imageCLASS LBP253x
- imageCLASS LBP253x product
- Power Cord
- Standard Cartridge 119
- Manuals
- User Software DVD-ROM
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Canon imageCLASS LBP253x is an easy to use, single function laser printer that is an ideal solution for a small office or home office environment. With so many easy to use features, such as the intuitive Color Touch LCD Display, various mobile solutions and security capabilities, completing your daily workflow will be a breeze.
The LBP253x features a user friendly, 3.5 inch Touch LCD display, which allows you to navigate through the menus efficiently.
The LBP253x delivers fast, exceptional black and white laser output and prints your professional quality documents at speeds of up to 35 pages-per-minute1 with your first print available in 6 seconds or less2. Eco friendly, automatic duplexing increases your business efficiency by helping your business save on paper costs while saving paper. Your printing needs are covered, with paper handling of up to 250 sheets in a front loading cassette, 50 sheets in the multipurpose tray and an additional 500 sheets in the optional paper cassette, for a total paper capacity of 800 sheets3.
The LBP253x has wireless connectivity and mobile solutions that allow you to keep your business moving forward while on the go. Built in Wi-Fi Direct Connection4a enables easy connection to mobile devices without a router. The LBP253x features mobile capabilities for printing on the go using your compatible mobile device such as Apple® AirPrint®6, Mopria™ Print Service7 and Google Cloud Print™8. The Canon PRINT Business5 app allows users to print to the device from compatible iOS or Android devices. The LBP253x is also equipped with Near Field Communication (NFC9), which allows you to "tap and print" using your compatible mobile Android device.
The LBP253x offers security and a diversity of print features to help you manage your business. Password protected Department ID Management helps business owners manage device usage for up to 300 IDs. Secure Print helps keep printed confidential documents safe, and with USB Direct Print, you can easily print from your USB flash drive in JPEG, TIFF and PDF formats. Additionally, the LBP253x supports PCL 5e/6, Adobe® Postscript® and UFR II printer languages, allowing greater versatility for your printing needs.
The LBP253x uses 1.6 watts or less in Energy Saver Mode, helping you save on energy costs. The Single Cartridge System combines the toner and drum into 1 unit, making replacement of cartridges simple. This printer uses Cartridge 119 Black and Cartridge 119 Black II for higher volume printing.
The LBP253x offers feature rich capabilities in a high quality, compact, reliable printer that is ideal for any office environment.
Wi-Fi Direct Connection enables easy connection from your mobile devices without a router.
Fast print speeds of up to 35 pages per minute, with your first print in your hands in 6 seconds or less.
Easily navigate through all the features with the 3.5-inch, Color Touch-Panel.
Print on the go with Canon PRINT Business, Apple AirPrint, Mopria Print Service, and Google Cloud Print
Supports host-based UFR II, PCL 5e/6 and Adobe PostScript to provide printing versatility for your business.
Eco-friendly, two-sided printing out of the box saves paper and related cost.
Secure Print helps protect the privacy of your printed documents.
Direct Print from USB allows printing from JPEG, TIFF, and PDF formats.
Touch and Print with Near Field Communication (NFC) using your compatible mobile Android device.
Low energy consumption; uses just 1.6 W in wireless, Energy Saver mode.
Generous, expandable paper capacity allows for up to 800 sheets.
2. May vary depending on the output environment.
3. Based on 20 lb. bond paper.
4. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
4a. Wi-Fi®; is a registered trademark of the Wi-Fi Alliance®;. The Wi-Fi CERTIFIED™ Logo is a certification mark of the Wi-Fi Alliance®;.
5. Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
6. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
7. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
8. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
9. Requires an Android mobile device with NFC hardware running Android 4.0 or later, and the Canon Print Business app, available for free at Google Play. Canon Print Business app must be open to use tap and print functionality.
| Printer Type | Monochrome Laser Single Function Printer |
| Print Speed | Up To 35ppm (1-Sided Plain Paper, Letter), Up To 17ppm (2-Sided Plain Paper, Letter)1 |
| First Print Time | 6 Seconds Or Less (Letter)2 |
| Printer Language | UFR II, PCL (5e/6), PS |
| Print Resolution | Default: 600 X 600 Dpi; 1200 X 1200 Dpi (Equivalent) |
| Maximum Print Size | Up To Legal |
| Duplex Print | Yes |
| Print Modes | Toner Saver, Booklet, Poster, Watermark |
| Print Memory | 1GB |
| Direct Print From Usb | Via USB High Speed 2.0, Print File Format: JPEG, TIFF, PDF |
| Standard Paper Source | 250-Sheet Cassette, 50-Sheet Multipurpose Tray3 |
| Optional Paper Source | 500-Sheet Cassette (PF-44) |
| Paper Output | Output Tray (Face Down): Approx. 150 Sheets, Sub-Output Tray (Face Up): 1 Sheet |
| Paper Weight | 16 To 32 Lb. Bond (Plain Paper, Cassette / Multipurpose Tray) |
| Media Sizes | Letter, Legal, A4, A5, A6, B5, Executive, Statement, Foolscap |
| Media Types | Plain, Heavy, Recycled, Color, Label, Envelope, Index |
| Envelope Capacity | 10 Envelopes (Multi-Purpose Tray) |
| Envelope Types | Com 10, Monarch, DL |
| Standard Interface | USB Device High-Speed 2.0, Shared 10/100/1000 BASE-T Ethernet (Network) IEEE 802.11b/G/N Wireless4 , NFC9 (Near Field Communication) |
| Wifi Access Mode | Infrastructure Mode |
| Wifi Authentication Methods | DS-SS System, OFDM System |
| Wifi Encryption Modes | WEP (128 (104)/64 (40) Bit, WPA-PSK (TKIP/AES-CCMP), WPA2-PSK (TKIP/AES-CCMP) |
| Wps Easy Setup Support Methods | Push Button Mode, PIN Code Mode |
| Mobile Functions | Canon PRINT Business5, Apple® AirPrint®6, Mopria™ Print Service7, Google Cloud Print™8 |
| Network Functions | |
| Embedded Web Server Remote Ui | Yes |
| Web Browser Support For Remote Ui | Windows Vista/7/8/8.1/10, Microsoft Internet Explorer 9.0 Or Later, Mac OS X 10.5.8 Or Later (Except For Classic Environment), Safari 5.0.6 Or Later |
| Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
| Tcp Ip Set Of Application Services | Bonjour(MDNS), HTTP, HTTPS, POP Before SMTP (IPv4,IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
| Network Management Protocols | SNMPv1, SNMPv3 (IPv4,IPv6) |
| Os Compatibility | Windows® 10, Windows 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server 2012 R2, Windows Server® 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac® OS X 10.5.8 & Up |
| Other Features | WiFi® Direct Connection: Yes4a |
| Cable Included | Power Cord (USB Not Included) |
| Bundled Software | Printer Driver |
| Power Consumption | Max: 990W Or Less. During Operation: Approx. 570W Or Less. Standby: Approx. 11.7W Or Less. Energy Saver: Approx. 1.6 W Or Less (Wireless) |
| Typical Energy Consumption | 0.9 KWh (230V) |
| Dimensions | 15.9" (W) X 14.9" (D) X 12.5" (H) |
| Unit Weight Without With Cartridge | 25.4 Lbs. (W/O Cartridge), 27.2 Lbs (W/Cartridge) |
| Package Weight | Approx. 34.2 Lbs |
| Cartridge Type | Cartridge 119 Black (Yields Approximately 2,100 Pages) Cartridge 119II Black (Yields Approximately 6,400 Pages) *Yields Based On ISO/IEC Standard |
| Lcd Display | 3.5 Inch Color Touch |
| Duty Cycle | Up To 50,000 Pages Per Month |
| Department Id Management | Yes, Up To 300 ID's |
| Security | IEEE802.1x, SNMPv3, HTTPS, IPSEC, Native Secured Print |
| Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese (Simplified / Traditional), Korean |
Cartridge 119 II
Hi-Capacity Black Toner
Cartridge 119
Black Toner
Paper Feeder PF-44
Additional 500 sheet paper cassette, supports up to 8-1/2" x 14" paper size.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
