imageCLASS LBP6030
- imageCLASS LBP6030 machine
- Starter Cartridge 125
- Setup Instructions
- Manuals
- Power Cord
- User Software CD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Reliable Laser Quality
Delivering 18 pages-per-minute1, Quick First Print of approximately less than 8 seconds, advanced print modes, and a 150-sheet front loading cassette, the imageCLASS LBP6030 can satisfy any small business or home office user looking for quality laser output.
Single Cartridge System
To deliver high-quality prints, the LBP6030 incorporates the Canon Single Cartridge System, which combines the toner, drum and development unit in one easy-to-replace cartridge, resulting in excellent image quality retention and eliminating the complication and warehousing of separate toner and drum consumables.
Desktop Solution
The sleek and compact design of the LBP6030 allows it to conveniently fit on any home desk or table helping you make the most of your workspace and increase productivity.
Print in black & white at up to 18 pages-per-minute (ppm)
Quick First Print provides first print time of approximately 8 seconds or less
Efficient energy saving mode; approximately 0.8 W of energy used
Advanced Print Modes include Poster, Watermark, and Toner Saver
150-sheet front-loading paper cassette
Single Cartridge System for cost-efficient supplies replenishment
Generation Green is Canon's new environmental initiative. This program encompasses imageCLASS Laser Printers, PIXMA Inkjet Printers, and Scanners. Generation Green is designed to provide business partners, customers and consumers a way to learn about the environmentally-friendly approach Canon takes in designing many of its current and future products. The imageCLASS LBP6000 has the following Generation Green characteristics:
- Auto-Duplexing - Using automatic 2-sided printing and copying can save you up to 50% of your paper supply.
- Energy Saving Mode - When the imageCLASS LBP6000 enters Energy Saving Mode, it has a low power consumption of 1.3 watts of energy in Energy Saving Mode.
- On-Demand SURF Technology - On-Demand (Surface Rapid Fixing) technology uses a linear ceramic heater that heats instantly for fast warm up speeds and Quick First Prints. This results in up to a 75% reduction in energy consumption compared to conventional roller-fixing systems.
- Toner Saving Mode - When the imageCLASS LBP6000 is switched into the toner saving mode, it allows for up to a 20% more economical toner usage.
- Toner Cartridge Recycling Program - Canon was the first in the printing industry to create a toner cartridge recycling program. Canon toner cartridges are 100% recovered with zero landfill waste.
- Hardware Recycling Program - Canon is committed to the world community and the belief that we are building a better world for future generations. We want to work with our customers to ensure appropriate recycling of certain imageCLASS products to help improve the environment and our local communities.
- ENERGY STAR® - Qualified products are 25% more efficient than conventional models. By using less energy these products reduce greenhouse gas emissions and save energy as well as money. The imageCLASS LBP6000 automatically enters low-power mode when not in use.
- RoHS Compliant - This is a directive from the European Union that restricts the use of hazardous materials found in electronic products. This product restricts the use of cadmium, mercury, lead, hexavalent chromium, Polybrominated Biphenyls (PBB), and Polybrominated Diphenyl Ethers (PBDE).
- ISO 14001 - We currently hold the largest Consolidated Certification to the ISO 14001 Standard for our Environmental Management Systems in the world with over 700 Canon companies certified to the Standard.
To learn more about Generation Green, visit www.cla.canon.com/en_US/app/html/GenerationGreen/.
- All ppm's based on letter-sized output unless otherwise noted.
- Based on 20 lb. paper.
| Printing Method | Monochrome Laser |
| Toner Compatibility | Canon Cartridge 125 CRG Yield* (1,600) *Yield Based On ISO/IEC Standard |
| Buffer Ram | 32MB (Buffer Memory) |
| Paper Compatibility | Plain Paper, Heavy Paper, Transparency, Label, Envelope |
| Print Features | Print Modes Toner Saver, Poster, Watermark |
| Paper Weights | 16 To 43 Lb. Bond |
| Output Tray Capacity | 100 Sheets (Face Down)2 |
| Os Compatibility | Windows® 8.1, Windows 8, Windows 7, Windows Server® 2012, Windows Server® 2008, Windows Server® 2008 R2, Windows Vista®, Windows Server 2003, Windows XP, Mac® OS X 10.4.9 Y Posteriores, Linux And Citrix. |
| Standard Interface | USB Device 2.0 Hi-Speed |
| Optional Interface | Wireless/Wired MFP Print Server C-6700WG3 |
| Software Included | Canon Drivers |
| Power Source | 120V-127V, 60Hz 220V-240V, 50/60Hz |
| Power Consumption Approx | Max.: 320 W Or Less (120V) 330 W Or Less (230V) Standby: 1.8 W Energy Saver: 0.8 W |
| Weight | 11 Lbs. (Without Cartridge); 12.1 Lbs. (With Cartridge) |
| Noise | During Operation: 49.3 DB (Sound Pressure ), 6.5 B Or Less (Sound Power) During Standby: Inaudible |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
