/content/cla/en/cla-test/cla-testing/haibd4-testing
/content/cla/en/cla-test/cla-testing/support/p/Software-Applications/1259B003
EOS Rebel T4i
Canon is proud to introduce its most sophisticated Rebel ever—the EOS Rebel T4i DSLR!
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Inspiration On Demand.
Canon is proud to introduce its most sophisticated Rebel ever—the EOS Rebel T4i DSLR! Built to make advanced photography simple and fun, the new Rebel T4i delivers phenomenal image quality, high performance, and fast, intuitive operation. This EOS Rebel amps up the speed with the powerful DIGIC 5 Image Processor that helps make high-speed continuous shooting of up to 5.0 fps possible—great for capturing fast action. An 18.0 Megapixel CMOS sensor ensures that every image is shot in superb, high resolution; and an extended ISO range of 100-12800 gives photographers the opportunities to take the Rebel T4i into more shooting situations than ever before. A 9-point all cross-type AF system (including a high-precision dual cross f/2.8 center point) delivers improved autofocus performance, and a new Hybrid CMOS AF System increases autofocus speed when shooting photos and video in Live View. For users interested in creating impressive videos, the Rebel T4i is ready to help you create your next masterpiece. Movie Servo AF provides continuous focus of moving subjects, so you never miss a moment. A built-in stereo microphone and manual audio level adjustment helps ensure that your audio will match the stunning quality of your video. First ever for an EOS Rebel, the Rebel T4i features a Vari-angle Touch Screen 3.0-inch Clear View LCD monitor II, which allows fast and intuitive camera operation. Add compatibility with Canon's proven EF and EF-S lenses and a slew of EOS accessories, the Rebel T4i is an incredibly versatile tool for creating the images and videos you envision.
| Type | Digital, AF/AE Single-Lens Reflex, Camera With Built-In Flash |
| Recording Medium | SD Card, SDHC Card, SDXC Memory Card * Compatible With Ultra High Speed (UHS-I) And Eye-Fi Cards. |
| Image Format | 22.3 X 14.9 Mm (APS-C Size) |
| Compatible Lenses | Canon EF Lenses Including EF-S Lenses (35mm-Equivalent Focal Length Is Approx.1.6x The Lens Focal Length) |
| Lens Mount | Canon EF Mount |
| Type | CMOS Sensor |
| Pixels | Effective Pixels: Approx. 18.0 Megapixels |
| Pixel Unit | 4.3 µm Square |
| Total Pixels | Total Pixels: Approx. 18.50 Megapixels |
| Aspect Ratio | 3:2 (Horizontal : Vertical) |
| Color Filter System | RGB Primary Color Filters |
| Low Pass Filter | Fixed Position In Front Of The CMOS Sensor |
| Dust Deletion Feature | (1) Self Cleaning Sensor Unit
| Recording Format | Complies With Design Rule For Camera File System 2.0 And Exif 2.30 |
| File Size | (1) Large: Approx. 17.90 Megapixels (5,184 X 3,456) (2) Medium: Approx. 8.00 Megapixels (3,456 X 2,304) (3) Small 1: Approx. 4.50 Megapixels (2,592 X 1,728) (4) Small 2: Approx. 2.50 Megapixels (1920 X 1280) (5) Small 3: Approx. 350,000 Pixels (720 X 480) (6) RAW: Approx. 17.90 Megapixels (5,184 X 3,456) |
| Backup Recording | N/A |
| File Numbering | The Following Three Types Of File Numbering Method Can Be Set: (1) Continuous Numbering * The Numbering Of Captured Images Will Continue Even After You Replace The Camera's Card. (2) Auto Reset * When You Replace The Camera's Card, The Numbering Will Be Reset To Start From 0001. If The New Card Already Contains Images, The Numbering Will Continue From The Last Recorded Image In The Card. (3) Manual Reset * Resets The File Number To 0001, And Creates A New Folder Automatically. |
