imageCLASS LBP151dw
- imageCLASS LBP151dw product
- Starter Cartridge 137 (Starter Yield: 1,700 sheets ISO/IEC)
- Power Cord
- Starter Guide
- User Software / Manual DVD
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Canon imageCLASS LBP151dw is an easy to use, wireless, single function laser printer that is an ideal solution for a small or home office environment. The compact, space saving design delivers professional quality output in one small footprint. The LBP151dw delivers exceptional black and white laser output at speeds of up to 28 pages-per-minute1, with your first print in your hands in 8 seconds or less2. This device supports PCL 6 and UFR II LT printer languages, allowing versatility for your printing needs. The Canon imageCLASS LBP151dw is eco-friendly, only using approximately 1.7 watts or less of energy in wireless, energy saving mode, and is set to automatic duplexing right out of the box which helps you save on paper and related costs. The device offers paper handling of up to 250 sheets in a front loading cassette and 1 sheet in the multipurpose tray3. Wireless connectivity4 allows you to print from almost anywhere in your home or office, and you can "Print on the Go" with various mobile features using your compatible mobile device such as Mopria™ Print Service6 and Google Cloud Print™7. The Canon PRINT Business5 app allows you to print to the LBP151dw from compatible iOS or Android devices. The single cartridge system combines the toner and drum into 1 unit, making cartridge replacement simple. This printer uses Canon Genuine Toner, Cartridge 137 Black.
Compact, space saving printer delivers professional quality output in one small footprint.
Print from almost anywhere in your office with Wireless Connectivity.
Fast print speeds of up to 28 pages per minute, and first print out in your hands in 8 seconds or less.
Print on the go with Canon PRINT Business, Mopria Print Service and Google Cloud Print.
Eco-friendly printer features two-sided printing right out of the box, saving paper and related cost.
Low energy consumption; uses just 1.7 W in wireless, Energy Saver mode.
Supports host-based UFR II LT and PCL6 languages to provide printing versatility.
2. May vary depending on the output environment.
3. Based on 20 lb. bond paper.
4. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
5. Canon PRINT Business is a free app available on the App Store®; and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
6. Mopria™ Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
7. Google Cloud Print™ requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
| Printer Type | Monochrome Laser Single Function Printer |
| Print Speed | Up To 28ppm (1-Sided Plain Paper, Letter), Up To 16ppm (2-Sided Plain Paper, Letter)1 |
| First Print Time | 8 Seconds Or Less (Letter)2 |
| Printer Language | UFR II LT (Host Based), PCL6 |
| Print Resolution | 600 X 600 Dpi; 1200 X 1200 Dpi Equivalent |
| Maximum Print Size | Up To Legal |
| Duplex Print | Yes |
| Print Modes | Collate, Poster, Booklet, Watermark, Toner Saver, Page Composer |
| Print Memory | 512 MB |
| Standard Paper Source | 250-Sheet Cassette, 1-Sheet Multipurpose Tray3 |
| Paper Output | Output Tray (Face Down): Approx. 100 Sheets |
| Paper Weight | 16-43 Lb. Bond (Plain Paper, Cassette / Multipurpose Tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, Executive, Statement |
| Media Types | Plain, Heavy, Bond, Label, Envelope, Index Card |
| Envelope Capacity | 20 Envelopes (Cassette), 1 Envelope (Multi-Purpose Tray) |
| Envelope Types | Com 10, Monarch, DL |
| Standard Interface | USB Device High-Speed 2.0, Shared 10/100 BASE-TX (RJ-45) Full Duplex/Half Duplex, IEEE 802.11b/G/N Wireless4 |
| Wifi Access Mode | Infrastructure Mode |
| Wifi Authentication Methods | DS-SS System, OFDM System |
| Wifi Encryption Modes | WEP (128 (104)/64 (40) Bit, WPA-PSK (TKIP/AES-CCMP), WPA2-PSK (TKIP/AES-CCMP) |
| Wps Easy Setup Support Methods | Push Button Mode, PIN Code Mode |
| Mobile Functions | Canon PRINT Business5, Mopria Print Service6, Google Cloud Print™7 |
| Embedded Web Server Remote Ui | Yes |
| Web Browser Support For Remote Ui | Windows Vista/7/8, Microsoft Internet Explorer 7.0 Or Later, Mac OS 10.6 Or Later, Safari 3.2.1 Or Later |
| Supported Network Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
| Tcp Ip Set Of Application Services | Bonjour(MDNS), HTTP, HTTPS, POP Before SMTP (IPv4,IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
| Network Management Protocols | SNMPv1, SNMPv3 |
| Os Compatibility | Windows® 10, 8.1, 8, 7, Windows Vista®,Windows Server® 2012 R2, 2012, 2008 R2, 2008, 2003 R2, 2003, Mac OS 10.5.8 & Up |
| Cable Included | Power Cord |
| Bundled Software | Printer Driver |
| Power Consumption | During Operation: 280 W Or Less, Standby: 2.6 W (Wired) / 3.2 W (Wireless) / 2.5 W (USB), Sleep Mode: 1.4 W (Wired ) / 1.7 W (Wireless) / 1.2 W (USB) |
| Typical Energy Consumption | 0.8 KWh (120V) |
| Dimensions | 15.4" (W) X 13.2" (D) X 9.7" (H) |
| Unit Weight Without With Cartridge | 17.6 Lbs. (W/O Cartridge), 19 Lbs (W/Cartridge) |
| Package Weight | Approx. 23.6 Lbs |
| Cartridge Type | Cartridge 137 Black (Yields Approximately 1,700 Pages) *Yields Based On ISO/IEC Standard |
| Duty Cycle | Up To 15,000 Pages Per Month |
| Security | IEEE802.1x, SNMPv3, HTTPS, IPSEC |
| Languages | English, French, Portuguese, Spanish |
Cartridge 137
Yields approx. 2,400 pages based on ISO/IEC 19752 Standard.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
