EOS Rebel SL3
- EOS Rebel SL3 Body (Black)
- EF-S 18-55mm f/4-5.6 IS STM
- Battery Pack LP-E17
- Battery Charger LC-E17
- Wide Strap EW-400D
- Eyecup Ef (Not shown)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Whether you're a first time SLR user, an aspiring photo enthusiast, or someone looking to capture those amazing family moments, the Canon EOS Rebel SL3 can be the perfect companion. It's the smallest and lightest EOS DSLR camera to date*, and is equipped with 4K recording capability, Canon's Dual Pixel CMOS AF, and a vari-angle LCD for selfies and fun angles.
Its 24.1 Megapixel (APS-C) CMOS Sensor combines with the powerful DIGIC 8 Processor for amazing performance and results, and the EOS Rebel SL3 even lets you channel your creativity with options like 4K Time-lapse movies and Creative Assist. Wherever you are and wherever you go, the EOS Rebel SL3 camera makes it simple to capture stunning photos and videos to view and share.
The EOS Rebel SL3 is the lightest and smallest Canon EOS DSLR camera to date*. Its compact construction is accompanied by excellent usability, including a rounded grip that can sit comfortably in your hand. Conveniently sized for everyday use, the EOS Rebel SL3 means less missed opportunities and more memories preserved.
* Among current lineup, as of April 10, 2019.
The Canon EOS Rebel SL3 camera features a powerful 24.1 Megapixel CMOS (APS-C) sensor that can capture high-resolution images and beautiful 4K video. Take photos and videos with fine details and dynamic, rich colors from the deepest reds to emerald greens to lush blues and purples. Simply turn the camera on and feel confident that the results will be stunning.
The EOS Rebel SL3 lets you shoot with Dual Pixel CMOS AF for fast, accurate autofocus that helps you get the photo you want right as the moment happens. The EOS Rebel SL3 camera features an expansive focus area of approx. 88% horizontal and 100% vertical^ when working with select compatible EF lenses. The Eye Detection AF analyzes the image and automatically determines where to focus based on your subject's eyes, helping you capture a treasured headshot or a once-in-a-lifetime moment with your best friend in sharp detail.
^ When shooting still photos. Actual coverage varies depending on the lens in use.
Capture 4K videos at a frame rate of up to 24p for high definition, cinematic results. Recording at almost four times the resolution of Full HD, you can see your subject in stunning clarity. Beautiful time-lapse videos can also be created in 4K simply and easily with the dedicated Time-lapse Movie mode. You can also harness the power of 4K frame cropping^ to extract still images from your video recordings. All of this is possible in-camera without the need for additional software.
^ Saving a still image from a single movie frame may not result in the same image quality as a normal still image. Still image aspect ratio is 16:9. When trimming, the images will be cropped, and the angle of view is smaller.
Movie Digital IS
The EOS Rebel SL3 camera features a 5-axis Image Stabilization function that helps capture stable and smooth movies, correcting not only the subject in motion but also camera shake. This Digital IS works regardless of the lens being used, and is further enhanced when used with an IS lens.
The EOS Rebel SL3 camera features a 3.0-inch Vari-angle Touch Screen LCD that can be ideal for composing and reviewing your photos. Tap the screen during Live View while taking photos or videos and thanks to Dual Pixel CMOS AF, the EOS Rebel SL3 will quickly lock focus to that location in the image. Touch gestures can be used for zooming in or swiping through images after you've taken them, and menu and quick control settings can be accessed quickly and easily. In addition, the Vari-angle Touch Screen LCD lets users capture high-quality selfie shots with ease.
Built-in Bluetooth®*** Capability
Bluetooth®*** pairing helps you connect the camera to compatible smart devices using the free Canon Camera Connect app*. To customize the Bluetooth® function, simply click on the DISP button located on the top of the camera. In addition, Bluetooth® lets you connect to the optional Wireless Remote Control BR-E1 for remote shooting as well as pick up GPS shooting location data from the user's compatible smartphone.
** Compatible with iOS® versions 10.3/11.4/12.1, Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1/8.0/8.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
*** Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.0 or later and the Camera Connect App Ver. 2.4.10. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
^ One-time registration is required on CANON iMAGE GATEWAY online photo album.
