imageCLASS MF429dw
- imageCLASS MF429x Product
- Power Cord
- Getting Started Guide
- User Software DVD
- Phone Cord
- Standard Cartridge 052 (Preinstalled)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageCLASS MF429dw is designed for low volume B&W multifunction needs as a smaller-format complement to imageRUNNER ADVANCE fleets. Most commonly used by a small-sized work team when deployed within a fleet managed environment, the MF429dw balances speedy product performance and minimal product maintenance with the ability to add an extra tray where needed. A 5" color touch screen delivers an intuitive out-of-the-box user experience and can be customized by a device administrator to simplify many daily tasks.
- Please reference user manuals for details on settings available to export.
- uniFLOW Scan not supported.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit http://www.cla.canon.com/cla/en/office/MobileApps. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
| Printer Type | Monochrome Laser |
| Print Speed | Up To 40ppm (Letter)/ 32ppm (Legal)4 |
| First Print Time | 6 Seconds Or Less (Letter) |
| Printer Language | Ufr Ii, Pcl®6, Pcl®5, Adobe Postscript 3® Fonts: Pcl:93 Fonts Ps: 136 Fonts |
| Print Resolution | Up To 600 X 600 Dpi |
| Duplex Print | Yes |
| Print Memory | 1 Gb |
| Direct Print From Usb | Available From Usb Memory (Jpeg, Tiff, Pdf) |
| Copy Type | Monochrome Laser |
| Copy Speed | Up To 40ppm (Letter); Up To 32ppm (Legal) |
| Copy Resolution | Up To 600 X 600 Dpi |
| Original Type | Text/Photo, Text, Photo |
| Halftones | 256 Levels |
| Warm Up Time | 14 Seconds Or Less From Power On |
| First Copy Time | 4 Seconds |
| Maximum Number Of Copies | Up To 999 Copies |
| Reduction Enlargement | 25-400% (1% Increments) Preset Reductions: 25%, 50%, 64%, 78% Preset Enlargements: 129%, 200%, 400% |
| Copy Size | Platen: Up To Letter Adf:; Up To Legal |
| Copy Features | Paper Setting, Favorite Settings, Two-Sided, Original Type Selection, Cancel, N-On-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy Id Card |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Fax Resolution | 400 X 400, 200 X 400, 200 X 200, 200 X 100 |
| Memory Capacity | Up To 512 Pages |
| Speed Dials | Up To 281 Dials |
| Group Dialing | Up To 299 Dials |
| Sequential Broadcasting | Up To 310 Addresses |
| Duplex Fax | Yes |
| Fax Features | Rx Mode, Resolution, Two-Sided Original, Density,Sharpness, Favorite Settings, Duplex Fax |
| Memory Backup | Yes |
| Scan Type | Single-Pass Duplexing Automatic Document Feeder |
| Scan Resolution | 300 X 600, 600 X 600 Scan Speed (Letter): Single-Sided: 13/38 Ipm (300 X 600 Dpi) (Color/Bw) Double-Sided: 26/70 Ipm (300 Dpi) (Color/Bw) |
| Scan Size | Legal, Letter, Statement Platen Acceptable Originals: Sheet, Book Single And Double-Sided Scanning Weight: 13-28 Lb. Bond (50-105 G/M2a) |
| Duplex Scan | Yes |
| Compatibility | Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 /Mac Os X V10.8.5 (Or Later) Scan-To-Mobile Devices: Canon Print Business |
| Output File Formats | Standard: Tiff, Jpeg, Pdf (Compact, Searchable) Optional: Pdf (Encrypted, Digital Signature) Communication Protocol: File: Ftp, Smb Email/Ifax: Smtp, Pop3, Ifax (Simple) Destination: Email/Internet Fax (Smtp), Smb, Ftp, Super G3 Fax |
| Scan Features | Push Scan, Pull Scan, Scan To Usb Memory Media: Standard Usb Memory (Jpeg, Tiff, Pdf) |
| Pull Scan | Scangear Mf For Twain, Wia, And Ica |
| Push Scan Scan To Pc | Usb And Network |
| Standard Paper Source | 250-Sheet Paper Cassette, 100-Sheet Stack Bypass |
| Optional Paper Source | 550-Sheet Paper Cassette (Cassette Unit-Ah1) |
| Document Feeder | 50 Sheets (20 Lb. Bond) |
| Paper Output | 65 Sheets (Letter, 20 Lb. Bond) |
| Paper Weight | Cassettes: 14 Lb. Bond To 32 Lb. Bond (52 To 120 G/M2a) Stack Bypass: 14 Lb. Bond To 43 Lb. Bond (52 To 163 G/M2a) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive, Custom (Min. 4.1" X 5.8" To Max. 8.5" X 14") Stack Bypass: Letter, Legal, Statement, Executive, Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Thick, Bond Stack Bypass: Thin, Plain, Recycled, Thick, Bond, Label, Envelope |
| Envelope Capacity | Stack Bypass: 10 Envelopes |
| Envelope Types | Com10, Monarch, C5, Dl |
| Standard Interface | Usb 2.0 X2 (Host), Usb 2.0 X1 (Device) High-Speed, 10/100/1000base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection |
| Wifi Authentication Methods | Wi-Fi Infrastructure Mode: Wep 64/128 Bit, Wpa-Psk (Tkip/Aes),Wpa2-Psk (Aes) Wi-Fi Access Point: Wpa2-Psk (Aes) |
| Network Functions | Ip/Mac Address Filtering, Ipsec, Tls, Encrypted Communication, Snmp V3.0, Ieee 802.1x, Ipv6, Smtp Authentication, Pop Authentication Before Smtp |
| Os Compatibility | Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/Windows Server 2012 R2/Windows Server 2016 Mac Os X V10.8.5 (Or Later) |
| Other Features | Printing From Mobile And Cloud-Based Services5: Apple® Airprint®, Canon Print Business, Mopria™ Print Service, Google Cloud Print ™ 6, Uniflow Secure Mobile Printing |
| Power Consumption | Maximum: Approx. 1320 W Standby: Approx. 10 W Sleep Mode: Approx. 0.9 W |
| Typical Energy Consumption | 1.3 Kwh (120v) Power Requirements: Ac 120-127 V:6.5 A, 60 Hz Standards: Energy Star® Qualified, Rated Epeat Silver 1 Operating Environment: Temperature: 50 To 86° F Humidity: 20 To 80% Rh (No Condensation) |
| Dimensions | 17.9"(H) X 18.3"(W) X 15.5"(D) 453 Mm X 464 Mm X 392 Mm |
| Unit Weight Without With Cartridge | 35.8 Lb. (16.2 Kg) W/O Cartridge |
| Package Weight | 45.9 Lb. (20.8 Kg) |
| Duty Cycle | 500-4000 Pages Per Month |
| Security | Standard: Secure Print Optional: Encrypted Pdf, User And Device Signatures Authentication: Standard: Embedded Universal Login Manager, Department Id Authentication Optional: Uniflow, Uniflow Online |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
