imageCLASS MF113w
- imageCLASS MF113w product
- Cartridge 047 Black, Starter - 700 Yield
- Drum 049 - 12,000 Yield
- Power Cord
- Starter Guide
- User Software DVD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Designed for home and small offices, the imageCLASS MF113w balances speedy performance and minimal maintenance. Print, scan, copy help you accomplish necessary tasks with just one machine.
The imageCLASS MF113w is registered EPEAT Silver.
Workflow Efficiency
- Supports mobile solutions1 for printing and scanning.
- Scan and convert documents to searchable digital files.
- Designed for small print jobs with first-print time as fast as 9 seconds.
User Experience
- 5-Line, black and white LCD panel allows you to navigate through the menu seamlessly and customize settings to access the features you use most.
- Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
Sustainability
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and therefore uses less energy.
- Encourages environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
- ENERGY STAR® certified and currently rated EPEAT® Silver.2
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit www.cla.canon.com/cla/en/office/MobileApps.
- For current EPEAT ratings (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- Includes consumables.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
| Printer Type | Black & White Laser Multifunctional |
| Print Speed | Up To 23 Ppm (Letter); Up To 17.9 Ppm (Legal) 4 |
| First Print Time | Approx. 9 Seconds |
| Printer Language | UFR II |
| Print Resolution | 600 X 400 (Dpi) |
| Maximum Print Size | Cassettes: Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Print Memory | 32 MB |
| Copy Speed | Up To 23 Ppm (Letter); Up To 17.9 Ppm (Legal) |
| Copy Resolution | 600 X 400 (Dpi) |
| First Copy Time | Platen: 9 Seconds Or Less |
| Reduction Enlargement | Magnifications: 25% - 400% (1% Increments) Preset Reductions: 25%, 50%, 64%, 78% Preset Enlargements: 129%, 200%, 400% |
| Copy Size | Platen: Up To Letter |
| Scan Type | Color Contact Image Sensor |
| Scan Resolution | 600 X 400 (Dpi) |
| Scan Size | Platen: Sheet, Book |
| Duplex Scan | Yes |
| Compatibility | ScanGear MF For TWAIN, And WIA |
| Standard Paper Source | Standard: 150-Sheet Paper Cassette |
| Paper Output | Standard: 100 Sheets |
| Paper Weight | Cassette: 16 Lb. Bond To 43 Lb. Bond ( 60 To 163 G/M2) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Plain, Recycled, Thick, Bond, Label, Envelope |
| Standard Interface | USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi® 802.11 B/G/N |
| Wifi Authentication Methods | Wi-Fi Infrastructure Mode: WEP 64/128 Bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) Wi-Fi Access Point: WPA2-PSK (AES) |
| Mobile Functions | Apple® Airprint,® Canon Print Business1, Mopria™ Print Service, Google Cloud Print™6 |
| Network Management Protocols | Standard: IP/MAC Address Filtering, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6 |
| Os Compatibility | Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 / Mac OS X V10.9.5 (Or Later) |
| Power Consumption | Maximum: Approx. 850 W Standby: Approx. 4.0 W Sleep Mode: Approx. 0.8 W |
| Typical Energy Consumption | 0.6 KWh Power Requirements: AC 120-127 V:6.5 A, 60 Hz AC 220-240 V:6.5 A, 60 Hz Standards: ENERGY STAR® Qualified, Rated EPEAT Silver 2 Operating Environment: Temperature: 50 To 86° F Humidity: 20 To 80% RH (No Condensation) |
| Dimensions | Standard (Desktop): 14.9" X 12.8" X 10.2" (378 Mm X 325 Mm X 259 Mm) |
| Unit Weight Without With Cartridge | Approx. 18.5 Lb. (8.4 Kg) Without Cartridge |
| Package Weight | Approx. 33 Lb.(15.0 Kg)3 |
| Lcd Display | 5-Line LCD |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
