imageCLASS MF216n
- MF216n product
- Starter Cartridge 137
- Power Cord
- Phone Cable
- User Manual
- Starter Guide
- Canon Drivers
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The convenience of networking through an Ethernet connection allows you to easily share printing, scanning and PC faxing. Documents will be at your fingertips in a flash with print speeds of up to 24 pages per minute1 and a Quick First Print time of 6 seconds or less.2
The MF226dn is equipped with a 35-sheet ADF, which makes scanning and copying multiple documents simple and fast. The 250-sheet3 front-loading paper cassette ensures fuss free paper replenishment and with a cassette capacity that high you will reduce the amount of times you have refill paper.
The MF226dn is a reliable, high quality printer in a small footprint that will fit right in with your small office and home office needs.
With Apple® AirPrint™ you can print right from your iPhone® or iPad®
Print from your Android phone or tablet with Mopria™ Print Service
With Canon Mobile Scanning for Business documents can be scanned from your MF226dn right to your iOS or Android device
The customizable 6-line black-and-white touch panel LCD helps to save time by letting you choose which features are on your home screen
Tiltable control panels gives you the ability to see and navigate through the features from different angles
Print and Copy at up to 24 pages per minute
250-sheet front loading cassette plus a single sheet multipurpose tray
Quiet Mode reduces the operational noise of the machine allowing you to focus on the task at hand
Streamline workflow with 4-in-1 fuctionality - Print, Copy, Scan and Fax
Sleek, compact design fits right on a desktop
- Print speeds are based on internal testing. Print and copy speeds may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
- May vary depending on the output environment.
- Based on 20 lb. Bond paper.
- AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
- Requires Canon Mobile Scanning for Business app, available free on the App StoreSM and Google Play; compatible with iPhone 5S, iPhone 5C, iPhone 5, iPhone 4S, iPhone 4, iPad Air, iPad 4, iPad 3, iPad 2, Original iPad, iPad mini, and iPad mini Retina running OS 5.1 - 7.1. Supports Android Tablets and Phones running OS 4.0 - 4.4.2
- Quiet Mode may affect processing speed and may not lower all sound. Quiet Mode is only compatible with certain paper sizes or types. Special Mode has higher priority than Quiet Mode.
- Letter-sized, after being restored from Energy Saver mode.
- The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
- Based on ITU-T #1 Chart (Standard mode).
- Requires Canon Mobile Printing app, available free on the App StoreSM and Google Play; compatible with iPhone 5S, iPhone 5C, iPhone 5, iPhone 4S, iPhone 4, iPad Air, iPad 4, iPad 3, iPad 2, Original iPad, iPad mini, and iPad mini Retina running OS 5.1 - 7.1.1. Supports Android Tablets and Phones running OS 3.0 - 4.4
- Mopria Print Service, available free in the Google Play store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
| Printer Type | Monochrome Laser |
| Print Speed | Up To 24ppm (1-Sided Plain Paper Letter) 1 |
| First Print Time | 6 Seconds Or Less (Letter)2 |
| Printer Language | UFR II LT (Host-Based) |
| Print Resolution | Up To 600 X 600 Dpi (1200 X 1200 Dpi Quality) |
| Maximum Print Size | Up To Legal |
| Duplex Print | No |
| Print Modes | Watermark, Toner Saver, Page Composer |
| Print Memory | 256 MB (Shared) |
| Copy Type | Monochrome Laser |
| Copy Speed | Up To 24cpm (Letter) |
| Copy Resolution | Up To 600 X 600 Dpi |
| Original Type | Text/Photo, Photo, Text |
| Halftones | 256 Levels |
| Warm Up Time | Approximately 13.5 Seconds |
| First Copy Time | Approximately 9 Seconds7 |
| Recovery Time | Approximately 2 Seconds |
| Maximum Number Of Copies | 99 Copies |
| Reduction Enlargement | 25%, 50%, 64%, 78%129%, 200%, 400% |
| Zoom | 25 - 400% In 1% Increments |
| Copy Size | Platen: Up To Letter ADF: Up To Legal |
| Copy Features | Collate 2 On 1 4 On 1 ID Card Copy |
| Copy Memory | 256 MB (Shared) |
| Modem Speed | Up To 33.6 Kbps (Super G3)8 |
| Fax Resolution | Up To 200 X 400 Dpi (Super Fine) |
| Transmission Time | JBIG (Approx. 3 Seconds) |
| Memory Capacity | Up To 256 Sheets9 |
| Speed Dials | 100 Coded Dials |
| Group Dialing | 103 Destinations |
| Sequential Broadcasting | 114 Destinations |
| Duplex Fax | No |
| Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial |
| Activity Reports | Activity Result & Activity Management |
| Pc Fax | Sending Only |
| Fax Forwarding | Yes |
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-Bit |
| Scan Resolution | Up To 600 X 600 Dpi (Optical) 9600 X 9600 (Interpolated) |
| Scan Size | Platen: Up To Letter ADF:Up To Legal |
| Duplex Scan | No |
| Compatibility | TWAIN, WIA |
| Scan Features | Push Scan, Pull Scan |
| Pull Scan | USB And Network |
| Push Scan Scan To Pc | USB And Network |
| Standard Paper Source | 250-Sheet Cassette Plus 1-Sheet Multipurpose Tray3 |
| Document Feeder | 35-Sheet Duplex3 |
| Paper Output | 100 Sheets (Face Down) |
| Paper Weight | 16-43 Lb. Bond (Cassette) 16-43 Lb. Bond (Multipurpose Tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, Executive, Statement |
| Media Types | Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope, Index Card |
| Envelope Capacity | 20 Envelopes |
| Envelope Types | Com 10, Monarch, DL, C5 |
| Standard Interface | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet |
| Mobile Functions | Canon Mobile Printing10, Apple AirPrint&Trade;4, Mopria&Trade; Print Service,12 Canon Mobile Scanning For Business5 |
| Embedded Web Server Remote Ui | Yes |
| Web Browser Support For Remote Ui | Microsoft Internet Explore 7.0 Or Higher, Safari 3.2.1 Or Higher |
| Os Compatibility | Windows&Reg; 8.1, Windows 8, Windows 7, Windows Server&Reg; 2012, Windows Server 2012 R2, Windows Server 2008 R2, Windows Server 2008, Windows Vista&Reg;, Windows Server 2003, Windows&Reg; XP, Mac&Reg; OS X 10.5.8 & Up |
| Cable Included | Power Cord (USB Not Included) |
| Bundled Software | Printer Driver, Fax Driver, Scanner Driver, MF Toolbox, Presto! PageManager, AddressBookTool,Toner Status |
| Power Consumption | Max: Approx. 1,190W During Operation: Approx. 500W Standby: Approx. 5.4W Energy Saver: Approx. 1.6W |
| Typical Energy Consumption | 0.7kWh |
| Dimensions | 15.4" (W) X 14.6" (D) X 14.2" (H) |
| Unit Weight Without With Cartridge | 25.4 Lbs. (W/O Cartridge) 26.7 Lbs. (W/Cartridge) |
| Package Weight | Approx. 38.6 Lbs. |
| Cartridge Type | Cartridge 137 (Yields Approximately 2,400 Pages) Single Cartridge System *Yields Based On ISO/IEC Standard |
| Lcd Display | 6-Line BW LCD Touch |
| Duty Cycle | Up To 8,000 Pages Per Month |
| Security | IP Filtering, MAC Address Filtering |
| Languages | English, French, Spanish, Portuguese |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