| Raw Jpeg Simultaneous Recording | Large RAW And JPEG Images Are Recorded Simultaneously |
| Color Space | SRGB, Adobe RGB |
| Picture Style | Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3 |
| Settings | Auto, Daylight, Shade, Cloudy (Twilight And Sunset), Tungsten Light, White Fluorescent Light, Flash, Custom (Custom White Balance: Approx. 2,000° - 10,000° K) |
| Auto White Balance | Auto White Balance With The Image Sensor |
| Color Temperature Compensation | White Balance Correction:
| Color Temperature Information Transmission | Provided |
| Type | Eye-Level SLR (With Fixed Pentamirror) |
| Coverage | Vertical/Horizontal Approx. 95% |
| Magnification | Approx. 0.85x / 23.8° |
| Eyepoint | Approx. 19 Mm (At -1m-1 From The Eyepiece Lens Center) |
| Dioptric Adjustment Correction | -3.0 To +1.0 M-1 (Dpt) |
| Focusing Screen | Fixed |
| Mirror | Quick-Return Half Mirror (Transmission: Reflection Ratio Of 40:60) |
| Viewfinder Information | 1) AF Information (AF Points And Focus Confirmation Light) 2) Exposure Information (Shutter Speed, Aperture, ISO Speed (Always Displayed), AE Lock, Exposure Level, Spot Metering Circle, Exposure Warning) 3) Flash Information (Flash Ready, Flash Exposure Compensation, High-Speed Sync, FE Lock, Red-Eye Reduction Light) 4) Image Information (Highlight Tone Priority (D+), Monochrome Shooting, Maximum Burst (1-Digit Display), White Balance Correction, SD Card Information) |
| Depth Of Field Preview | Enabled With Depth-Of-Field Preview Button |
| Type | TTL-CT-SIR AF-Dedicated CMOS Sensor |
| Af Points | 9 Points (All AF Points Are Cross-Type At F/5.6., Center AF Point Is Diagonal Cross-Type At F/2.8.) |
| Af Working Range | EV -0.5 - 18 (At 23°C/73°F And ISO 100, Based On Canon's Testing Standards) |
| Focusing Modes | (1) Autofocus
| Af Point Selection | (1) Manual Selection (2) Auto Selection * Automatically Set In Basic Zone Modes. |
| Selected Af Point Display | Indicated By Superimposed Display In The Viewfinder And On The LCD Monitor |
| Af Assist Beam | (1) Intermittent Firing Of Built-In Flash (2) Effective Range: Approx. 13.1 Ft./4 M. At Center, Approx. 11.5 Ft /3.5 M. At Periphery * With An EOS-Dedicated Speedlite Attached, The Speedlite's AF-Assist Beam Is Emitted Instead. * Compatible With Assist-Beam (Intermittent Firing) Of 270EX II, 320EX, And 270EX Flashes. |
| Metering Modes | Real-Time Evaluative Metering With Image Sensor Evaluative Metering, Partial Metering (Center: Approx. 9% Of Viewfinder), Spot Metering (Center: Approx. 4% Of Viewfinder), Center-Weighted Average Metering * AE Lock Possible. The Active Metering Time Can Be Changed. |
| Metering Range | EV 1.0 - EV 20.0 (At 73°F/23°C With EF50mm F/1.4 USM Lens, ISO 100) | ||||||||||||
| Exposure Control Systems | Creative Zone (1) Program AE (Shiftable) (2) Shutter-Priority AE (3) Aperture-Priority AE (4) Manual Exposure (Including Bulb) Basic Zone (1) Scene Intelligent Auto (Program AE / Non-Shiftable) (2) Flash Off (3) Creative Auto (4) Portrait (5) Landscape (6) Close-Up (7) Sports (8) Night Portrait (9) Handheld Night Scene Mode (10) HDR Backlight Control Mode |
| Iso Speed Range | For Stills: 1. Manual Setting Range Of ISO 100-12800, Expansion To ISO 25600 2. Auto, ISO 100-6400 (In Whole-Stop Increments) - In Creative Zone Modes, The Maximum ISO Speed (ISO 400, 800, 1600, 3200, Or 6400) For ISO Auto Can Be Set. - With C.Fn-6-1 (Highlight Tone Priority), ISO 200 Or Higher Will Be Set.
