EOS Rebel T100
- EOS Rebel T100 Body1
- EF-S 18–55mm f/3.5–5.6 IS II OR
EF-S 18-55mm f/3.5-5.6 DC III2 - Battery Pack LP-E10
- Battery Charger LC-E10
- Power cable for battery charger
- Camera strap EW-400D
- Eyecup Ef (not shown)
- Getting started guide
1. Box content may vary by region.
2. EF-S 18-55mm f/3.5-5.6 DC III only available with the EOS Rebel T100 Kit
(Not sold seperately).
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
** Compatible with Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1/8.0.
All data is based on Canon standard testing methods except where indicated.
Subject to change without notice.
| Type | Digital, AF/AE Single-Lens Reflex Camera With Built-In Flash |
| Recording Medium | SD, SDHC And SDXC Memory Cards |
| Image Format | Approx. 22.3mm X 14.9mm |
| Compatible Lenses | Canon EF Lenses (Including EF-S Lenses And Excluding EF-M Lenses) |
| Lens Mount | Canon EF / EF-S Mount |
| Type | CMOS Sensor (Approx. 22.3 Mm X 14.9 Mm) |
| Pixels | Approx. 18.7 Megapixels (Rounded To The Nearest 100,000) |
| Pixel Unit | Approx. 4.29 µm Square |
| Total Pixels | Approx. 18.0 Megapixels (Rounded To The Nearest 100,000) |
| Aspect Ratio | 3:2 (Horizontal: Vertical) |
| Color Filter System | RGB Primary Color Filters |
| Low Pass Filter | Built-In / Fixed |
| Dust Deletion Feature | Manual Cleaning And Dust Delete Data Acquisition |
| Recording Format | Compliant To Design Rule For Camera File System 2.0 And Exif 2.30 |
| File Name | JPEG, RAW (14 Bit Canon Original RAW 2nd Edition) |
| File Size | 3:2 Aspect Ratio Large: 5184 X 3456 Medium: 3456 X 2304 Small 1: 2592 X 1728 Small 2: 1920 X 1280 Small 3: 720 X 480 RAW: 5184 X 3456 4:3 Aspect Ratio Large: 4608 X 3456I Medium: 3072 X 2304 Small 1: 2304 X 1728 Small 2: 1696 X 1280I Small 3: 640 X 480 RAW: 5184 X 3456 16:9 Aspect Ratio Large: 5184 X 2912I Medium: 3456 X 1944I Small 1: 2592 X 1456I Small 2: 1920 X 1080 Small 3: 720 X 400* RAW: 5184 X 3456 1:1 Aspect Ratio Large: 3456 X 3456 Medium: 2304 X 2304 Small 1: 1728 X 1728 Small 2: 1280 X 1280 Small 3: 480 X 480 RAW: 5184 X 3456 I. The Dimensions Will Not Attain A Perfect Aspect Ratio. Values Are Rounded To The Nearest 100,000. (Nearest 10,000 For S3.) For JPEG, The Image Will Be Generated According To The Selected Aspect Ratio. RAW Images Are Generated In [3:2], And The Set Aspect Ratio Is Appended. |
| File Numbering | The Following Three Types Of File Numbering Methods Can Be Set:
| Color Space | SRGB, Adobe RGB |
| Picture Style |
| Auto White Balance | Option Between Ambience Priority And White Priority Settings Settings
| Color Temperature Compensation | Blue/Amber Bias: ±9 Levels Magenta/Green Bias: ±9 Levels Corrected Based On The Current WB Mode's Color Temperature. |
| Type | Pentamirror |
| Coverage | Approx. 95% Vertically And Horizontally (With Eye Point Approx. 21mm) |
| Magnification | Approx. 0.80x (With 50mm Lens At Infinity, -1m-1 Dpt) |
| Eyepoint | Approx. 21mm (At -1m-1 From Eyepiece Lens Center) |
| Dioptric Adjustment Correction | Fixed At -1.0 M-1 (Dpt) - E-Series Dioptric Adjustment Lenses Can Be Used To Make Dioptric Adjustments. |
| Mirror | Quick-Return Half Mirror |
| Viewfinder Information | AF Point, AF Point Activation Indicator, ISO Speed, White Balance Correction, Focus Indicator, ISO Speed, Exposure Level Indicator, Focusing Screen |
| Depth Of Field Preview | Yes, Assigned To SET Button |
| Type | TTL Secondary Image-Forming Phase-Difference Detection System With AF-Dedicated Sensor |
| Af Points | 9 Points All AF Points Support F/5.6 Cross-Type AF With Center AF Point AF Working Range Centre AF Point: EV 0 -18 (At Room Temperature & ISO100) Other AF Points: EV 1 -18 (At Room Temperature & ISO100) |
| Focusing Modes |
| Af Point Selection |
| Selected Af Point Display | Indicated By Superimposed Display In The Viewfinder And On The LCD Monitor. |
| Af Assist Beam | Intermittent Firing Of Built-In Flash Or Emitted By Optional Dedicated Speedlite (Effective Up To 4.0 M) |
| Metering Modes |
Spot Metering Not Provided. |
| Metering Range |
| Iso Speed Range | Manual ISO Setting: ISO 100–6400 (In Whole-Stop Increments), Expandable Equivalent To ISO 12800. If Highlight Tone Priority Is Set, The ISO Speed Is Automatically Set Within ISO 200 To ISO 6400. ISO Auto Setting: ISO 100–6400 In Creative Zone Modes, The Maximum ISO Speed (ISO 400, 800, 1600, 3200 Or 6400) For ISO Auto Can Be Set. 1 |
