imageCLASS MF445dw
- Print up to 40 ppm
- Print up to 8-1/2" x 14"
- 900-sheet maximum paper capacity
- MF445dw Product
- Canon Genuine Toner 057, Standard Yield (3,100 Pages)
- Power Cord
- Fax Cord
- User Software DVD
- Getting Started Guide
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Usability
- 5" intuitive color touchscreen with smartphone-like usability.
- A unique, customized device experience with Application Library.
- Create Wi-Fi® Direct hotspot from the printer to establish direct connection to compatible mobile device(s) without the need for an external router.
Quality and Reliability
- Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
- Intuitive maintenance videos for common tasks like consumables replacement.
- Designed to achieve maximum uptime with status notifications to help keep supplies replenished.
Workflow Efficiency
- Supports mobile solutions for printing and scanning4.
- Scan and convert documents to searchable digital files through a single-pass duplex document feeder.
- Designed for small print jobs with first-print time as fast as 5.3 seconds.
Cost Efficiency
- High-capacity, all-in-one cartridge helps reduce overall supply costs.
- Out-of-the-box, standard two-sided printing plus the ability to print multiple pages onto one page helps to reduce paper consumption.
Security
- Low risk of confidential information loss as documents are only stored in short-term memory.
- Security settings can be set behind an administrator log-in.
- Verify System at Startup is a process to help verify the validity of the device firmware, and Application Library from unauthorized modifications.
Sustainability
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and therefore uses less energy.
- Encourage environmentally conscious work practices by providing multiple settings that can help save paper and energy.
- ENERGY STAR® certified and currently rated EPEAT® Silver.1
Easy To Use With Application Library
- Unique to the Canon product line, the Application Library platform allows for one-touch button creation of key functions: Print Template, Standby Slide (screen saver), Scan-to-Preset Destination, ID Card Copy, Consumables Information, Copy (Eco), Copy (Bleed Reduce), Passport Copy, Fax and Store, Name and Scan, Copy (Enhance Text), and Language.
Mobile-Friendly Device Access
- From application-based to cloud-based5 to device native, the imageCLASS MF445dw model offers a variety of methods for printing from a mobile phone or tablet across iOS and Android devices. The Canon PRINT Business application, which supports both platforms, offers access to additional device settings as well as the ability to scan from the printer to a mobile phone or tablet.
Fast, Single-Pass Duplex Scanning
- The imageCLASS MF445dw leverages a single-pass document feeder for two-sided scanning at up to 70 images per minute (ipm) in black and white or up to 26 ipm in color. Scanned files can be converted into multiple file formats, including Hi-Compression PDF and Searchable PDF (OCR).
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- Includes consumables.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
- Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. For more information, including compatibility, please visit https://www.cla.canon.com/cla/en/office/MobileApps. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers terms and conditions.
| Printer Type | Black And White Laser |
| Print Speed | Up To 40 Ppm (Letter); Up To 32 Ppm (Legal) 3 |
| First Print Time | Approx. 5.3 Seconds |
| Printer Language | UFR II, PCL®6, PCL®5, Adobe PostScript 3® |
| Print Resolution | 600 X 600 (Dpi) |
| Duplex Print | Automatic (Standard) |
| Print Memory | 1GB |
| Direct Print From Usb | Available From USB Memory (JPEG, TIFF, PDF) |
| Copy Speed | Up To 40 Ppm (Letter); Up To 32 Ppm (Legal) |
| Copy Resolution | 600 X 600 (Dpi) |
| First Copy Time | Approx. 6.2 Seconds |
| Maximum Number Of Copies | Up To 999 Copies |
| Reduction Enlargement | Preset Reductions: 25%, 50%, 64%, 78% Preset Enlargements: 129%, 200%, 400% |
| Copy Size | Platen: Up To Letter ADF: Up To Legal |
| Copy Features | Paper Setting, Favorite Settings, Two-Sided, Original Type Selection, Cancel, N-On-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Fax Resolution | 400 X 400, 200 X 400, 200 X 200, 200 X 100 |
| Memory Capacity | Up To 512 Pages |
| Speed Dials | Max. 281 |
| Group Dialing | Max. 299 Dials |
| Sequential Broadcasting | Max. 310 Addresses |
| Fax Features | RX Mode, Resolution, Two-Sided Original, Density, Sharpness, Favorite Settings, Duplex Fax |
| Memory Backup | Yes |
| Scan Type | Single-Pass Duplexing Automatic Document Feeder |
| Scan Resolution | 300 X 600, 600 X 600 |
| Scan Size | Legal, Letter, Statement |
| Duplex Scan | Yes |
| Output File Formats | Standard: TIFF, JPEG, PDF (Compact, Searchable) Optional: PDF (Encrypted, Digital Signature) |
| Pull Scan | ScanGear MF For TWAIN, WIA, And ICA |
| Standard Paper Source | 250-Sheet Paper Cassette, 100-Sheet Multipurpose Tray |
| Optional Paper Source | 550-Sheet Paper Cassette (Cassette Unit-AH1) |
| Paper Output | Standard: 65 Sheets |
| Paper Weight | Cassettes: 16 Lb. Bond To 32 Lb. Bond (60 To 120 G/M2) Multipurpose Tray: 16 Lb. Bond To 43 Lb. Bond (60 To 163 G/M2) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" X 5.8" To Max. 8.5" X 14") Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Thick, Bond Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes) |
| Standard Interface | USB 2.0 X2 (Host), USB 2.0 X1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection |
| Wifi Authentication Methods | WEP 64/128 Bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
| Mobile Functions | Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service, Google Cloud Print™, 4, 5 |
| Network Management Protocols | IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP |
| Os Compatibility | UFR II/PCL/PS: Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/ Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X V10.8.5 (Or Later) |
| Power Consumption | Maximum: Approx. 1330 W Standby: Approx. 10 W Sleep Mode: Approx. 0.9 W |
| Typical Energy Consumption | 1.1 KWh |
| Dimensions | Standard (Desktop): 17.9" X 18.3" X 15.5" (453 Mm X 464 Mm X 392 Mm) |
| Unit Weight Without With Cartridge | Approx. 35.8 Lb. (16.2 Kg) |
| Package Weight | Approx. 45.9 Lb. (20.8 Kg) 2 |
| Lcd Display | 5" Color Touch-Panel |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