| Exposure Compensation | Manual: ±5 Stops In 1/3- Or 1/2-Stop Increments (AEB ±2 Stops) AEB : ±2 Stops In 1/3- Or 1/2-Stop Increments * If The Exposure Compensation Exceeds ±2 Stops, The Left Or Right Icon Appears In The Viewfinder. * Manual Exposure Compensation And AEB Can Be Set In Combination. * AEB Is Set In The Following Sequence: Standard Exposure, Decreased Exposure, And Increased Exposure. * If AEB Is Used With The Self-Timer, The Three Bracketed Shots Will Be Taken In Succession After The 10-Sec. Or 2-Sec. Delay. |
| Ae Lock | (1) Auto AE Lock * In The One-Shot AF Mode With Evaluative Metering, AE Lock Takes Effect When Focus Is Achieved. (2) Manual AE Lock * In The P, Tv, Av, And M Modes, Enabled With The AE Lock Button. (Press Again To Update.) * Enabled In All Metering Modes. |
| Type | Vertical-Travel, Mechanical, Focal-Plane Shutter With All Speeds Electronically-Controlled |
| Shutter Speeds | 1/4000 To 1/60 Sec., X-Sync At 1/200 Sec. (Scene Intelligent Auto) 1/4000 To 30 Sec., Bulb, X-Sync At 1/200 Sec. (Total Shutter Speed Range. Available Range Varies By Shooting Mode.) * Settable In 1/3- Or 1/2-Stop Increments. |
| Shutter Release | Soft-Touch Electromagnetic Release |
| Self Timer | 10-Sec. Or 2-Sec. Delay |
| Shutter Lag Time | (1) During SW-1 ON, Time Lag Between SW-2 ON And Start Of Exposure: Approx. 0.075 Sec. (2) Time Lag Between Simultaneous SW-1/SW-2 ON And Start Of Exposure: Approx. 0.150 Sec. * Time Lag With The Aperture Stopped Down By 3 Stops Or Less. Excludes AF Operation Time. |
| Remote Control | Compatible With Remote Controller RC-6, RC-1, And RC-5 Remote Control Mode (Via Menu) For Video Shooting Provided * You Can Start Or Stop Video Shooting Immediately With The Wireless Remote Control's 2-Sec. Delay Mode (Operates As Immediate Start/Stop). * Still Photo Shooting Is Possible With The Wireless Remote Control's Immediate Shutter-Release Mode. |
| Type | Auto Pop-Up, Retractable, Built-In Flash In The Pentamirror |
| Flash Metering System | E-TTL II Autoflash (Evaluative Flash Metering And Average Flash Metering), FE Lock |
| Guide Number | Approx. 13/43 (At ISO 100 In Meters/Feet) |
| Recycling Time | Approx. 3 Sec. |
| Flash Ready Indicator | Flash-Ready Icon Lights In Viewfinder |
| Flash Coverage | Up To 17mm Focal Length (Equivalent To Approx. 28mm In 135 Format) |
| Fe Lock | Provided |
| Flash Exposure Compensation | Up To ±2 Stops In 1/3- Or 1/2-Stop Increments
| Flash Metering | E-TTL II Autoflash (Evaluative Flash Metering And Average Flash Metering), FE Lock |
| Flash Exposure Compensation | ±2 Stops In 1/3-Stop Or 1/2-Stop Increments |
| Pc Terminal | Not Provided |
| Drive Modes | Single, Continuous, 10-Sec. Self-Timer/Remote Control, 2-Sec. Self-Timer, Continuous Shooting After 10-Sec. Self-Timer (2 To 10 Shots) |
| Continuous Shooting Speed | Max. Approx. 5.0 Fps (With One-Shot AF Or AI SERVO AF) * Same As With Battery Grip BG-E8 Loaded With Size-AA/LR6 Alkaline Batteries. |
