EOS RP
- EOS RP Camera Body
- Battery Pack LP-E17
- Battery Charger LC-E17
- Wide Neck Strap
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Get impressive results using the camera’s helpful Feature Assistant and Creative Assist functions. Be imaginative with a number of special scene modes. And quickly adjust settings with the convenient Mode Dial. With its compact size, comfortable grip, vari-angle touchscreen LCD and electronic viewfinder, operation is familiar and easy. Whether you travel near or far, the EOS RP helps you capture your world with the quality, control and ease you crave.
For all their appealing features one of the concerns of using a full-frame camera has been its larger profile, however, the EOS RP is the lightest and smallest Canon EOS full-frame camera to date. * Weighing approx. 440g (body only) while being impressively compact and comfortable to use, the EOS RP is more convenient to carry, shoot with, and store than any previous EOS full-frame camera before.
*As of February 13, 2019.
Engineered to work seamlessly with RF lenses, the EOS RP also maintains complete compatibility with EF and EF-S lenses by using one of three optional Mount Adapters. When using EF-S lenses, the EOS RP even crops automatically to reflect the APS-C sized sensor the lenses are designed for.
* Optional Mount Adapter EF-EOS R is required when using EF/EF-S lenses with an EOS R camera.
54mm Large Diameter and Short Back Focus
The RF mount on the EOS RP camera has a large, 54mm internal diameter - the same as the EOS R - enabling impressive handling and providing increased flexibility for lens design. Thanks to the camera's mirrorless design, the lens's rear element can be much closer to the image plane. This reduced back focus distance, combined with the RF mount's 54mm diameter, helps facilitate lenses of stellar optical quality and stunning performance while enabling innovative compact camera and lens designs.
20mm Flange Focal Distance for Increased Durability
All RF lenses feature a 20mm flange focal distance, which is the distance from the lens mount to the surface of the image sensor. This flange focal distance balances the benefits of short back focus with the engineering requirements necessary for mount stability. Accordingly, the RF mount's flange focal distance ensures excellent optical performance while maintaining the mount rigidity and camera durability necessary for real-world operation.
12 Pins for Quickly Communicating Large Amounts of Information
With a robust 12 pin connection between the camera and the lens, the EOS RP camera and RF lenses are able to communicate at a high speed, transferring a large amount of data and information for incredibly fast AF, plus enhanced image stabilization and optimization.
Variety of Mount Adapter Options for Expanded Compatibility with EF/EF-S Lenses
Mount adapters, such as the Mount Adapter EF-EOS R, deliver seamless connections between the EOS RP camera and EF and EF-S lenses with all functions intact. Offering L series level weather and dust sealing, the Mount Adapter EF-EOS R is even compatible with EF extenders like the Extender EF 1.4x III to extend your camera's optical reach. Beyond enabling use of EF and EF-S lenses on the EOS RP camera, the Control Ring Mount Adapter EF-EOS R and the Drop-in Filter Mount Adapter EF-EOS R add functions that open up a number of new possibilities for creative image capture.
26.2 Megapixel Full-frame CMOS Sensor
The EOS RP camera features a Canon-developed and produced 35mm full-frame CMOS sensor with approx. 26.2 effective megapixels. It employs the DIGIC 8 Image Processor to enhance the speed of operations across the board. This means fast, efficient performance and phenomenal image quality for big prints.
ISO 40000
The EOS RP camera has a standard ISO sensitivity range of 100-40000 for stills and 100-25600 for video (100-12800 for 4K video shooting). Combined with the EOS RP camera's remarkable low-light AF performance, still and video shooting is possible even in dark situations.
Digital Lens Optimizer
The EOS RP camera has an in-camera Digital Lens Optimizer that works with RF lenses (and EF/EF-S lenses with a Mount Adapter) to provide a substantial improvement in image quality. The Digital Lens Optimizer limits deterioration in image quality caused by low-pass filters or wide-aperture lens designs. It's usable both during shooting and when developing RAW data, and does not affect continuous shooting speeds. Data from compatible EF and EF-S lenses is built into the camera, and data information from RF lenses is transferred near instantly through the EOS RP's 12 pin communication system.
High-speed Focusing in Approx. 0.05 sec.***
The EOS RP camera's highly responsive Dual Pixel CMOS AF system features 4,779 manually selectable AF points** and can deliver sharp focus within approximately 0.05 seconds***. This means fast action can be captured and focus can be maintained with speed, accuracy and ease.