The DIGIC 8 Image Processor helps produce high image quality and fast operation, even in in low light. When using high ISO settings, the image processor helps keep results sharp and detailed in virtually any lighting situation. Powerful all around, the DIGIC 8 Image Processor helps ensure your photos and videos look sharp and lifelike with minimal noise or grain.
To help you frame your ideal shot, the Canon EOS Rebel SL3 camera incorporates a fully featured optical viewfinder with a wide-area, 9-point AF system that is designed to achieve sharp focus in an instant. This sophisticated AF system makes it easy to capture the action, no matter where the subject moves - even in bright light situations. 63-zone evaluative metering helps the EOS Rebel SL3 achieve optimal exposure with a diverse array of subjects and lighting conditions.
The EOS Rebel SL3 is designed to allow users to operate almost every feature while looking through the OVF (optical viewfinder). The camera features various operating controls, such as buttons, switches, and dials, that make them easy for the user to locate and operate.
Creative Assist
Making it simple to change camera settings and see the results in real time, the Canon EOS Rebel SL3's built-in Creative Assist feature helps you find just the right look to match the emotion or tone of the image. With effects such as brightness, contrast and saturation easily found on one menu, the EOS Rebel SL3 is a convenient tool for getting great looks and experimenting with different styles.
Feature Assistant
With its convenient Feature Assistant function, the EOS Rebel SL3 camera helps users take advantage of its advanced features and create impressive photos with ease. By explaining and illustrating the camera's shooting modes and their effects with sample photos of each mode, the Feature Assistant encourages experimentation and provides guidance for creating amazing photographs.
Shooting Mode Guide
The EOS Rebel SL3 features a mode dial on the top of the camera to provide quick and easy access to multiple shooting mode functions. Each mode displays an explanation and example to understand the meaning of that specific style – making this camera easy to use. There's even a Smooth Skin mode that offers five levels of skin smoothing to make the skin appear soft.
*Among current lineup, as of April 10, 2019.
| Type | Digital AF/AE Single-Lens Reflex Camera With Built-In Flash | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Recording Medium | SD/SDHC/SDXC Memory Cards
| Image Format | Approx. 22.3 X 14.9mm (APS-C) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Compatible Lenses | Canon EF Lenses (Including EF-S Lenses, Excluding EF-M Lenses) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Lens Mount | Canon EF Mount | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | CMOS Sensor (Supporting Dual Pixel CMOS AF) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Pixels | Approx. 24.1 Megapixels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Pixel Unit | Approx. 3.72 µm Square | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Total Pixels | Approx. 25.8 Megapixels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Aspect Ratio | 3:2 (Horizontal : Vertical) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Color Filter System | RGB Primary Color Filters | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Low Pass Filter | Installed In Front Of The Image Sensor, Non-Detachable | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dust Deletion Feature |
| Recording Format | Compliant To Design Rule For Camera File System 2.0 And Exif 2.3* * Supports Time Difference Information. |
| File Size | 3:2 Aspect Ratio 4:3 Aspect Ratio 16:9 Aspect Ratio 1:1 Aspect Ratio
| File Numbering | File Numbering Can Be Set As Follows:<
| Raw Jpeg Simultaneous Recording | Simultaneous Recording Of Any Combination Of RAW/C-RAW And JPEG Image-Recording Quality Is Supported. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Color Space | SRGB/Adobe RGB | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Picture Style |
| Settings |
| Auto White Balance | Option Between Ambience Priority And White Priority Settings | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Color Temperature Compensation | Blue/Amber Bias: ±9 Levels Magenta/Green Bias: ±9 Levels * Corrected In Reference To The Current WB Mode's Color Temperature. * Blue/Amber And Magenta/Green Correction Can Be Set At The Same Time. |