| Max Burst During Continuous Shooting | Based On 8GB Memory Card: JPEG Large/Fine: Approx. 22 Shots RAW: Approx. 6 Shots RAW+JPEG Large/Fine: 3 Shots Based On UHS-I Memory Card: JPEG Large/Fine: Approx. 30 Shots RAW: Approx. 6 Shots RAW + JPEG Large/Fine: 3 Shots |
| Shooting Modes | Still Photo Shooting And Video Shooting |
| Focusing | (1) Autofocus - Face Detection + Tracking AF - FlexiZone - Multi (31 Zones, AF At The Touched Zone) - FlexiZone - Single - Quick Mode AF (2) Manual Focusing *Magnify The Image By 5x Or 10x And Focus Manually. |
| Metering Modes | Evaluative Metering, Partial Metering, Spot Metering, Center-Weighted Average Metering |
| Metering Range | EV 0 To EV 20 (At 23°C/73°F, 50mm F/1.4 Lens, ISO 100) |
| Grid Display | Provided (Two-Type Grid Displays) |
| Exposure Simulation | Provided |
| Silent Shooting | Not Provided |
| File Format | MOV (Image Data: H.264; Audio: Linear PCM (Stereo)) |
| File Size | Recording Size: Recording Size: [Full HD] 1920 X 1080: 330 MB/Min. [HD] 1280 X 720: 330 MB/Min. [SD] 640 X 480: 82.5 MB/Min. |
| Frame Rates | 1920 X 1080 (Full HD): 30p (29.97) / 24p (23.976) / 25p 1280 X 720 (HD): 60p (59.94) / 50p 640 X 480 (SD): 30p (29.97) / 25p |
| Continuous Shooting Time | [1920 X 1080] 30 Fps: Approx. 22 Min. 25 Fps: Approx. 22 Min. 24 Fps: Approx. 22 Min. [1280 X 720] 60 Fps: 22 Min. 50 Fps: 22 Min. [640 X 480] 30 Fps: 1 Hr. 32 Min. 25 Fps: 1 Hr. 32 Min. |
| Focusing | (1) Autofocus 1. Face Detection + Tracking AF 2. FlexiZone - Multi (31 Zones, AF At The Touched Zone) 3. FlexiZone - Single (2) Manual Focus 1. Magnify The Image By Approx. 5x Or Approx. 10x And Focus Manually. 2. Magnified View Is Not Possible During Video Shooting. |
| Range | Auto ISO Range: ISO 100-6400 Manual ISO Range: ISO 100-6400, H12800 *If Highlight Tone Priority Is Set, Automatically Set Within ISO 200 Or Higher. |
| Exposure Control | (1) Program AE For Video Shooting * In Basic Zone Modes, P, Av, And Tv Modes * Shutter Speed 1/30 - 1/4000 Sec. (Signal Accumulation Time), Aperture, And ISO Speed Automatically Set. (2) Manual Exposure * For Manual Exposure. * Shutter Speed (Signal Accumulation Time), Aperture, And ISO Speed (Auto/Manual) Manually Set. The Shutter Speed (Signal Accumulation Time) Is Limited To 1/4000 Sec. At The Maximum And To 1/30 Sec. At The Minimum For 24/25/30 Fps Or 1/60 Sec. Or Higher For 50/60 Fps. |
| Exposure Compensation | Provided (±3 Stops In 1/3-Stop Increments) * For Video, Exposure Compensation Will Not Be Applied Beyond ±3 Stops Even If The Exposure Compensation Has Been Set Beyond ±3 Stops. |
| Type | TFT Color, Liquid-Crystal Monitor With Touch Panel LCD (Capacitive Type) |
| Screen Monitor Size | 3.0 In. (Screen Aspect Ratio Of 3:2) |
| Pixels | Approx. 1,040,000 Dots |
| Coverage | Viewing Angle: 170° (Vertically And Horizontally) |
| Brightness Control | Auto: Brightness Adjusted Automatically By The Light Sensor, Manual: 7 Levels Provided |
| Coating | Anti-Smudge Coating |
| Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
| Image Display Format | (1) Single Image Display
| Highlight Alert | On The Detailed Information And Histogram Displays, Highlight Areas With No Image Data Will Blink. |
