imageCLASS LBP228x
- Print up to 40 ppm
- Print up to 8-1/2" x 14"
- 900-sheet maximum paper capacity
- Supports uniFLOW and uniFLOW Online
- LBP228x Product
- Canon Genuine Toner 057, Standard Yield (3,100 Pages)
- Power Cord
- User Software DVD
- Getting Started Guide
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageCLASS LBP228x is registered EPEAT Silver.
Workflow Efficiency
- 5" intuitive color touchscreen with smartphone-like usability.
- A unique, customized device experience with Application Library.
- Supports various mobile printing solutions.1
- Designed for smaller print jobs with first- print-out time as fast as 5.3 seconds.
Security
- Low risk of confidential information loss, since documents are only stored in short-term memory.
- With imageWARE Enterprise Management Console Device Configuration Manager Plug-in, security settings can be captured and exported to other devices on the same network.2
- Remotely control device access and set rules via optional uniFLOW or uniFLOW Online.
- Verify System at Startup is a process to help verify the validity of the device firmware, and Application Library from unauthorized modifications.
Cost Management
- Leverage optional uniFLOW or uniFLOW Online for full accounting and reporting for Canon and third-party devices, pull printing, and job routing.
- Service parts are designed for machine's life cycle to help minimize need for proactive maintenance and potentially reduce service calls.
- High-capacity, all-in-one cartridge helps reduce overall supply costs.
- Out-of-the-box, standard two-sided printing plus the ability to print multiple pages onto one sheet helps to reduce paper consumption.
Device and Fleet Management
- Designed for quick, easy deployment.
- Remote diagnostics for rapid service response.
- Easily monitor device status and consumable levels, observe meter readings, manage settings, and implement security settings.
Quality and Reliability
- Canon's signature reliability and engine technologies keep productivity high and minimize the impact on support resources.
- Designed to achieve maximum up time with status notifications to help keep supplies replenished.
- Intuitive maintenance videos for common tasks like consumables replacement.
Sustainability
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and therefore helps reduce low-energy consumption.
- Encourages environmentally conscious work practices by providing multiple settings that can help save paper and energy.
- ENERGY STAR® certified and currently rated EPEAT® Silver.3
Manage Output with uniFLOW
Fleet Management Tools
Easy to Use with Application Library
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.cla.canon.com/cla/en/office/MobileApps. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
- Please reference user manuals for details on settings available to export.
- For latest EPEAT ratings (Gold/Silver/Bronze), please visit https://www.cla.canon.com/cla/en/epeat.
- Includes consumables.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
| Printer Type | Black And White Laser |
| Print Speed | Up To 40 Ppm (Letter); Up To 32 Ppm (Legal) 5 |
| First Print Time | Approx. 5.3 Seconds |
| Printer Language | UFR II, PCL®6, PCL®5, Adobe PostScript 3® |
| Print Resolution | 600 X 600 Dpi |
| Maximum Print Size | Up To Legal |
| Duplex Print | Yes |
| Print Modes | Secure Print, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations |
| Print Memory | 1 GB |
| Direct Print From Usb | Available From USB Memory (JPEG, TIFF, PDF) |
| Standard Paper Source | 250-Sheet Paper Cassette, 100-Sheet |
| Optional Paper Source | 550-Sheet Paper Cassette (Cassette Unit-AH1) |
| Paper Output | 65 Sheets |
| Paper Weight | Cassettes: 14 Lb. Bond To 32 Lb. Bond (52 To 120 G/M2) Multipurpose Tray: 14 Lb. Bond To 43 Lb. Bond (52 To 163 G/M2) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" X 5.8" To Max. 8.5" X 14") Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Thick, Bond Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes) |
| Standard Interface | USB 2.0 X2 (Host), USB 2.0 X1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection |
| Wifi Access Mode | WEP 64/128 Bit, WPA-PSK (TKIP/ AES), WPA2-PSK (AES) |
| Wifi Authentication Methods | WPA2-PSK (AES) |
| Mobile Functions | Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service, Google Cloud Print,™,6 UniFLOW Secure Mobile Printing |
| Os Compatibility | UFR II/PCL/PS: Windows® 7/Windows 8.1/ Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X V10.9.5 (Or Later) Print |
| Power Consumption | Maximum: Approx. 1300 W, Standby: Approx. 8.5 W, Sleep Mode: Approx. 0.9 W |
| Typical Energy Consumption | 0.33 KWh |
| Dimensions | Standard (Desktop): 17.3" X 14.7" X 12.3" (438 Mm X 373 Mm X 312 Mm) |
| Unit Weight Without With Cartridge | Approx. 20.3 Lb. (9.2 Kg) |
| Package Weight | Approx. 28.7 Lb. (13.0 Kg)4 |
| Cartridge Type | Cartridge 057 Black, Standard - Yields Up To 3,100 Pages, Cartridge 057 Black, High Capacity - Yields Up To 10,000 Pages |
| Lcd Display | 5" Color Touch Panel |
| Security | Authentication: Standard: Embedded Universal Login Manager, Department ID Authentication, Optional: UniFLOW, UniFLOW Online Data: Verify System At Startup Network: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6 Document: Secure Print |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