| Exposure Compensation | +/-5 EV In 1/3 Or 1/2 Stop Increments (Can Be Combined With AEB). Shooting
| Ae Lock |
| Type | Electronically-Controlled Focal-Plane Shutter, With Electronic First Curtain |
| Shutter Speeds | 30-1/4000 Sec (1/2 Or 1/3 Stop Increments), Bulb (Total Shutter Speed Range. Available Range Varies By Shooting Mode) |
| Shutter Release | Soft-Touch Electromagnetic Release |
| Self Timer | 2s, 10s, 10s + Continuous Shots 2-10 |
| Type | Built-In Flash |
| Flash Metering System | E-TTL II Autoflash (Evaluative, Average), FE Lock |
| Guide Number | Approx. 30.2 Ft./9.2m (At ISO 100) |
| Recycling Time | Approx. 2 Sec. |
| Flash Coverage | Up To Approx. 17mm Focal Length (Equivalent To Approx. 28mm In 35mm Format) |
| Fe Lock | Possible |
| Flash Exposure Compensation | Up To ±2 Stops In 1/3- Or 1/2-Stop Increments. Flash Exposure Compensation For Built-In Flash And External Speedlite Can Be Set With The Camera. |
| Flash Exposure Compensation | ±2 Stops In 1/3-Stop Or 1/2-Stop Increments |
| External Flash Settings | E-TTL II With EX Series Speedlites5 |
| Drive Modes |
| Continuous Shooting Speed | Max. Approx. 3.0 Fps |
| Shooting Modes | Still Photo And Video Recording |
| Focusing |
| Metering Modes |
AE Lock Possible
| Metering Range | EV 0-20 (Room Temperature, ISO 100) |
| Grid Display | Grid Overlay (X2), Histogram |
| File Format | MOV: Movie: MPEG4 AVC/H.264 Variable (Average) Bit Rate Audio: Linear PCM |
| File Size | [Full HD] 1920 X 1080 (30 Fps/24 Fps): 340 MB/Min. [HD] 1280 X 720 (60 Fps): 340 MB/Min. [SD] 640 X 480 (30 Fps): 90 MB/Min. |
| Frame Rates | 1920 X 1080 (Full HD): 30 Fps (29.97 Fps) / 24 Fps (23.98 Fps) 1280 X 720 (HD): 60 Fps (59.94 Fps) 640 X 480 (SD): 30 Fps (29.97 Fps) |
| Focusing |
ISO Sensitivity
| Exposure Compensation | +/-5 EV In 1/3 Or 1/2 Stop Increments (Can Be Combined With AEB). |
| Type | TFT Color, Liquid-Crystal Monitor |
| Screen Monitor Size | 2.7-Inch Approx. 6.8cm Diagonal (Width: Approx. 6.0cm, Height: Approx. 4.5cm) |
| Pixels | Approx. 230,000 Dots |
| Coverage | Approx. 120° Vertically And 130° Horizontally |
| Brightness Control | Adjustable To One Of Seven Brightness Levels |
| Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Hungarian, Czech, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
| Image Display Format |
| Highlight Alert | On The Detailed Information And Histogram Displays, Highlight Areas With No Image Data Will Blink. Quick Control Function During Shooting During Playback |
| Protection | Erase Protection Can Be Applied/Canceled For A Single Image, All Images In A Folder Or All Images In The Card. |
| Erase | Erase Unprotected Image(S) With Selection From Single Image, Selected Images, All Images On Folder Or All Images In A Card. |
| Compatible Printers | PictBridge-Compatible Printers |
| Printable Images | RAW And JPEG Images Compliant To “Design Rule For Camera File System (DCF)” Movies Cannot Be Printed. |
| Dpof | DPOF Print Ordering Provided (Complies To DPOF Version 1.1) |
| Custom Functions | 10 Custom Functions |
| Custom Controls | Not Provided |
| Camera User Settings | Not Provided |
| My Menu Registration | (1) Shooting Menu (X4) (2) Playback Menu (X2) (3) Setup Menu (X3) (4) My Menu |
| Usb Terminal | Hi-Speed USB Equivalent
| Video Out Terminal | HDMI Type C (Resolution Switches Automatically) Video Output: (Switches Automatically To 1, 2, 3 Or 4 To Suit The Connected Device.) Wi-Fi* (Wireless LAN) And NFC FunctionsStandards Compliance
Transmission Range
Connection Method
NFC Connection |
| Battery | Battery Pack LP-E10 X 1 The Camera Can Be Powered By An AC Power Supply By Using The Household Power Outlet Accessories (Sold Separately). |
| Number Of Shots | Approx. 500 (At 23°C, AE 50%, FE 50%) 9 Approx. 410 (At 0°C, AE 50%, FE 50%) |
| Battery Check | Automatic Battery Check When The Power Switch Is Turned ON. Battery Level Indicated In One Of The Four Levels On LCD Monitor. |
| Power Saving | Power Turns Off Automatically After The Set Time Of Non-Operation Elapses. [Auto Power Off] Settable To 30 Sec., 1 Min., 2 Min., 4 Min., 8 Min., 15 Min. Or Disable |
| Start Up Time | Approx. 0.1 Sec. (CIPA Standards) |
| Dimensions W X H X D | Approx. 5.08 X 3.99 X 3.03 In. / 129.0 X 101.6 X 77.1mm
| Weight | Approx. 15.38 Oz. / 436g (Including Battery And Card) |
| Operating Temperature Range | 32-104°F / 0-40°C |
| Operating Humidity Range | 85% Or Less |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
