imageCLASS LBP6780x
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
| Model Name | ImageCLASS LBP6780x |
| Type | Desktop Laser Printer Printing Method: Electrophoto Method (RAPID Fusing System) |
| Developing System | Contact Developing System Standard PDL: UFR II, PCL 5e/6, Adobe PostScript 3 |
| Image Server Memory | Standard/Maximum: 768MB RAM CPU: ARM11-528MHz + ARM9-264MHz |
| Network Interface Connection | Shared 10/100/1000Base-T (RJ-45) |
| Other Interface | USB Hi-Speed (Device) X1 USB Hi-Speed (Host) X2 User Interface: LCD 22 Characters X 5 Lines 8 LED Indicators 12 Operation Keys |
| Printing Resolution | UFR II, PCL 5e/6, PostScript 3: 600 X 600 Dpi, 1200 X 1200 Dpi Equivalent, 2400 Equivalent X 600 Dpi Engine: 600 X 600 Dpi Print Drivers: UFR II, PCL 5e/6, PostScript 3: Windows® (XP/Windows Vista®/Windows 7/Windows 8/Server 2003/Server 2008/Server 2008 R2/Small Business Server 2011/Server 2012), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/Small Business Server 2011), Microsoft® Failover Cluster (Server 2003/Server 2008/Server 2008 R2),Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/5.6), Macintosh® (OS X 10.5.8 Or Later), VMware (VSphere 4, 5), SAP (PCL 5e/6, PostScript 3 Only) |
| Halftone | 256 Gradations (Continuous-Tone) |
| Letter | (BW): Up To 42 Ppm |
| First Copy Time | 8.5 Seconds |
| Maximum Original Size | Legal (8-1/2" X 14") |
| Standard Paper Capacity | 500-Sheet Paper Cassette (20 Lb. Bond) 100-Sheet Multi-Purpose Tray |
| Optional | 500-Sheet Paper Cassette (Up To 2) |
| Maximum Paper Capacity | 1,600 Sheets |
| Output Paper Capacity | Face-Down Paper Output: Face-Down/Face-Up Output Tray: Approx. 250 Sheets Face-Up Output Slot: Approx. 50 Sheets |
| Cassette | Legal, Letter, Executive, Custom Sizes (Width: 4-1/8" To 8-1/2"; Length: 5-7/8" To 14") |
| Bypass | Legal, Letter, Executive, Index Card, Custom Sizes (Width: 3" To 8-1/2"; Length: 5" To 14") And Envelopes |
| Cassette | 16 Lb. Bond To 32 Lb. Bond (60 - 120g/M2) |
| Bypass | 16 Lb. Bond To 53 Lb. Bond (60 - 199g/M2) |
| Duplexing | Standard Automatic Trayless Duplexing (Legal, Letter) |
| Warm Up Time | 28 Seconds Or Less |
| Power Requirements | 220-240V, 50/60Hz |
| Power Consumption | (Approx., Average): Operating: 700W Standby: 14W Deep Sleep Mode: Approx. 0.9W |
| Plug | NEMA 5-15P |
| Dim | 13-5/8" X 17-7/8" X 16-3/4" (345mm X 454mm X 424mm) |
| Installation Space | 17-7/8" X 28-1/4" (454mm X 622mm) (When Multi-Purpose Tray Is Extended) |
| Weight | Approx. 36.6 Lb. (16.6kg)* |
| Estimated Toner Yield | Black (Starter): 6,000 Standard Pages** Black: 12,500 Standard Pages** |
| Description | Paper Feeder Unit PF-45 (Optional) |
| Acceptable Originals | Legal, Letter, Executive, Statement, Custom Sizes (Width: 4-1/8" To 8-1/2" Length: 5-7/8" To 14") |
| Capacity | 500 Sheets (20 Lb. Bond) |
| Dimensions | 5-5/8" X 17-7/8" X 18-1/2" (141mm X 454mm X 470mm) |
| Weight | Approx. 12.1 Lb. (5.5kg)Other Optional Accessories
** Toner Cartridge Yield In Accordance With ISO/IEC 19752. ♦ Up To Two Paper Feeder Units Can Be Added. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