** Available AF points may decrease when shooting with AF cropping or in movie mode, or depending on camera settings or lens attached.
*** Based on the results of AF speed tests in accordance with CIPA guidelines. Results may vary depending on shooting conditions and lens in use. Relies on internal measurement method.
Test conditions:
- Brightness at time of distance measurement: EV12 (regular temperature, ISO 100)
- Shooting mode: M
- Lens in use: RF 24–105mm F4 L IS USM, with a focal distance of 24mm
- Live-view mode: On (with manual shutter button operation)
- AF mode: Live single-point AF (central)
- AF operation: One-shot AF
AF Area Coverage of Approx. 88% x 100%^
The EOS RP camera features an expansive focus area of approx. 88% horizontal and 100% vertical^ not only with RF lenses, but also when working with select EF lenses. With older EF lenses, or with Extender types I and II, the EOS RP focuses approx. 80% horizontally and 80% vertically. This means fast and impressive focusing even if your subject is way off center.
^ When shooting still photos. Actual coverage varies depending on the lens in use.
AF Points and AF Area
The EOS RP camera features a sophisticated AF system with a maximum of 4,779 manually selectable AF points**, which covers almost the entire image sensing area. The EOS RP can also be configured to focus on specific areas, using an extended range of selectable modes that include 1-point AF, Expand AF Area, Zone AF and Spot AF in addition to the conventional Face+ Tracking AF.
Excellent Low-light Performance.
Amazing for nighttime photography or in very low light, the EOS RP camera's brilliant AF can operate in light as dim as a light rating of EV -5^ where other AF systems may fail or search. Phenomenal AF is achieved even when using lenses with high F numbers. This ultra-sensitive AF works in concert with the EOS RP's EVF to clearly capture subjects even when there's limited light.
^ When using RF 50mm F1.2 L USM, with central AF point.
f/11 Compatible in All AF Areas
The EOS RP camera's brilliant AF system doesn't just work with bright lenses. With the EOS RP, autofocus will operate over nearly the entire image area even when used with compatible f/11 lenses. For example, users can take ultra-telescopic 800mm shots using a compact EF 100-400mm f/4-5.6 IS II lens together with an EF 2x III extender, and AF will function properly over the entire field. When used with a III-type extender, the effective AF range is limited to an area roughly 88% x 100% of the total image frame, or 80% x 80% if combined with a I/II type extender.
Variety of AF Modes including Eye Detection AF
The EOS RP camera's Face+ Tracking mode helps enhance reliability for tracking moving subjects. When the camera detects a human face, it uses the subject's eye as the AF point, choosing the eye closest to the camera by default. Photographers can also select which eye to focus on by touching the screen or using the camera's AF point selection button and cross keys. Eye Detection AF can also be used in conjunction with Servo AF and Movie AF modes.
Focus Peaking
Among the EOS RP camera's manual focus aids, Focus Peaking helps establish the focus area quickly and clearly. With manual focus peaking, the outline of the area in focus is indicated by a colored line. Focus Peaking is usable in conjunction with the EOS RP's Focus Guide feature, and can be customized with peaking color and detection level specifications that fit the project at hand.
0.39-type OLED EVF with Approx. 2.36 Million Dots
The EOS RP camera features a high-precision 0.39-inch OLED (Organic Light-Emitting Diode) EVF with approx. 2.36 million dots and a 22mm eyepoint. The electronic viewfinder (EVF) has been created to provide a bright, sharp and colorful 100% view of the subject at hand. Equipped with an aspherical lens, the EVF shows a crisp and vivid image with minimal distortion, even when the eye moves off the center of the visual field.
The EOS RP EVF has a bright, 22mm-high eyepoint design that creates a generous 30mm space between your nose and the rear of the viewfinder. This makes it easy to compose and view images in the viewfinder with or without glasses.
The EVF's 0.39-inch OLED based display features approximately 2.36 million dots for an incredibly sharp and detailed image that makes it easy to check focus and view the extensive image data that's displayed.
Touch and Drag AF
Touch and Drag AF makes it fast and easy to select a focus point without taking your eye away from the viewfinder. Using the Touchscreen LCD, it's as simple as pointing to the desired area of focus. The chosen AF point is then displayed in the camera's EVF for quick confirmation.