| Type | Eye-Level SLR (With Fixed Pentaprism) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Coverage | Approx. 95% Vertical/Horizontal Coverage (At Approx. 19mm Eye Point And Large Image Size) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Magnification | Approx. 0.87x/24.5° (With 50mm Lens At Infinity, -1 M-1) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Eyepoint | Approx. 19 Mm (At -1m-1 From The Eyepiece Lens Center) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dioptric Adjustment Correction | Adjustable From Approx. -3.0 To +1.0 M-1 (Dpt) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing Screen | Fixed | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Mirror | Quick-Return Half Mirror (Transmission: Reflection Ratio Of 40:60) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Viewfinder Information | Spot Metering Circle, AF Point Activation Indicator, AF Point, ISO Speed Indicator, Focus Indicator, Maximum Burst, ISO Speed, Highlight Tone Priority, Exposure Level Indicator, Exposure Compensation Amount, AEB Range, Red-Eye Reduction Lamp ON, Exposure Compensation, Aperture, Shutter Speed, Bulb Exposure, FE Lock, Busy, Built-In Flash Recharging, No Card Warning, Card Error, Card Full Warning, Error Code, Flash Exposure Compensation, High-Speed Sync, FE Lock / FEB In-Progress, Flash-Ready, Improper FE Lock Warning, AE Lock, AEB In-Progress, Warning Icon. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Depth Of Field Preview | Provided With Customized DISP Button Settings. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | TTL Secondary Image-Forming Phase-Difference Detection System With AF-Dedicated Sensor | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Af Points | 9 Points Center AF Point Is AF Cross-Type Supporting F/5.6. Center AF Point Is Vertical Line-Sensitive Supporting F/2.8. Other AF Points Is Vertical Line-Sensitive Or Horizontal Line-Sensitive AF Supporting F/5.6. |
| Af Working Range | With One-Shot AF, At 73°F/23°C, ISO 100 EV -0.5-18 (Center AF Point) EV 0.5-18 (Other AF Points) (Based On Canon’s Testing Standards And Environment) |
| Focusing Modes |
| Af Point Selection |
| Af Assist Beam |
| Metering Modes | 63-Zone Metering Sensor (1) Evaluative Metering (Linked To All AF Points) (2) Partial Metering (Center, Approx. 9.0% Of Viewfinder) (3) Spot Metering (Center, Approx. 4.0% Of Viewfinder) (4) Center-Weighted Average Metering |
| Metering Range | EV 1.0 - EV 20.0 (At 73°F/23°C, ISO 100, Evaluative Metering) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Control Systems |
| Iso Speed Range | Manual Setting
Auto
*1 ISO 200 When [Highlight Tone Priority] Is Set To [Enable] Or [Enhanced]. |
| Exposure Compensation |
* Up To ±3 Stops When [Shooting Screen: Guided] Is Set. |
| Ae Lock |
| Type | Vertical-Travel, Mechanical, Focal-Plane Shutter With All Speeds Electronically-Controlled * Electronic 1st Curtain And Mechanical 2nd Curtain |
| Shutter Speeds | Creative Zone: 1/4000 To 30 Sec., Bulb
| Shutter Release | Soft-Touch Electromagnetic Release | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Self Timer | 10-Sec. Delay, 2-Sec. Delay, Continuous Shooting After 10 Sec. (2 To 10 Shots) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Shutter Lag Time | With SW-1 ON, Time Lag Between SW-2 ON And Start Of Exposure: Approx. 0.075 Sec.
| Fe Lock | Provided | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Metering | E-TTL II Autoflash (Evaluative, Average), FE Lock | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Exposure Compensation | ±2 Stops In 1/3- Or 1/2-Stop Increments
| External Flash Settings | The Camera Can Set The Following With EX Series Speedlites:
| Drive Modes |
| Max Burst During Continuous Shooting |
The Number Of Possible Shots And Maximum Burst (Standard) Apply To A UHS-I Compliant 32GB Card Base On Canon Testing Standards. |
| Shooting Modes | Still Photo Shooting And Video Shooting | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Focusing |
| Metering Modes | Real-Time Metering With Image Sensor
| Metering Range | EV 0-20 (At 73°F/23°C, ISO 100, Evaluative Metering) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Grid Display |
| File Format | MP4 Video: MPEG-4 AVC/H.264
Video Recording Size And Frame Rates
* The Image Is Cropped Around The Center Of The Image Sensor. Time-Lapse Movie (MP4)
* Some Limitations Apply When Scene 1, Scene 2, Or Scene 3 Is Used. |
| Continuous Shooting Time | Continuous Shooting Time
Bit Rate Indicates Video Output Only, Audio Is Not Included. |
| Focusing |
| Range | Full Range (0-255) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Exposure Compensation | Up To ±3 Stops In 1/3- Or 1/2-Stop Increments | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Type | TFT Color, Liquid-Crystal Monitor | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Screen Monitor Size | 3.0-Inch (Screen Aspect Ratio Of 3:2) Approx. 2.95 In./7.50cm Diagonal (Approx. 2.46 In./6.24cm Width, Approx. 1.64 In/4.16cm Height) |
