imageCLASS LBP7680Cx
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Powerful Processing Engine:
Superb Image Quality:
New User Interface:
USB Direct Print:
SD Card:
Front-Load Access:
Consistent imageRUNNER Print Driver Architecture:
Printing Options:
RAPID Fusing System:
Unleash new workflows with MFP integration:
Optimized for fleets and Managed Document Services (MDS):
| Model Name | Color ImageCLASS LBP7680Cx |
| Type | Desktop Laser Printer Printing Method: Electrophoto Method (RAPID Fusing System) |
| Developing System | Contact Developing System |
| Image Server Memory | Standard 768MB RAM CPU: ARM11-528 MHz + ARM9-264 MHz |
| Printing Resolution | UFR II/PCL 5e/6/PS 3: 600 X 600 Dpi 2400 (Equivalent) X 600 Dpi Engine: 600 X 600 Dpi |
| Halftone | 256 Gradation (Continuous-Tone) |
| Letter | (B/W, Color): Up To 21 Ppm (Letter) |
| First Copy Time | 16 Seconds Or Less |
| Maximum Original Size | Legal (8-1/2" X 14") |
| Standard Paper Capacity | 250 Sheet Paper Cassette (20 Lb. Bond) Optional: 250 Sheet Paper Cassette |
| Manual Bypass | 50 Sheet Multi-Purpose Tray |
| Maximum Paper Capacity | 550 Sheets |
| Cassette | Legal, Letter, Executive, Statement, Foolscap, Index Card, Envelope DL, Envelope COM-10, Envelope ISO-C5, Envelope ISO-B5, And Envelope Monarch, Custom Sizes (Width 4-1/8" To 8-1/2", Length 5-7/8" To 14") |
| Bypass | Legal, Letter, Executive, Statement, Foolscap, Index Card, Envelope ISO-C5, Envelope ISO-B5, And Envelope Monarch, Custom Sizes (Width 3" To 8-1/2", Length 5"To 14") |
| Cassette | 60 - 176 G/M2 (16 Lb. Bond To 43 Lb. Bond) |
| Bypass | 60 - 176 G/M2 (16 Lb. Bond To 47 Lb. Bond) |
| Duplexing | Standard Automatic Trayless Duplexing (Legal, Letter) Paper Output: Face Down Output Capacity: Face Down Output Tray: Approx. 125 Sheets |
| Warm Up Time | 29 Seconds Or Less |
| Power Requirements | 220-240V, 50/60Hz Plug: NEMA 5-15P Power Consumption: Operating: 440W Stand By: 22W Deep Sleep Mode: 1W |
| Dim | 13-5/8" X 16-5/16" X 19-3/4" (350mm X 414mm X 499mm) Installation Space (H X W X D): 13-5/8" X 16-5/16" X 42-1/8" (350mm X 414mm X 1069mm) |
| Weight | Approx. 49.4 Lb.(22.4 Kg)* |
| Estimated Toner Yield | Black (Starter): 3,400 Images (1,200 Images)** Y/M/C Starter: 2,900 Images (1,400 Images)** |
| Description | Paper Feeder Unit PF-701 |
| Acceptable Originals | Legal, Letter, Executive, Statement, Foolscap, Index Card, Envelope DL, Envelope COM-10, Envelope ISO-C5, Envelope ISO-B5, And Envelope Monarch, Custom Sizes (Width 4-3/16" To 8-1/2". , Length 5-7/8" To 14".) |
| Capacity | 250 Sheets (20 Lb. Bond) |
| Dimensions | 4-15/16" X 16-1/8" X 20-1/2" (115mm X 409mm X 520mm) |
| Weight | Approx. 12.1 Lb.(4 Kg) |
| Pdl Support | (Standard): UFR II, PCL5c/6, Adobe PostScript 3UFR II, PCL 5c/6, Adobe PS3: Windows® (XP/Windows Vista® / Windows 7/Server 2003/Server 2008/ Server 2008 R2/Small Business Server 2011), Windows Terminal Servers (Server 2008/Server 2008 R2), Small Business Server 2011, Microsoft Failover Cluster (Windows Server 2003/Server 2003 R2/Server 2008/Server 2008 R2), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 2.0/2.1/3.0/4.0/5.0/5.5), Macintosh (OS X 10.4.9 Or Later) (UFR II/PS Only), VMware (VSphere 4/5), SAP (PCL/PS Only) |
| Interface Connections | Shared 10BASE-T/100BASE-TX/1000BASE-T Other Interface: USB(Device)X1 / USB(Host)X2 User Interface: LCD 22 Characters X 5 Line, 8 LED Indicators, 12 Operation Keys* Excluding The CRG. ** Toner Cartridge Yield In Accordance With ISO/IEC 19798 ♦ One Paper Feeder Unit Can Be Added. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
