imageCLASS LBP214dw
- imageCLASS LBP214dw Product
- Starter Toner 052
- Power Cord
- User Software DVD-ROM
- Starter Guide
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Designed for small-sized businesses, the imageCLASS LBP214dw balances speedy performance, minimal maintenance and the ability to add an extra paper tray.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
- Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
- Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit http://www.cla.canon.com/cla/en/office/MobileApps. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
| Printer Type | Monochrome Laser Single Function Printer |
| Print Speed | Up To 40 Ppm (Letter); Up To 32 Ppm (Legal)2 |
| First Print Time | Approx. 6 Seconds |
| Printer Language | UFR II LT, PCL®6, PCL®5 |
| Print Resolution | 600 X 600 Dpi |
| Maximum Print Size | Up To Legal |
| Duplex Print | Yes |
| Print Memory | 1 GB |
| Direct Print From Usb | Available From USB Memory (JPEG, TIFF, PDF) |
| Warm Up Time | From Power On: 14 Seconds Or Less From Sleep Mode: 4 Seconds Or Less |
| Standard Paper Source | 250-Sheet Paper Cassette, 100-Sheet Paper Bypass |
| Optional Paper Source | 550-Sheet Paper Cassette (Cassette Unit-AH1) |
| Paper Output | Standard: Approx. 65 Sheets (Letter, 20lb. Bond) |
| Paper Weight | Cassettes: 14 Lb. Bond To 32 Lb. Bond (52 G/M2 To 120 G/M2) Stack Bypass: 14 Lb. Bond To 43 Lb. Bond (52 G/M2 To 163 G/M2) |
| Media Sizes | Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" X 5.8" To Max. 8.5" X 14") Stack Bypass: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" X 5" To Max. 8.5" X 14") |
| Media Types | Cassettes: Thin, Plain, Recycled, Thick, Bond Stack Bypass: Thin, Plain, Recycled, Thick, Bond,Label, Envelope (10 Envelopes) |
| Standard Interface | USB 2.0 X2 (Host), USB 2.0 X1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/G/N, Wi-Fi® Direct Connection |
| Wifi Authentication Methods | Wi-Fi Infrastructure Mode: WEP 64/128 Bit, WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES) Wi-Fi Access Point: WPA2-PSK (AES) |
| Network Functions | IP/MAC Address Filtering, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6 |
| Embedded Web Server Remote Ui | Yes |
| Os Compatibility | Windows 7/Windows 8.1/Windows 10/ Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/Windows Server 2012 R2/Windows Server 2016 Mac OS X V10.8.5 (Or Later) |
| Other Features | Printing From Mobile And Cloud-Based Services3: Apple® AirPrint®, Canon PRINT Business, Mopria™ Print Service, Google Cloud Print ™ 4 |
| Cable Included | Power Cord |
| Bundled Software | Printer Driver |
| Power Consumption | Maximum: Approx. 1320 W Standby: Approx. 10 W Sleep Mode: Approx. 0.9 W |
| Typical Energy Consumption | 1.3 KWh (120V)/ 1.2kWh (230V) Power Requirements: AC 120-127 V:6.5 A, 60 Hz/ AC 220-240 V:3.4 A, 50/60 Hz Standards: ENERGY STAR® Qualified, Rated EPEAT Silver 1 Operating Environment: Temperature: 50 To 86° F Humidity: 20 To 80% RH (No Condensation) |
| Dimensions | 15.8"(W) X 14.7"(D) X 9.9"(H) 401 Mm(W) X 373 Mm(D) X 250 Mm(H) |
| Unit Weight Without With Cartridge | Approx. 19.4 Lb. (8.8 Kg). W/O Cartridge |
| Package Weight | Approx. 28.7 Lb. (13.0 Kg) |
| Duty Cycle | Up To 4,500 Pages Per Month |
| Security | Secured Print Authentication: Standard: Department ID Authentication |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