Vari-angle Touchscreen LCD
The EOS RP camera features a 3.0-inch, 1.04 Megapixel Clear View LCD II Vari-angle Touchscreen LCD. Brightness is adjustable in seven levels. Its extensive flexibility makes it easy to compose and shoot from virtually any angle, making selfies simple and enabling the LCD to fold away when not in use. The brightness of the EVF and the LCD monitor can even be adjusted individually - a first for an EOS camera. Touchscreen features include settings, review and even AF point selection.
Shooting Modes
A mode dial is featured on the top of the EOS RP camera to provide quick and easy access to a number of shooting modes and settings. For instance, the SCN option - or Special Scene Mode option - gives you the opportunity to select from a variety of settings. This includes modes such as Food, Group Photos, Kids, Panning, and even Silent Mode-perfect for situations where the shutter could be turned off. To set individual features to Auto or Manual, the user can use the Fv mode (Flexible AE) to quickly adjust functions such as shutter speed, aperture setting, and ISO sensitivity.
Special Scene Modes
The EOS RP features a variety of Special Scene modes -such as Food, Kids, Sports, Group Photos, Landscape, and more. Handheld Night Scene and HDR Backlight Control are two other Special Scene Modes featured. The Handheld Night Scene mode captures nightscapes with bright highlights and detailed dark areas. The HDR Backlight Control mode ensures that backlit subjects are not recorded too dark.
Easy Operation
The EOS RP is designed to allow users to operate almost every feature while looking through the EVF (electronic viewfinder). The camera features various operating controls, such as buttons, switches, and dials, that make them easy for the user to locate and operate. Many of the operating controls can even be customized to perform different functions to make the shooting process even easier.
Creative Assist
The EOS RP camera's built-in Creative Assist feature makes it simple to change camera settings and see the results in real time, helping you find just the right look to match the emotion or tone of the image. With effects such as brightness, contrast and saturation easily found on one menu, the EOS RP is a convenient tool for getting great looks and experimenting with different styles.
Feature Assistant
With its Feature Assistant function, the EOS RP camera can help you take advantage of its advanced features and create impressive photos with ease. By providing simple text explanations as well as sample photos to illustrate the function, the Feature Assistant helps put you in the know so you get amazing photographs.
USB Charge Compatible
The EOS RP camera is compatible with the USB Power Adapter PD-E1 for in-camera charging via USB. Featuring an industry standard USB-C connector, the optional USB Power Adapter PD-E1 makes for easy charging without the necessity to remove the battery from the camera.
Battery Pack LP-E17
For power and the convenience of compatibility among multiple cameras, the EOS RP camera uses the Battery Pack LP-E17, a robust, long-lasting battery that helps deliver power, shot after shot, recording after recording.
Camera Connect^^
Canon's Camera Connect^^ app uses the EOS RP camera's built-in Wi-Fi® and Bluetooth® compatibility to connect to a compatible mobile device. This allows a number of functions from easy image transfer to remote shooting, to adding GPS information to your photos and videos and more.
^^ Compatible with iOS® versions 10.3/11.4/12.1, Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1/8.0/8.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
DPP Express
Canon's Digital Photo Professional Express makes speedy processing of JPEGs and CR3 RAW files on a compatible handheld device a breeze. Working with Canon's Camera Connect app^^ to create a streamlined wireless workflow, DPP Express lets you adjust settings right on your mobile device, saving files to the cloud, a PC or your camera.
^^ Compatible with iOS© versions 9.3/10.3/11.2, Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1/8.0/8.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
Extension Grip Accessory
The optional Extension Grip EG-E1 provides additional support and comfort using the EOS RP so you can feel even more confident when shooting. There's an access panel so you can easily swap batteries and SD cards when needed.
