy Resolution | 600 X 600 (Dpi) |
| First Copy Time | Approx. 6.2 Seconds |
| Maximum Number Of Copies | Up To 999 Copies |
| Reduction Enlargement | Preset Reductions: 25%, 50%, 64%, 78% Preset Enlargements: 129%, 200%, 400% |
| Copy Size | Platen: Up To Letter ADF: Up To Legal |
| Copy Features | Paper Setting, Favorite Settings, Two-Sided, Original Type Selection, Cancel, N-On-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Fax Resolution | 400 X 400, 200 X 400, 200 X 200, 200 X 100 |
| Memory Capacity | Up To 512 Pages |
| Speed Dials | Max. 281 |
| Group Dialing | Max. 299 Dials |
| Sequential Broadcasting | Max. 310 Addresses |
| Fax Features | RX Mode, Resolution, Two-Sided Original, Density, Sharpness, Favorite Settings, Duplex Fax |
| Memory Backup | Yes |
| Scan Type | Single-Pass Duplexing Automatic Document Feeder |
| Scan Resolution | 300 X 600, 600 X 600 |
| Scan Size | Legal, Letter, Statement |
| Duplex Scan | Yes |
| Output File Formats | Standard: TIFF, JPEG, PDF (Compact, Searchable) Optional: PDF (Encrypted, Digital Signature) |
| Pull Scan | ScanGear MF For TWAIN, WIA, And ICA |
| Standard Paper Source | 250-Sheet Paper Cassette, 100-Sheet Multipurpose Tray |
| Optional Paper Source | 550-Sheet Paper Cassettes (Cassette Unit-AH1) |
| Paper Output | Standard: 65 Sheets |
| Paper Weight | Cassettes: 16 Lb. Bond To 32 Lb. Bond (60 To 120 G/M2) Multipurpose Tray: 16 Lb. Bond To 43 Lb. Bond (60 To 163 G/M2) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" X 5.8" To Max. 8.5" X 14") Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Thick, Bond Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes) |
| Standard Interface | USB 2.0 X2 (Host), USB 2.0 X1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection |
| Wifi Authentication Methods | WEP 64/128 Bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
| Mobile Functions | Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service, Google Cloud Print,™ UniFLOW Secure Mobile Printing |
| Network Management Protocols | IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP |
| Os Compatibility | UFR II/PCL/PS: Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/ Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X V10.8.5 (Or Later) |
| Power Consumption | Maximum: Approx. 1330 W Standby: Approx. 10 W Sleep Mode: Approx. 0.9 W |
| Typical Energy Consumption | 0.34 KWh |
| Dimensions | Standard (Desktop): 17.9" X 18.3" X 15.5" (453 Mm X 464 Mm X 392 Mm) |
| Unit Weight Without With Cartridge | Approx. 35.8 Lb. (16.2 Kg) |
| Package Weight | Approx. 45.9 Lb. (20.8 Kg) 4 |
| Lcd Display | 5" Color Touch-Panel |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
