imageCLASS LBP6230dw
- imageCLASS LBP6230dw product
- Starter Cartridge 126
- Power Cord
- USB Cable
- User Manual
- Starter Guide
- Canon Drivers
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The LBP6230dw is a compact laser printer that delivers professional quality output at blazing fast speeds with impressive features including mobile printing, automatic 2-sided printing and wireless1 connectivity. It is also easy to use and is compact enough to fit right on a desktop for your personal, small office or home office needs.
The free Canon Mobile Printing2 app allows you to print right from your iOS or Android device so you can stay productive when on the go. With fast print speeds of up 25 pages per minute3 and a Quick First Print of approximately 6 seconds4 you will spend less time waiting around for your documents to arrive.
The LBP6230dw is equipped with a 250-sheet5 front loading paper cassette so replacing paper will be a breeze. With automatic two-sided printing you can cut back on paper usage in your home or office.
For the best quality, use Canon GENUINE Cartridge 126 which is designed specifically for use with the LBP6230dw. It helps to improve image processing and precise character and overall image quality. The toner and drum are both combined into just one easy to replace cartridge.
Easily print from a mobile device with the free Canon Mobile Printing app
Limit interruptions with the 250-sheet standard paper cassette
Space-saving, compact design is a perfect fit for a desktop
Save time with print speeds of up to 25 pages per minute, first print in approximately 6 seconds
Reduce paper use with automatic two-sided printed right out of the box
- Wireless performance may vary based on terrain and distance between printer and wireless network clients.
- Requires Canon Mobile Printing app, available free on the App StoreSM and Google Play; compatible with iPhone 5S, iPhone 5C, iPhone 5, iPhone 4S, iPhone 4, iPad Air, iPad 4, iPad 3, iPad 2, Original iPad, iPad mini, and iPad mini Retina running OS 5.1 - 7.1.1. Supports Android Tablets and Phones running OS 3.0 - 4.4.
- Print speeds are based on internal testing. Print and copy speeds may vary depending on the number of copies selected, as well as on the settings for size, type, and orientation of paper.
- May vary depending on the output environment.
- Based on 20 lb. Bond Paper.
| Printer Type | Monochrome Laser |
| Print Speed | Up To 16 Ppm (2-Sided Plain Paper Letter)3 Up To 26 Ppm (1-Sided Plain Paper Letter)3 |
| First Print Time | Approximately 6 Seconds4 |
| Printer Language | UFR II LT (Host-Based) |
| Print Resolution | Up To 600 X 600 Dpi (2400 X 600 Dpi Quality) |
| Duplex Print | Yes |
| Print Modes | Collate, Poster, Booklet, Watermark, Toner Saver, Page Composer |
| Print Memory | 64 MB |
| Standard Paper Source | 250-Sheet Cassette Plus 1-Sheet Multipurpose Tray5 |
| Paper Output | 100 Sheets (Face Down) |
| Paper Weight | 16-43 Lb. Bond (Cassette) 16-43 Lb. Bond (Multipurpose Tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, Executive |
| Media Types | Plain Paper, Heavy Paper, Transparency, Label, Index Card, Envelope |
| Envelope Capacity | Multipurpose Tray: 20 Sheets Stack Bypass: 1 Sheet |
| Envelope Types | Com 10, Monarch, DL, C5 |
| Standard Interface | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet, 802.11 B/G/N Wireless1 |
| Wifi Access Mode | Infrastructure Mode |
| Wifi Authentication Methods | Open System, Shared Key, WPA-PSK, WPA2-PSK |
| Wifi Encryption Modes | WEP (64/128 Bit), TKIP, AES |
| Wps Easy Setup Support Methods | Push-Button Mode, PIN Code Mode |
| Mobile Functions | Canon Mobile Printing2 |
| Embedded Web Server Remote Ui | Yes |
| Web Browser Support For Remote Ui | Internet Explorer 7.0 Or Higher, Safari 3.2.1 Or Higher |
| Print Protocols | LPD (IPv4,IPv6), RAW (IPv4,IPv6), WSD-Print (IPv4,IPv6) |
| Tcp Ip Set Of Application Services | (IPv4) RARP, BOOTP, DHCP, DNS, DynamicDNS, MulticastDNS, WINS (IPv6) DHCP, DNS, DynamicDNS, MulticastDNS |
| Network Management Protocols | SNMPv1(IPv4,IPv6), SNMPv3(IPv4,IPv6), SLP(IPv4,IPv6) |
| Os Compatibility | Windows 8.1, Windows 8, Windows 7, Windows Server® 2012, Windows Server 2008 R2, Windows Server 2008, Windows Vista®, Windows Server 2003, Windows® XP, Mac® OS X 10.6 & Up, Linux, Citrix (FR2 And Later) |
| Cable Included | Power Cord, USB Cable |
| Bundled Software | Canon Drivers, Network Setup Tool |
| Power Consumption | Max: 930W Or Less During Operation: Approx. 400W Standby: Approx. 1.4 W (USB/Wired) Approx. 2.1W (Wireless) Energy Saver: Approx. 0.9 W (USB/Wired) Approx. 1.6 W (Wireless) Power Requirement: AC 110-120V, 50/60Hz |
| Typical Energy Consumption | 0.7 KWh/W |
| Dimensions | 14.9" (W) X 11.5" (D) X 9.6" (H) |
| Unit Weight Without With Cartridge | 15.4 Lbs. (W/O Cartridge) 16.7 Lbs. (W/ Cartridge) |
| Package Weight | Approx. 19.8 Lbs. |
| Cartridge Type | Cartridge 126 (Yields Approximately 2,100 Pages) Single Cartridge System *Yields Based On ISO/IEC Standard |
| Duty Cycle | Up To 8,000 Pages Per Month |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