* As of February 13, 2019
** Optional Mount Adapter EF-EOS R is required when using EF/EF-S lenses.
*** Compatible with iOS®; versions 10.3/11.4/12.1, Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1/8.0/8.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
**** Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS®; devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth®;
| Type | Digital Single-Lens Non-Reflex AF/AE Camera |
| Recording Medium | SD/SDHC/SDXC Memory Cards
| Image Format | Approx. 35.9 X 24.0mm |
| Compatible Lenses | Canon RF Lens Group (Excluding EF, EF-S And EF-M Lenses) When Using Mount Adapter EF-EOS R: Canon EF Or EF-S Lenses (Excluding EF-M Lenses) |
| Lens Mount | Canon RF Mount |
| Type | CMOS Sensor (Compatible With Dual Pixel CMOS AF) |
| Pixels | Approx. 26.2 Megapixels |
| Pixel Unit | Approx. 5.76 µm Square |
| Total Pixels | Approx. 27.1 Megapixels |
| Aspect Ratio | 3:2 (Horizontal:Vertical) |
| Color Filter System | RGB Primary Color Filters |
| Low Pass Filter | Installed In Front Of The Image Sensor, Non-Detachable |
| Dust Deletion Feature |
| Recording Format | Compliant To Design Rule For Camera File System 2.0 And Exif 2.3. Supports Time Difference Information In Exif 2.31. |
| File Size | 3:2 Aspect Ratio Large/RAW/C-RAW: 6240 X 4160 Medium: 4160 X 2768 Small 1: 3120 X 2080 Small 2: 2400 X 1600 1.6x (Crop) Large/RAW/C-RAW: 3888 X 2592 Small 2: 2400 X 1600 4:3 Aspect Ratio Large/RAW/C-RAW: 5536 4160 Medium: 3680 X 2768 Small 1: 2768 X 2080* Small 2: 2112 X 1600* 16:9 Aspect Ratio* Large/RAW/C-RAW: 6240 X 3504 Medium: 4160 X 2336 Small 1: 3120 X 1752 Small 2: 2400 X 1344 1:1 Aspect Ratio Large/RAW/C-RAW: 4160 X 4160 Medium: 2768 X 2768 Small 1: 2080 X 2080 Small 2: 1600 X 1600
| File Numbering | The Following File Numbers Can Be Set:
| Raw Jpeg Simultaneous Recording | Possible |
| Color Space | Selectable Between SRGB And Adobe RGB |
| Picture Style |
| Settings |
| Auto White Balance | Option Between Ambience Priority And White Priority Settings. |
| Color Temperature Compensation | Blue/Amber Bias: ±9 Levels Magenta/Green Bias: ±9 Levels Corrected In Reference To The Current WB Mode's Color Temperature. |
| Type | OLED Color Electronic Viewfinder |
| Coverage | Approx. 100% Vertically And Horizontally Relative To The Shooting Image Area (With Image Quality L, At Approx. 23mm Eyepoint). |
| Magnification | Approx. 0.70 (With 50mm Lens At Infinity, -1 M-1) |
| Eyepoint | Approx. 22mm (At -1 M-1 From The Eyepiece Lens End) |
| Viewfinder Information |
| Type | Phase-Difference Detection System With Image Sensor (Dual Pixel CMOS AF) | ||||||||||||||||||
| Af Points | Max. 4,779 When Selected With Cross Keys. |
| Af Working Range | EV -5 To 18 (F/1.2, At 73°F/23°C, ISO 100, One-Shot AF) | ||||||||||||||||||
| Focusing Modes |
| Af Point Selection | AF Point Selection And AF Operation
* Not Available In 4K Movie Recording |
| Af Assist Beam |
| Metering Modes | Real-Time Metering With Image Sensor (384 [24x16])
| Metering Range | EV -3 - 20 (At 73°F/23°C, ISO 100) | |||||||||||||||||||||
| Exposure Control Systems |
| Iso Speed Range | ISO Speed Range Manual Setting
Auto
*1 Depending On [Minimum] And [Maximum] Of [ISO Speed Settings] Or [Range For Stills]. |
| Exposure Compensation | Exposure Compensation
| Ae Lock |
| Type | Electronically Controlled Focal-Plane Shutter
| Shutter Speeds | 1/4000 To 30 Sec., Bulb (Total Range Of All Shooting Modes) X-Sync At 1/180 Sec. |
| Shutter Release | Soft-Touch Electromagnetic Release | |||||||||||
| Self Timer | 10-Sec. Delay, 2-Sec. Delay, Continuous Shooting | |||||||||||
| Shutter Lag Time | Shutter Lag Time
| Flash Metering | E-TTL II Autoflash |
| Flash Exposure Compensation | ±3 Stops In 1/3- Or 1/2-Stop Increments |
| Fe Lock | Provided |
| External Flash Settings | The Camera Can Set The Following With EX Series Speedlites:
| Drive Modes |
| Max Burst During Continuous Shooting | Maximum Burst
| Shooting Modes | Still Photo Shooting And Video Shooting |