| Items | When You Press The Quick Control Function Button Under The Following Conditions, You Can Set The Functions Below: *The Settable Functions Depend On The Shooting Mode (1) With Viewfinder Shooting: Shutter Speed, Aperture, ISO Speed, Exposure Compensation, AEB, Flash Exposure Compensation, Picture Style, White Balance, Auto Lighting Optimizer, Built-In Flash Func. Setting, AF Mode, Drive Mode, Metering Mode, And Image Recording Quality. (2) With Live View Shooting: AF Mode, Drive Mode, White Balance, Picture Style, Auto Lighting Optimizer, Image-Recording Quality, And Built-In Flash Func. Setting. (3) With Video Shooting: AF Mode, White Balance, Picture Style, Auto Lighting Optimizer, Image Recording Quality (Stills), Video-Recording Size, And Video Snapshot. |
| Protection | Erase Protection Can Be Applied/Canceled For A Single Image, All Images In A Folder, Or All Images In The Card. |
| Erase | Erase Single Image, Erase Selected Images, Erase All Images On Folder, Erase All Images In A Card, Or Erase Only Unprotected Images. |
| Compatible Printers | PictBridge-Compatible Printers |
| Printable Images | JPEG Images Complying To Design Rule For Camera File System
| Dpof | DPOF Print Ordering Provided (Complies To DPOF Version 1.1) * If Both Standard And Index Are Set, Only Standard Will Take Effect For Printing. |
| Compatible Images | Not Provided |
| Custom Functions | Eight Custom Functions With 24 Settings Settable With The Camera |
| Custom Controls | Not Provided |
| My Menu Registration | Up To Six Top-Tier Menu Options And Custom Function Settings Can Be Registered |
| Usb Terminal | For Personal Computer Communication And Direct Printing (USB 2.0 Hi-Speed) |
| Video Out Terminal | (1) Video OUT Terminal: NTSC/PAL Selectable (2) Mini-HDMI OUT Terminal |
| Extension System Terminal | Not Provided |
| Battery | One Battery Pack LP-E8 * With The AC Adapter Kit ACK-E8, AC Power Is Possible. * With BG-E8, Two Battery Packs (LP-E8) Can Be Used. Or Six Size-AA/LR6 Batteries Can Be Used. |
| Battery Life | 1) Camera Body Only
2) With Battery Grip BG-E8
| Battery Check | Automatic Battery Level Check When Power Is Turned ON. Battery Level Indicated In One Of Four Levels On LCD Monitor. |
| Power Saving | Power Turns Off After The Set Time Of Non-Operation Elapses * [Auto Power Off] Settable To 30 Sec., 1 Min., 2 Min., 4 Min., 8 Min., 15 Min. Or Disable |
| Date Time Battery | Built-In Secondary Battery. When Fully-Charged, The Date/Time Can Be Maintained For About Three Months. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Start Up Time | Approx. 0.1 Sec. (Based On CIPA Testing Standards) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | Approx. 5.2 X 3.9 X 3.1 In./ 133.1 X 99.8 X 78.8 Mm |
| Weight | Approx. 18.3 Oz. / 520 G (Body Only) Approx. 20.3 Oz. / 575 G (CIPA Guidelines) |
| Operating Temperature Range | 32-104°F/0-40°C |
| Operating Humidity Range | 85% Or Less |
ABOUT CANON
PRODUCT RESOURCES
ABOUT CANON
PRODUCT RESOURCES
Ⓒ 2026