| Pixels | Approx. 1.04 Million Dots | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Coverage | Approx. 170° Vertically And Horizontally | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Brightness Control | Adjustable To One Of Seven Brightness Levels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Coating | Clear View LCD II
| Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, And Japanese) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Image Display Format |
| Highlight Alert | With Detailed Information Display, Overexposed Highlight Areas With No Image Data Will Blink. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Histogram | Brightness And RGB | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Items | Pressing The Quick Control Button Displays The Quick Control Screen During Viewfinder Shooting, Live View Shooting, Movie Shooting And Playback. After Selecting An Item, You Can Select Contents By Operating The Main Dial. |
| Protection |
| Erase | Except Protected Images
| Compatible Printers | Images Can Be Sent Via Wi-Fi® To A PictBridge-Compatible (Wireless LAN) Printer And Printed. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dpof | Complies To DPOF Version 1.1 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| My Menu Registration |
| Usb Terminal | Hi-Speed USB (USB 2.0)
| Video Out Terminal | Type C (Resolution Switches Automatically)
| Extension System Terminal | 3.5mm Diameter Stereo Mini Jack
| Battery | Battery Pack LP-E17 X 1
| Battery Life |
Using A Fully Charged LP-E17. |
| Battery Check | Automatic Battery Check When The Power Switch Is Turned ON. Displayed In 4 Levels. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Power Saving | Power Turns Off After The Set Time (10/30* Or 30 Sec., 1, 2, 4, 8 Or 15 Min.) Of Non-Operation Elapses. * Normally 10 Sec. Is Set. 30 Sec. Will Be Set For Function Setting, Live View Shooting, Image Playback, Etc. |
| Date Time Battery | Built-In Secondary Battery
| Start Up Time | Approx. 0.2 Sec. (Based On CIPA Testing Standards) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Dimensions W X H X D | Approx. 4.82 X 3.65 X 2.75 In. (122.4 X 92.6 X 69.8mm)
| Weight | Black Approx. 15.84 Oz. / 449g (Including Battery And Card) Approx. 14.18 Oz. / 402g (Body Only) White Approx. 15.91 Oz. / 451g (Including Battery And Card) Approx 14.25 Oz. / 404g (Body Only) |
| Operating Temperature Range | 32-104°F/0-40°C | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Operating Humidity Range | 85% Or Less | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Remote Switch RS-60E3
Compact remote switch replicating all of the functions of the shutter release button.
A wireless remote controller compatible with Bluetooth enabled cameras for wireless focusing, still shooting and video recording, and zooming using the Power Zoom Adapter PZ-E1. Operating distance is approximately 16 ft in any direction.
Directional Microphone
DM-E1
Crisp sound. Superb performance. The new Directional Microphone DM-E1 can help experienced videographers and aspiring filmmakers alike achieve high-quality audio when recording video using a compatible Canon EOS digital camera*.
Battery charger for LP-E17 Li-ion batteries for EOS Rebel Camera.
Interface Cable IFC-600PCU
Conveniently charge the battery in your PowerShot by connecting the camera to your computer using the IFC-600PCU cable
Hand Strap E2
The Canon Hand Strap E2 is designed to add support and comfort to hand-holding a Canon SLR camera. The strap attaches to the eyelets at the sides of the camera.
AC Adapter AC-E6N
Provides AC power to the camera with the combination of DR-E6.
DC Coupler DR-E18
When shooting indoors, in a studio or on a tabletop, use this DC coupler to provide uninterrupted power to your EOS camera.
Eyecup Ef
Magnifier MG-Ef
A viewfinder accessory developed to make it easier to check the composition. It magnifies the viewfinder image by approx. 1.2 times. This model is compatible with the EOS Rebel models. * Please note that the magnifier will reduce the field of view visible through the camera's viewfinder and display. This effect on the image through the viewfinder will be more pronounced while wearing glasses. The magnifier may blur the image visible through the viewfinder and may make it more difficult to focus the camera manually. Please note, the image taken with the camera will not be affected by any of the above.
Rubber Frame EF
The Ef rubber frame replaces the standard eyecup when using a Diopter lens.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
