imageCLASS MF429x
- imageCLASS MF429x Product
- Power Cord
- Getting Started Guide
- User Software DVD
- Phone Cord
- Standard Cartridge 052 (Preinstalled)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageCLASS MF429x is designed for low volume B&W multifunction needs as a smaller-format complement to imageRUNNER ADVANCE fleets. Most commonly used by a small-sized work team when deployed within a fleet managed environment, the MF429x balances speedy product performance and minimal product maintenance with the ability to add an extra tray where needed. A 5" color touch screen delivers an intuitive out-of-the-box user experience and can be customized by a device administrator to simplify many daily tasks.
- Please reference user manuals for details on settings available to export.
- uniFLOW Scan not supported.
Note: Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. - For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit http://www.cla.canon.com/cla/en/office/MobileApps. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
| Printer Type | Monochrome Laser |
| Print Speed | Up To 40ppm (Letter)/ 32ppm (Legal)4 |
| First Print Time | 6 Seconds Or Less (Letter) |
| Printer Language | UFR II, PCL®6, PCL®5, Adobe PostScript 3® Fonts: PCL:93 Fonts PS: 136 Fonts |
| Print Resolution | Up To 600 X 600 Dpi |
| Duplex Print | Yes |
| Print Memory | 1 GB |
| Direct Print From Usb | Available From USB Memory (JPEG, TIFF, PDF) |
| Copy Type | Monochrome Laser |
| Copy Speed | Up To 40ppm (Letter); Up To 32ppm (Legal) |
| Copy Resolution | Up To 600 X 600 Dpi |
| Original Type | Text/Photo, Text, Photo |
| Halftones | 256 Levels |
| Warm Up Time | 14 Seconds Or Less From Power On |
| First Copy Time | 4 Seconds |
| Maximum Number Of Copies | Up To 999 Copies |
| Reduction Enlargement | 25-400% (1% Increments) Preset Reductions: 25%, 50%, 64%, 78% Preset Enlargements: 129%, 200%, 400% |
| Copy Size | Platen: Up To Letter ADF:; Up To Legal |
| Copy Features | Paper Setting, Favorite Settings, Two-Sided, Original Type Selection, Cancel, N-On-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Fax Resolution | 400 X 400, 200 X 400, 200 X 200, 200 X 100 |
| Memory Capacity | Up To 512 Pages |
| Speed Dials | Up To 281 Dials |
| Group Dialing | Up To 299 Dials |
| Sequential Broadcasting | Up To 310 Addresses |
| Duplex Fax | Yes |
| Fax Features | RX Mode, Resolution, Two-Sided Original, Density,Sharpness, Favorite Settings, Duplex Fax |
| Memory Backup | Yes |
| Scan Type | Single-Pass Duplexing Automatic Document Feeder |
| Scan Resolution | 300 X 600, 600 X 600 Scan Speed (Letter): Single-Sided: 13/38 Ipm (300 X 600 Dpi) (Color/BW) Double-Sided: 26/70 Ipm (300 Dpi) (Color/BW) |
| Scan Size | Legal, Letter, Statement Platen Acceptable Originals: Sheet, Book Single And Double-Sided Scanning Weight: 13-28 Lb. Bond (50-105 G/M2a) |
| Duplex Scan | Yes |
| Compatibility | Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 /Mac OS X V10.8.5 (Or Later) Scan-To-Mobile Devices: Canon PRINT Business |
| Output File Formats | Standard: TIFF, JPEG, PDF (Compact, Searchable) Optional: PDF (Encrypted, Digital Signature) Communication Protocol: File: FTP, SMB Email/IFax: SMTP, POP3, IFax (Simple) Destination: Email/Internet FAX (SMTP), SMB, FTP, Super G3 FAX |
| Scan Features | Push Scan, Pull Scan, Scan To USB Memory Media: Standard USB Memory (JPEG, TIFF, PDF) |
| Pull Scan | ScanGear MF For TWAIN, WIA, And ICA |
| Push Scan Scan To Pc | USB And Network |
| Standard Paper Source | 250-Sheet Paper Cassette, 100-Sheet Stack Bypass |
| Optional Paper Source | 550-Sheet Paper Cassette (Cassette Unit-AH1) |
| Document Feeder | 50 Sheets (20 Lb. Bond) |
| Paper Output | 65 Sheets (Letter, 20 Lb. Bond) |
| Paper Weight | Cassettes: 14 Lb. Bond To 32 Lb. Bond (52 To 120 G/M2a) Stack Bypass: 14 Lb. Bond To 43 Lb. Bond (52 To 163 G/M2a) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive, Custom (Min. 4.1" X 5.8" To Max. 8.5" X 14") Stack Bypass: Letter, Legal, Statement, Executive, Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Thick, Bond Stack Bypass: Thin, Plain, Recycled, Thick, Bond, Label, Envelope |
| Envelope Capacity | Stack Bypass: 10 Envelopes |
| Envelope Types | COM10, Monarch, C5, DL |
| Standard Interface | USB 2.0 X2 (Host), USB 2.0 X1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection |
| Wifi Authentication Methods | Wi-Fi Infrastructure Mode: WEP 64/128 Bit, WPA-PSK (TKIP/AES),WPA2-PSK (AES) Wi-Fi Access Point: WPA2-PSK (AES) |
| Network Functions | IP/MAC Address Filtering, IPSEC, TLS, Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP |
| Os Compatibility | Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/Windows Server 2012 R2/Windows Server 2016 Mac OS X V10.8.5 (Or Later) |
| Other Features | Printing From Mobile And Cloud-Based Services5: Apple® AirPrint®, Canon PRINT Business, Mopria™ Print Service, Google Cloud Print ™ 6, UniFLOW Secure Mobile Printing |
| Power Consumption | Maximum: Approx. 1320 W Standby: Approx. 10 W Sleep Mode: Approx. 0.9 W |
| Typical Energy Consumption | 1.2 KWh (230V) Power Requirements: AC 220-240 V: 3.5A, 50/60 Hz Standards: ENERGY STAR® Qualified, Rated EPEAT Silver 1 Operating Environment: Temperature: 50 To 86° F Humidity: 20 To 80% RH (No Condensation) |
| Dimensions | 17.9"(H) X 18.3"(W) X 15.5"(D) 453 Mm X 464 Mm X 392 Mm |
| Unit Weight Without With Cartridge | 35.8 Lb. (16.2 Kg) W/O Cartridge |
| Package Weight | 45.9 Lb. (20.8 Kg) |
| Duty Cycle | 500-4000 Pages Per Month |
| Security | Standard: Secure Print Optional: Encrypted PDF, User And Device Signatures Authentication: Standard: Embedded Universal Login Manager, Department ID Authentication Optional: UniFLOW, UniFLOW Online |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
