imageCLASS MF416dw
- imageCLASS MF416dw product
- Standard Cartridge 119
- Power Cord
- Starter Guide / Manuals
- User Software DVD-ROM
- Telephone Cable
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Canon imageCLASS MF416dw ensures efficiency with its 4-in-1 functionality. The MF416dw offers feature rich capabilities in a high quality, reliable printer that is ideal for any small office or home office environment.
The 4-in-1, Canon imageCLASS MF416dw has print, scan, copy and fax capabilities so you can accomplish all necessary tasks with just one machine. With so many easy to use features, such as the intuitive 3.5 inch Color Touch LCD Display, various mobile solutions and security features, your daily workflow will be a breeze.
Your professional quality documents are printed at speeds of up to 35 pages per minute1 in black and white with a quick first print time of 6.3 seconds or less2. Eco friendly, all mode duplexing right out of the box allows you to save on paper and related costs. With ID Card Copy, you can easily create copies of identification cards or other small documents on a single page.
The MF416dw has wireless connectivity, increasing your productivity and allowing you to print from almost anywhere in your home or office6. The device also has built in Wi-Fi direct capability6a, enabling easy connection to mobile devices without a router. The MF416dw is equipped with a variety of easy to use mobile capabilities for printing on-the-go using your compatible mobile device, such as Apple® AirPrint®9, Mopria™ Print Service10 and Google Cloud Print™11. The Canon PRINT Business8 app allows users to print to and scan from the device to compatible iOS or Android devices. With NFC7 technology, you can easily "Touch and Print" to the MF416dw using your compatible mobile device.
Password protected Department ID Management helps business owners manage device usage for up to 300 IDs. Secure Print helps keep confidential documents safe. Using USB Direct Print, you can easily print from and scan to that USB in JPEG, TIFF and PDF formats. The MF416dw also supports host-based UFR II, PCL6, and Adobe® PostScript® languages to provide printing versatility.
The intuitive 3.5-inch Touch LCD Display allows users to navigate through the menu seamlessly. The wide screen and color display is user friendly and easy to read, helping you to complete your business tasks in a breeze.
With the front-loading 250-sheet paper cassette, 50-sheet ADF, 50-sheet multipurpose tray, and additional optional 500-sheet paper cassette (PF-44), your paper handling requirements are covered5.
The MF416dw uses less than 3 watts of energy in Energy Saver Mode, helping you save money on energy costs. The Single Cartridge System combines the toner and drum into 1 unit, making replacement of cartridges simple. This machine uses Canon GENUINE Toner, Cartridge 119 and Cartridge 119 II for higher volume printing.
Easily connect your mobile devices without a router using Wi-Fi Direct Connection.
Print at speeds of up to 35 pages per minute, with your first print in your hands in 6.3 seconds or less.
Print on the go with Canon PRINT Business, Apple AirPrint, Mopria Print Service and Google Cloud Print.
Seamlessly navigate through all the features with the user-friendly 3.5 inch, Color Touch LCD Panel.
Touch and Print with Near Field Communication (NFC) using your compatible mobile Android device.
Supports host-based UFR II, PCL6, and Adobe PostScript languages to provide printing versatility.
Secure Print helps protect the privacy of your printed documents.
Password protected Department ID monitors and controls device usage for up to 300 IDs.
Easily print from, and scan to your USB flash drive in JPEG, TIFF and PDF formats.
Eco-friendly, all mode, two-sided printing out of the box saves paper and related cost.
Generous, expandable paper capacity allows for up to 800 sheets.
Low energy consumption; uses just 2.2 W or less in Energy Saver Mode.
2. May vary depending on the output environment.
3. Letter size, after being restored from energy saver mode.
4. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
4a. Based on ITU-T #1 Chart (standard mode).
5. Based on 20 lb. bond paper.
6. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
6a. Wi-Fi®; is a registered trademark of the Wi-Fi Alliance®;. The Wi-Fi CERTIFIED™ Logo is a certification mark of the Wi-Fi Alliance®;.
7. Requires an Android mobile device with NFC hardware running Android 4.0 or later, and the Canon Print Business app, available for free at Google Play. Canon Print Business app must be open to use tap and print functionality.
8. Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
9. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
10. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
11. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
| Printer Type | Monochrome Laser |
| Print Speed | Up To 17ppm (2-Sided Plain Paper Letter) / 35ppm (1-Sided Plain Paper Letter)1 |
| First Print Time | 6.3 Seconds Or Less (Letter)2 |
| Printer Language | UFR II (Host-Based), PCL6 (5c, XL) / PS |
| Print Resolution | Up To 600 X 600 Dpi; (1200 X 600 Dpi Quality) |
| Maximum Print Size | Up To Legal (8.5 X 14 Inches) |
| Duplex Print | Yes |
| Print Modes | Poster, Booklet, Watermark, Page Composer, Toner Saver |
| Print Memory | 1 GB (Shared) |
| Direct Print From Usb | PDF/JPEG/TIFF Formats |
| Copy Type | Monochrome Laser |
| Copy Speed | Up To 35ppm (Letter) |
| Duplex Copy Speed | Up To 17cpm (Letter) |
| Copy Resolution | Up To 600 X 600 Dpi |
| Original Type | Text/Photo, Text, Photo |
| Halftones | 256 Levels |
| Warm Up Time | 16 Seconds Or Less From Power On |
| First Copy Time | 10 Seconds Or Less3 |
| Recovery Time | 5 Seconds Or Less |
| Maximum Number Of Copies | Up To 999 Copies |
| Reduction Enlargement | 25-400% In 1% Increments |
| Copy Size | Platen: Up To 8.5 X 11, Feeder: 5.1 X 5.5 To 8.5 X 14 |
| Copy Features | Frame Erase, Memory Sort, 2 On 1, 4 On 1, ID Card Copy |
| Modem Speed | Up To 33.6 Kbps (Super G3)4 |
| Fax Resolution | Up To 406 X 391 Dpi (Ultra Fine) |
| Transmission Time | Approx. 3 Seconds Per Page (ECM-JBIG, Transmitting From The Memory At 33.6 Kbps) |
| Memory Capacity | Up To 512 Sheets4a |
| Speed Dials | Up To 281 Dials |
| Group Dialing | 199 Destinations |
| Sequential Broadcasting | 310 Destinations |
| Duplex Fax | Yes |
| Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Fax Forwarding, Dual Access, Remote Reception, PC Fax (Sending Only), DRPD, ECM, Auto Redial |
| Memory Backup | Yes |
| Activity Reports | Fax Activity / Result Reports, Fax Activity Management Reports |
| Pc Fax | Sending Only |
| Fax Forwarding | SMB, E-Mail, FTP, IFax Simple |
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-Bit |
| Scan Resolution | Up To 600 X 600 Dpi (Optical), 9600 X 9600 (Software Interpolated Resolution) |
| Scan Size | Platen: Up Letter, Feeder: Up To Legal |
| Duplex Scan | Yes |
| Compatibility | TWAIN, WIA 2.0, ICA |
| Output File Formats | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
| Scan Features | Push Scan, Pull Scan, Scan To USB |
| Pull Scan | USB And Network |
| Push Scan Scan To Pc | USB And Network |
| Scan To Email | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
| Scan To Smb | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
| Standard Paper Source | 250-Sheet Cassette Plus 50-Sheet Multipurpose Tray5 |
| Optional Paper Source | 500-Sheet Cassette5 (PF-44) |
| Document Feeder | Duplex Auto Document Feeder 50-Sheets5 |
| Paper Output | 150 Sheets (Face Down) |
| Paper Weight | 16-34 Lb. (Bond, Plain Paper) |
| Media Sizes | Letter, Legal, A4, A5, B5, Executive, Statement |
| Media Types | Plain, Heavy, Recycled, Color, Label (20 Sheets, Mp Tray), Envelope |
| Envelope Capacity | 5 (Multipurpose Tray) |
| Envelope Types | Com 10, Monarch, DL, C5 |
| Standard Interface | USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), 802.11 B/G/N Wireless6, Wi-Fi Direct Connection6a, NFC7 (Near Field Communication) |
| Wifi Access Mode | Infrastructure Mode, WPS Easy Set Up |
| Wifi Authentication Methods | WEP 64/128 Bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
| Wifi Encryption Modes | WEP (64/128 Bit), TKIP, AES |
| Wps Easy Setup Support Methods | Push-Button Mode, PIN Code Mode |
| Mobile Functions | Canon PRINT Business8, Apple® AirPrint®9, Mopria™ Print Service10, Google Cloud Print™11 |
| Network Functions | Print, Scan (SMB, E-Mail, FTP), PC Fax |
| Embedded Web Server Remote Ui | Yes |
| Web Browser Support For Remote Ui | IE 7.0 Or Higher, Safari 3.2.1 Or Higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
| Tcp Ip Set Of Application Services | Bonjour(MDNS), HTTP, HTTPS, POP Before SMTP (IPv4, IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
| Network Management Protocols | SNMPv1 (IPv4,IPv6), SNMPv3 (IPv4, IPv6) |
| Os Compatibility | Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012 R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac OS X® 10.6 & Up |
| Cable Included | Power Cord, Phone Cable (USB Not Included) |
| Bundled Software | Printer Driver, Fax Driver, Scanner Driver, Network Scan Utility, MF Scan Utility, Presto! PageManager |
| Power Consumption | Approx: 600 W (During Operation), 9 W (Standby), 2.2 W (Energy Saver / Sleep Mode) |
| Typical Energy Consumption | 1.2 KWh (120V) |
| Dimensions | 15.4"(W) X 18.6"(D) X 17.0"(H) |
| Unit Weight Without With Cartridge | 40.6 Lbs W/O Cartridge, 42.3 W/ Cartridge |
| Package Weight | 51.6 Lbs |
| Cartridge Type | Cartridge 119 (Yields Approximately 2,100 Pages), Cartridge 119II (Yields Approximately 6,400 Pages) Single Cartridge System *Yields Based On ISO/IEC Standard |
| Department Counter | No |
| Lcd Display | 3.5 Inch, Color Touch LCD |
| Duty Cycle | Up To 50,000 Pages Per Month |
| Department Id Management | Yes, Up To 300 ID's |
| Security | IEEE802.1x, SNMPv3, HTTPS, IPSEC, Secure Print (Up To 32 Jobs), Departartment ID Up To 300 IDs |
| Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean |
Cartridge 119 II
Hi-Capacity Black Toner
Cartridge 119
Black Toner
Paper Feeder PF-44
Additional 500 sheet paper cassette, supports up to 8-1/2" x 14" paper size.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