| Focusing |
| Metering Modes |
| Metering Range | EV -2.5 - 18 (At 73°F/23°C, ISO 100, One-Shot AF, With 29.97 Fps) |
| Grid Display |
| File Format | MP4 Video: MPEG-4 AVC / H.264
ALL-I: Linear PCM IPB: AAC |
| Continuous Shooting Time | Continuous Shooting Time
| Focusing |
| Range | Full Range (0 To 255) | |||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Control | Exposure Control
| Exposure Compensation | ±3 Stops In 1/3- Or 1/2-Stop Increments | |||||||||||||||||||||||||||||||||||||||||||||||||
| Type | TFT Color, Liquid-Crystal Monitor |
| Screen Monitor Size | 3.0-Inch (Screen Aspect Ratio Of 3:2) 2.95 In./7.50cm Diagonal (2.46 In./6.24cm Width, 1.64 In./4.16cm Height) |
| Pixels | Approx. 1.04 Million Dots |
| Coverage | Approx. 100% Vertically/Horizontally |
| Brightness Control | Manually Adjustable To One Of Seven Brightness Levels |
| Coating | Clear View LCD II
| Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese) |
| Image Display Format |
| Highlight Alert | The White Areas With No Image Data Will Blink. |
| Protection |
| Erase | Except Protected Images
| Compatible Printers | Images Can Be Sent Via Wi-Fi® To A PictBridge-Compatible (Wireless LAN) Printer And Printed. |
| Dpof | Compliant To DPOF Version 1.1 |
| Custom Controls | Custom Controls Customizable Buttons
Customizable Dials
| My Menu Registration | My Menu Registration
| Usb Terminal | Equivalent To SuperSpeed USB (USB 3.1 Gen 1)
| Video Out Terminal | Type C (Resolution Switches Automatically) / CEC Not Compatible
| Extension System Terminal | 3.5mm Diameter Stereo Mini Jack |
| Battery | Battery Pack LP-E17 X 1
| Number Of Shots | Number Of Possible Shots (Approx. Shots)
| Battery Check | Automatic Battery Check When The Power Switch Is Turned ON.
| Power Saving | Power Turns Off After The Set Time Of Non-Operation Elapses. Display Off Auto Power Off Disable
| Date Time Battery | Built-In Secondary Battery
| Start Up Time | Approx. 0.82 Sec.
| Dimensions W X H X D | Approx. 5.22 X 3.35 X 2.76 In. / 132.5 X 85.0 X 70.0 Mm (Depth From Tip Of Grip To LCD Screen Surface: Approx. 2.34 In / 59.4mm) |
| Weight | Approx. 1.07 Lbs. / 485g (Including Battery, SD Memory Card; Without Body Cap) Approx. 1.0 Lbs. / 440g (Body Only; Without Battery, Card Or Body Cap) |
| Operating Humidity Range | 32-104° F / 0-40° C |
| Working Temperature Range | 85° Or Less |
Timer Remote Controller TC-80N3
Remote switch for EOS cameras with the N3-type socket. This remote switch has a self-timer, interval timer, long exposure timer and exposure-count setting feature. The timer can be set from 1 second to 99 hours. A new dial enables you to easily enter the numeric settings with a single thumb. It has an illuminated LCD panel and a 2.6ft/80cm cord.
Wireless Remote Control BR-E1
A wireless remote controller compatible with Bluetooth enabled cameras for wireless focusing, still shooting and video recording, and zooming using the Power Zoom Adapter PZ-E1. Operating distance is approximately 16 ft in any direction.
Remote Switch RS-60E3
Compact remote switch replicating all of the functions of the shutter release button.
Battery charger for LP-E17 Li-ion batteries for EOS Rebel Camera.
Interface Cable IFC-100U
USB interface cable to connect to a computer or other USB device. Approx. 3.3 ft.
Interface Cable IFC-400U
USB interface cable to connect to a computer or other USB device. Approx. 13.1 ft.
AC Adapter AC-E6N
Provides AC power to the camera with the combination of DR-E6.
Allows you to charge the battery inside your camera by way of USB.
DC Coupler DR-E18
When shooting indoors, in a studio or on a tabletop, use this DC coupler to provide uninterrupted power to your EOS camera.
AC Adapter Kit ACK-E18
An AC adapter and DC coupler DR-E18 kit
The Extension Grip EG-E1 provides additional support and comfort so you can feel even more confident when shooting. There's an access panel so you can easily swap batteries and SD cards when needed.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
